We need to use two simultaneous video outputs from AGX Orin. We see that there are two graphic heads available. It looks like Display Port and HDMI sharing the same interface pins. Is there a way to use two simultaneous video outputs from AGX Orin? Each one, from different graphic head (not MST from same display port).
No, there is no other method than MST in DP on Orin. Only one display head.
Thank you very much for the rapid reply.
