How many displays will ORIN NX DP MST support?
The ORIN AGX MST only supports 2,and how about the ORIN NX ?
The same as AGX Orin.
BUT From: “Jetson_Orin_NX_DS-10712-001_v0.4.pdf”
it mentioned:
Display Controller
1x shared HDMI 2.1, eDP 1.4, VESA DisplayPort 1.4a HBR3
Maximum Resolution (eDP/DP/HDMI): up to 3840x2160 at 60 Hz (up to
36 bpp) | up to four displays can be supported over DP interface with
MST and compatible serializer…
So four displays will be supported?? …And it will influence our design…
which is true???
No, the datasheet is talking about that port could be used as “either” HDMI/eDP or DP.
Has nothing do with the maximum display supported.
