Hi
How many displays can be connected to AGX Xavier 32GB?
I understand that the AGX Xavier is two displays.
Is it correct?
How many displays will ORIN NX DP MST support? - Jetson & Embedded Systems / Jetson Orin NX - NVIDIA Developer Forums
I understand that the orin series is also limited to two units.
Is there a Jetson module that can connect three displays?
Best regards
Xavier AGX can connect to 3 display heads.
Thank you for your reply.
Am I correct in understanding that since there are three outputs (DP, HDMI, eDP), I can connect three displays to each of them?
That means I need a custom carrier board, right?
Bestregards
Xavier AGX devkit have 2 DP and 1 HDMI port.
DP is shared within the type C port.
Thank you for your reply!
system
Closed
8
