Hi nVidia Jetson Team
AGX Orin display spec:1x8K@60
8K@60 means 4K@60x4
Does Orin with MST HUB(DP 1.4) support at least 4K@60x3?
if not,what’s the Orin MST maximum capacity with 3 display output?
8K@60 means 4K@60x4
Currently, only 2x4K60 can be supported.
Hi Kayccc
thanks for reply
downgrade to 4K@30 ,3 port output can be support?
or another question
in MST 3 monitor situation ,what are the maximum resolution of each output port?
Currently there is no 3 monitors supported. Maximum to 2.
Hi WayneWWW
So, even in 1080P@30 resolution ,Orin just only support 2 monitor out through MST?
What’s the limitation? hardware or firmware
Is it possible to upgrade to 3 or more in the future?
