Hello @kayccc,
I have asked earlier if it is possible to use multiple monitors with MST hub on Jetson Agx Orin 64gb dev kit:
I have received MST hub but there is no image on any of connected two monitors. What can be a problem?
Thank you.
Hello @kayccc,
Thank you.
Are you using the latest JetPack 5.1.2 SW?
Yes, I am using Jetpack 5.1.2.
Does the monitor work when you don’t connect with MST?
Yes, one monitor work normally on Jetson but when I try two monitors with MST hub, there is no image on any of them.
Hello @WayneWWW @marinkovicivan
I am trying to find an MST Hub that is comaptible with Jetson since I want to connect two displays to my jetson where each is showing a different feed from each of my two connected cameras to Jetson AGX ORIN 64G.
Looking at Amazon, lots of them are specific to Windows.
Could you please share one that would work on Ubuntu 22.04 on Jetson?
Jetson AGX ORIN 64G only has one DP port. My displays each have both DP and HDMI port.
