We are using Orin AGX industrial and I would like to know how many simultaneous video outputs it supports and what is needed (on hardware) to implement multiple video outputs?
Thanks in advance,
Y
Thanks in advance,
Y
Thanks for visiting the NVIDIA Developer forums! Your topic will be best served in the Jetson category.
I will move this post over for visibility.
Cheers,
Tom
If using DP MST, then 2 display output could be used. If using HDMI, then 1 display output.
Thank you for your swift reply; could you please elaborate how to implement in hardware if using DP MST?
Y
Please refer to the hardware design guide document of Orin AGX.
The MST is achieve by external MST Hub.
Thanks again, is there any reference design I can use please?
Y
You could check the download center which has the schematic of our reference board.
