hi,
for our development on our carrier board we need 2 displays which have to be connected via the displayports.
as i understand it the Orin AGX supports only one physical DP.
But on the Nvidia reference design the ORIN AGX has 2 physical DP ports:
can we connect 2 displays to the 2 ports although some pins of HDMI_DP0 are set as RESERVED in pinmux? or is only HDMI_DP2 available and you need an external MST compatible IC to split the HDMI DP2 signal into 2 separate signals?
