How to split the display screen in Jeston AGX Orin
I have a Jeston AGX Orin device, which contain only one display port, I want to split the screen like to have two screen run on the device. I don’t want it to be a mirror, each screen will like display different application for example, how to do that since the device have one display port? Can I use things like [Multi-Stream Transport (MST) Hub, DP to 2X HDMI 2.0 (DisplayPort to Dual HDMI)] and thank you :)
Sorry for the late response, our team will do the investigation and provide suggestions soon. Thanks
Only MST on pure DP is supported. DP to 2x HDMI is not guaranteed
