wnliu
1
Hi all,
I have a BlueField-2 DPU100GbE (Model No: BF2H516A), and it is totally unresponsive.
I install it on AMD Ryzen 7 3700X + b450 platform, and DELL R750 server, with 12V ATX plugged.
The lights never come on. And lspci never found it.
Is this normal? Is this card good? What should I do to check if it’s good or bad?
vikiz
2
You should follow this guide to make sure everything is set correctly:
https://docs.nvidia.com/networking/display/bluefield2dpuenug/hardware+installation
Best Regards,
Viki
I had a somewhat similar problem in the past, the DPU was overheating and shutting itself down.
Make sure you are providing adequate ventilation
