Multiple Displays with Jetson Orin Nano on Board Level
Hi dear community,
We want to develop a Embedded System with the Jetson Orin Nano as Compute module. Our device needs two internal displays (e.g. LVDS/MIPI-DSI) is there any experience with multiplexing the Display Port signal to connect two displays on board level? My first research lead me to the following chip (but i can’t find any source to purchase it - just this datasheet) https://www.analogix.com/en/output/two-dual-mipi-dsi.
I am not sure, if it would be more useable to multiplex the signal on DP side or first use a converter to MIPI-DSI and try to split it on MIPI-DSI Side.
As this is my first post in this forum, please correct me, if some information is missing or this is the wrong place for my question ;-).
Thank you very much in advance!
Orin can only support 2 displays by using DP-MST hub. There is no other interface that is officially working for 2 displays.
Thank you very much for the quick response. Is there any suggested DP-MST hub on board level, which is recommended?
