How can I connect two monitors on Jetson Agx Orin 64gb dev kit? Is it possible with MST hub? Is there any other option too?
Thank you for your answer.
Yes, Multiple displays can be supported over DP interface with MST for 2x4K60 resolutions.
Thank you for your answer. Will it be same image on both monitors or different?
The MST is for different.
