Thanks for your guides.
I have downloaded an image with Jetpack 4.2.1 for my Jetson Nano Card:
Jetson Nano Developer Kit SD Card Image JP 4.2 2019/06/07
SInce installed deepstream on host was 4.0.1, I have pulled a docker image with deepstream 4.0.1 from this link:
DeepStream-l4t
Details of installed tools in Jetpack 4.2.1:
Cuda: 10.0
Cudnn:7.5
TensrRT:5.1
and after that I run my program in this host & docker image successfully.
Now I want to transfer produced docker image to another Jetson Nano card, for example with Jetpack 4.4. So I have downloaded this image latest Jetson Nano SD Card Image.
Cuda: 10.2
Cudnn:8.0
TensrRT:7.1
I did not install deepstream in this card. Because I want to run my docker image without installing deepstream on new host. When I want to run my program in new sd card , it gives me this error:
./Velocity: symbol lookup error: /usr/lib/aarch64-linux-gnu/libcuda.so.1: undefined symbol: NvRmHost1xGetDefaultOpenAttrs
but this file is accessible in docker :
ls /usr/lib/aarch64-linux-gnu/libcuda.so
and when I check that so file in host,
there is just one so file, while there are 3 so file in docker.
All dependent so files for my executable program are available:
root@Sayna122:/home/nano/Documents/Projects/Velocity/builds/Debug# ldd Velocity
linux-vdso.so.1 (0x0000007f78536000)
libpthread.so.0 => /lib/aarch64-linux-gnu/libpthread.so.0 (0x0000007f7837a000)
libX11.so.6 => /usr/lib/aarch64-linux-gnu/libX11.so.6 (0x0000007f78251000)
libgflags.so.2.2 => /usr/lib/aarch64-linux-gnu/libgflags.so.2.2 (0x0000007f78220000)
libpaho-mqtt3c.so.1 => /usr/local/lib/libpaho-mqtt3c.so.1 (0x0000007f7815b000)
libpylonbase-5.2.0.so => /opt/pylon5/lib64/libpylonbase-5.2.0.so (0x0000007f77811000)
libpylonutility-5.2.0.so => /opt/pylon5/lib64/libpylonutility-5.2.0.so (0x0000007f7764d000)
libGCBase_gcc_v3_1_Basler_pylon.so => /opt/pylon5/lib64/libGCBase_gcc_v3_1_Basler_pylon.so (0x0000007f77621000)
libnvinfer_plugin.so.5 => /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so.5 (0x0000007f7734b000)
libnvinfer.so.5 => /usr/lib/aarch64-linux-gnu/libnvinfer.so.5 (0x0000007f6e3ff000)
libcurl.so.4 => /usr/lib/aarch64-linux-gnu/libcurl.so.4 (0x0000007f6e382000)
libgstbase-1.0.so.0 => /usr/lib/aarch64-linux-gnu/libgstbase-1.0.so.0 (0x0000007f6e30b000)
libgstreamer-1.0.so.0 => /usr/lib/aarch64-linux-gnu/libgstreamer-1.0.so.0 (0x0000007f6e1db000)
libgstvideo-1.0.so.0 => /usr/lib/aarch64-linux-gnu/libgstvideo-1.0.so.0 (0x0000007f6e147000)
libgobject-2.0.so.0 => /usr/lib/aarch64-linux-gnu/libgobject-2.0.so.0 (0x0000007f6e0e9000)
libglib-2.0.so.0 => /usr/lib/aarch64-linux-gnu/libglib-2.0.so.0 (0x0000007f6dfdb000)
libcudart.so.10.0 => /usr/local/lib/libcudart.so.10.0 (0x0000007f6df6a000)
libnppc.so.10.0 => /usr/local/lib/libnppc.so.10.0 (0x0000007f6dedf000)
libnppig.so.10.0 => /usr/local/lib/libnppig.so.10.0 (0x0000007f6c591000)
libnvdsgst_dsexample.so => /opt/nvidia/deepstream/deepstream-4.0/lib/gst-plugins/libnvdsgst_dsexample.so (0x0000007f6c519000)
libnvdsgst_meta.so => /opt/nvidia/deepstream/deepstream-4.0/lib/libnvdsgst_meta.so (0x0000007f6c505000)
libnvds_meta.so => /opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_meta.so (0x0000007f6c4ef000)
libnvdsgst_helper.so => /opt/nvidia/deepstream/deepstream-4.0/lib/libnvdsgst_helper.so (0x0000007f6c4db000)
libnvbufsurface.so.1.0.0 => /usr/local/lib/libnvbufsurface.so.1.0.0 (0x0000007f6c45d000)
libnvbufsurftransform.so.1.0.0 => /usr/local/lib/libnvbufsurftransform.so.1.0.0 (0x0000007f6bdd8000)
libopencv_dnn.so.3.3 => /usr/local/lib/libopencv_dnn.so.3.3 (0x0000007f6baa8000)
libopencv_highgui.so.3.3 => /usr/local/lib/libopencv_highgui.so.3.3 (0x0000007f6ba84000)
libopencv_imgcodecs.so.3.3 => /usr/local/lib/libopencv_imgcodecs.so.3.3 (0x0000007f6b960000)
libopencv_imgproc.so.3.3 => /usr/local/lib/libopencv_imgproc.so.3.3 (0x0000007f6b193000)
libopencv_core.so.3.3 => /usr/local/lib/libopencv_core.so.3.3 (0x0000007f6aebe000)
libstdc++.so.6 => /usr/lib/aarch64-linux-gnu/libstdc++.so.6 (0x0000007f6ad2a000)
libm.so.6 => /lib/aarch64-linux-gnu/libm.so.6 (0x0000007f6ac70000)
libgcc_s.so.1 => /lib/aarch64-linux-gnu/libgcc_s.so.1 (0x0000007f6ac4c000)
libc.so.6 => /lib/aarch64-linux-gnu/libc.so.6 (0x0000007f6aaf3000)
/lib/ld-linux-aarch64.so.1 (0x0000007f7850b000)
libxcb.so.1 => /usr/lib/aarch64-linux-gnu/libxcb.so.1 (0x0000007f6aac3000)
libdl.so.2 => /lib/aarch64-linux-gnu/libdl.so.2 (0x0000007f6aaae000)
librt.so.1 => /lib/aarch64-linux-gnu/librt.so.1 (0x0000007f6aa95000)
libGenApi_gcc_v3_1_Basler_pylon.so => /opt/pylon5/lib64/libGenApi_gcc_v3_1_Basler_pylon.so (0x0000007f6a625000)
libLog_gcc_v3_1_Basler_pylon.so => /opt/pylon5/lib64/libLog_gcc_v3_1_Basler_pylon.so (0x0000007f6a60b000)
libcudnn.so.7 => /usr/local/lib/libcudnn.so.7 (0x0000007f537a5000)
libcublas.so.10.0 => /usr/local/lib/libcublas.so.10.0 (0x0000007f4de3e000)
libnghttp2.so.14 => /usr/lib/aarch64-linux-gnu/libnghttp2.so.14 (0x0000007f4de0c000)
libidn2.so.0 => /usr/lib/aarch64-linux-gnu/libidn2.so.0 (0x0000007f4dde0000)
librtmp.so.1 => /usr/lib/aarch64-linux-gnu/librtmp.so.1 (0x0000007f4ddb6000)
libpsl.so.5 => /usr/lib/aarch64-linux-gnu/libpsl.so.5 (0x0000007f4dd98000)
libssl.so.1.1 => /usr/lib/aarch64-linux-gnu/libssl.so.1.1 (0x0000007f4dd0e000)
libcrypto.so.1.1 => /usr/lib/aarch64-linux-gnu/libcrypto.so.1.1 (0x0000007f4dacd000)
libgssapi_krb5.so.2 => /usr/lib/aarch64-linux-gnu/libgssapi_krb5.so.2 (0x0000007f4da7b000)
libldap_r-2.4.so.2 => /usr/lib/aarch64-linux-gnu/libldap_r-2.4.so.2 (0x0000007f4da22000)
liblber-2.4.so.2 => /usr/lib/aarch64-linux-gnu/liblber-2.4.so.2 (0x0000007f4da05000)
libz.so.1 => /lib/aarch64-linux-gnu/libz.so.1 (0x0000007f4d9d8000)
libgmodule-2.0.so.0 => /usr/lib/aarch64-linux-gnu/libgmodule-2.0.so.0 (0x0000007f4d9c4000)
liborc-0.4.so.0 => /usr/lib/aarch64-linux-gnu/liborc-0.4.so.0 (0x0000007f4d94b000)
libffi.so.6 => /usr/lib/aarch64-linux-gnu/libffi.so.6 (0x0000007f4d931000)
libpcre.so.3 => /lib/aarch64-linux-gnu/libpcre.so.3 (0x0000007f4d8bf000)
libopencv_imgcodecs.so.3.2 => /usr/lib/aarch64-linux-gnu/libopencv_imgcodecs.so.3.2 (0x0000007f4d879000)
libopencv_imgproc.so.3.2 => /usr/lib/aarch64-linux-gnu/libopencv_imgproc.so.3.2 (0x0000007f4d57a000)
libopencv_core.so.3.2 => /usr/lib/aarch64-linux-gnu/libopencv_core.so.3.2 (0x0000007f4d377000)
libnvrm.so => /usr/local/lib/libnvrm.so (0x0000007f4d333000)
libEGL.so.1 => /usr/lib/aarch64-linux-gnu/libEGL.so.1 (0x0000007f4d312000)
libnvos.so => /usr/local/lib/libnvos.so (0x0000007f4d2f4000)
libnvbuf_fdmap.so.1.0.0 => /usr/local/lib/libnvbuf_fdmap.so.1.0.0 (0x0000007f4d2e1000)
libnvrm_graphics.so => /usr/local/lib/libnvrm_graphics.so (0x0000007f4d2c2000)
libnvddk_vic.so => /usr/local/lib/libnvddk_vic.so (0x0000007f4d2a4000)
libcuda.so.1 => /usr/lib/aarch64-linux-gnu/libcuda.so.1 (0x0000007f4c35f000)
libgtk-x11-2.0.so.0 => /usr/local/lib/libgtk-x11-2.0.so.0 (0x0000007f4bf8e000)
libgdk-x11-2.0.so.0 => /usr/local/lib/libgdk-x11-2.0.so.0 (0x0000007f4bedf000)
libcairo.so.2 => /usr/lib/aarch64-linux-gnu/libcairo.so.2 (0x0000007f4bde5000)
libgdk_pixbuf-2.0.so.0 => /usr/lib/aarch64-linux-gnu/libgdk_pixbuf-2.0.so.0 (0x0000007f4bdb6000)
libjpeg.so.8 => /usr/lib/aarch64-linux-gnu/libjpeg.so.8 (0x0000007f4bd6a000)
libpng16.so.16 => /usr/lib/aarch64-linux-gnu/libpng16.so.16 (0x0000007f4bd2f000)
libtiff.so.5 => /usr/lib/aarch64-linux-gnu/libtiff.so.5 (0x0000007f4bcb4000)
libtbb.so.2 => /usr/lib/aarch64-linux-gnu/libtbb.so.2 (0x0000007f4bc76000)
libXau.so.6 => /usr/lib/aarch64-linux-gnu/libXau.so.6 (0x0000007f4bc63000)
libXdmcp.so.6 => /usr/lib/aarch64-linux-gnu/libXdmcp.so.6 (0x0000007f4bc4c000)
libMathParser_gcc_v3_1_Basler_pylon.so => /opt/pylon5/lib64/libMathParser_gcc_v3_1_Basler_pylon.so (0x0000007f4bc31000)
libXmlParser_gcc_v3_1_Basler_pylon.so => /opt/pylon5/lib64/libXmlParser_gcc_v3_1_Basler_pylon.so (0x0000007f4bad5000)
libNodeMapData_gcc_v3_1_Basler_pylon.so => /opt/pylon5/lib64/libNodeMapData_gcc_v3_1_Basler_pylon.so (0x0000007f4baaa000)
libunistring.so.2 => /usr/lib/aarch64-linux-gnu/libunistring.so.2 (0x0000007f4b927000)
libgnutls.so.30 => /usr/lib/aarch64-linux-gnu/libgnutls.so.30 (0x0000007f4b7c7000)
libhogweed.so.4 => /usr/lib/aarch64-linux-gnu/libhogweed.so.4 (0x0000007f4b786000)
libnettle.so.6 => /usr/lib/aarch64-linux-gnu/libnettle.so.6 (0x0000007f4b745000)
libgmp.so.10 => /usr/lib/aarch64-linux-gnu/libgmp.so.10 (0x0000007f4b6c8000)
libkrb5.so.3 => /usr/lib/aarch64-linux-gnu/libkrb5.so.3 (0x0000007f4b5f9000)
libk5crypto.so.3 => /usr/lib/aarch64-linux-gnu/libk5crypto.so.3 (0x0000007f4b5bb000)
libcom_err.so.2 => /lib/aarch64-linux-gnu/libcom_err.so.2 (0x0000007f4b5a5000)
libkrb5support.so.0 => /usr/lib/aarch64-linux-gnu/libkrb5support.so.0 (0x0000007f4b58b000)
libresolv.so.2 => /lib/aarch64-linux-gnu/libresolv.so.2 (0x0000007f4b566000)
libsasl2.so.2 => /usr/lib/aarch64-linux-gnu/libsasl2.so.2 (0x0000007f4b53e000)
libgssapi.so.3 => /usr/lib/aarch64-linux-gnu/libgssapi.so.3 (0x0000007f4b4f6000)
libwebp.so.6 => /usr/lib/aarch64-linux-gnu/libwebp.so.6 (0x0000007f4b49c000)
libgdcmMSFF.so.2.8 => /usr/lib/aarch64-linux-gnu/libgdcmMSFF.so.2.8 (0x0000007f4b23e000)
libIlmImf-2_2.so.22 => /usr/lib/aarch64-linux-gnu/libIlmImf-2_2.so.22 (0x0000007f4af77000)
libHalf.so.12 => /usr/lib/aarch64-linux-gnu/libHalf.so.12 (0x0000007f4af24000)
libgdal.so.20 => /usr/lib/libgdal.so.20 (0x0000007f49fa3000)
libgdcmDSED.so.2.8 => /usr/lib/aarch64-linux-gnu/libgdcmDSED.so.2.8 (0x0000007f49e81000)
libGLdispatch.so.0 => /usr/lib/aarch64-linux-gnu/libGLdispatch.so.0 (0x0000007f49d53000)
libnvrm_gpu.so => /usr/local/lib/libnvrm_gpu.so (0x0000007f49d10000)
libnvidia-fatbinaryloader.so.440.18 => /usr/lib/aarch64-linux-gnu/libnvidia-fatbinaryloader.so.440.18 (0x0000007f49ca1000)
libpangocairo-1.0.so.0 => /usr/lib/aarch64-linux-gnu/libpangocairo-1.0.so.0 (0x0000007f49c85000)
libXfixes.so.3 => /usr/lib/aarch64-linux-gnu/libXfixes.so.3 (0x0000007f49c6f000)
libatk-1.0.so.0 => /usr/lib/aarch64-linux-gnu/libatk-1.0.so.0 (0x0000007f49c39000)
libgio-2.0.so.0 => /usr/lib/aarch64-linux-gnu/libgio-2.0.so.0 (0x0000007f49abd000)
libpangoft2-1.0.so.0 => /usr/lib/aarch64-linux-gnu/libpangoft2-1.0.so.0 (0x0000007f49a9a000)
libpango-1.0.so.0 => /usr/lib/aarch64-linux-gnu/libpango-1.0.so.0 (0x0000007f49a43000)
libfontconfig.so.1 => /usr/lib/aarch64-linux-gnu/libfontconfig.so.1 (0x0000007f499f3000)
libXrender.so.1 => /usr/lib/aarch64-linux-gnu/libXrender.so.1 (0x0000007f499da000)
libXinerama.so.1 => /usr/lib/aarch64-linux-gnu/libXinerama.so.1 (0x0000007f499c5000)
libXi.so.6 => /usr/lib/aarch64-linux-gnu/libXi.so.6 (0x0000007f499a7000)
libXrandr.so.2 => /usr/lib/aarch64-linux-gnu/libXrandr.so.2 (0x0000007f4998d000)
libXcursor.so.1 => /usr/lib/aarch64-linux-gnu/libXcursor.so.1 (0x0000007f49974000)
libXcomposite.so.1 => /usr/lib/aarch64-linux-gnu/libXcomposite.so.1 (0x0000007f49961000)
libXdamage.so.1 => /usr/lib/aarch64-linux-gnu/libXdamage.so.1 (0x0000007f4994e000)
libXext.so.6 => /usr/lib/aarch64-linux-gnu/libXext.so.6 (0x0000007f4992c000)
libpixman-1.so.0 => /usr/lib/aarch64-linux-gnu/libpixman-1.so.0 (0x0000007f498c8000)
libfreetype.so.6 => /usr/lib/aarch64-linux-gnu/libfreetype.so.6 (0x0000007f4981f000)
libxcb-shm.so.0 => /usr/lib/aarch64-linux-gnu/libxcb-shm.so.0 (0x0000007f4980c000)
libxcb-render.so.0 => /usr/lib/aarch64-linux-gnu/libxcb-render.so.0 (0x0000007f497f1000)
liblzma.so.5 => /lib/aarch64-linux-gnu/liblzma.so.5 (0x0000007f497bf000)
libjbig.so.0 => /usr/lib/aarch64-linux-gnu/libjbig.so.0 (0x0000007f497a2000)
libbsd.so.0 => /lib/aarch64-linux-gnu/libbsd.so.0 (0x0000007f49780000)
libp11-kit.so.0 => /usr/lib/aarch64-linux-gnu/libp11-kit.so.0 (0x0000007f4966e000)
libtasn1.so.6 => /usr/lib/aarch64-linux-gnu/libtasn1.so.6 (0x0000007f4964d000)
libkeyutils.so.1 => /lib/aarch64-linux-gnu/libkeyutils.so.1 (0x0000007f49637000)
libheimntlm.so.0 => /usr/lib/aarch64-linux-gnu/libheimntlm.so.0 (0x0000007f4961e000)
libkrb5.so.26 => /usr/lib/aarch64-linux-gnu/libkrb5.so.26 (0x0000007f49594000)
libasn1.so.8 => /usr/lib/aarch64-linux-gnu/libasn1.so.8 (0x0000007f494fe000)
libhcrypto.so.4 => /usr/lib/aarch64-linux-gnu/libhcrypto.so.4 (0x0000007f494bf000)
libroken.so.18 => /usr/lib/aarch64-linux-gnu/libroken.so.18 (0x0000007f4949c000)
libgdcmIOD.so.2.8 => /usr/lib/aarch64-linux-gnu/libgdcmIOD.so.2.8 (0x0000007f49475000)
libgdcmDICT.so.2.8 => /usr/lib/aarch64-linux-gnu/libgdcmDICT.so.2.8 (0x0000007f491fb000)
libgdcmjpeg8.so.2.8 => /usr/lib/aarch64-linux-gnu/libgdcmjpeg8.so.2.8 (0x0000007f491c9000)
libgdcmjpeg12.so.2.8 => /usr/lib/aarch64-linux-gnu/libgdcmjpeg12.so.2.8 (0x0000007f49197000)
libgdcmjpeg16.so.2.8 => /usr/lib/aarch64-linux-gnu/libgdcmjpeg16.so.2.8 (0x0000007f49165000)
libopenjp2.so.7 => /usr/lib/aarch64-linux-gnu/libopenjp2.so.7 (0x0000007f4910a000)
libCharLS.so.1 => /usr/lib/aarch64-linux-gnu/libCharLS.so.1 (0x0000007f490b5000)
libuuid.so.1 => /lib/aarch64-linux-gnu/libuuid.so.1 (0x0000007f4909e000)
libjson-c.so.3 => /lib/aarch64-linux-gnu/libjson-c.so.3 (0x0000007f49084000)
libgdcmCommon.so.2.8 => /usr/lib/aarch64-linux-gnu/libgdcmCommon.so.2.8 (0x0000007f4904d000)
libIex-2_2.so.12 => /usr/lib/aarch64-linux-gnu/libIex-2_2.so.12 (0x0000007f4901d000)
libIlmThread-2_2.so.12 => /usr/lib/aarch64-linux-gnu/libIlmThread-2_2.so.12 (0x0000007f49006000)
libarmadillo.so.8 => /usr/lib/libarmadillo.so.8 (0x0000007f48feb000)
libproj.so.12 => /usr/lib/aarch64-linux-gnu/libproj.so.12 (0x0000007f48f8d000)
libpoppler.so.73 => /usr/lib/aarch64-linux-gnu/libpoppler.so.73 (0x0000007f48d28000)
libfreexl.so.1 => /usr/lib/aarch64-linux-gnu/libfreexl.so.1 (0x0000007f48d0f000)
libqhull.so.7 => /usr/lib/aarch64-linux-gnu/libqhull.so.7 (0x0000007f48cb1000)
libgeos_c.so.1 => /usr/lib/aarch64-linux-gnu/libgeos_c.so.1 (0x0000007f48c6f000)
libepsilon.so.1 => /usr/lib/aarch64-linux-gnu/libepsilon.so.1 (0x0000007f48c47000)
libodbc.so.2 => /usr/lib/aarch64-linux-gnu/libodbc.so.2 (0x0000007f48bd8000)
libodbcinst.so.2 => /usr/lib/aarch64-linux-gnu/libodbcinst.so.2 (0x0000007f48bb4000)
libkmlbase.so.1 => /usr/lib/aarch64-linux-gnu/libkmlbase.so.1 (0x0000007f48b8a000)
libkmldom.so.1 => /usr/lib/aarch64-linux-gnu/libkmldom.so.1 (0x0000007f48acd000)
libkmlengine.so.1 => /usr/lib/aarch64-linux-gnu/libkmlengine.so.1 (0x0000007f48a86000)
libexpat.so.1 => /lib/aarch64-linux-gnu/libexpat.so.1 (0x0000007f48a45000)
libxerces-c-3.2.so => /usr/lib/aarch64-linux-gnu/libxerces-c-3.2.so (0x0000007f486c0000)
libnetcdf.so.13 => /usr/lib/aarch64-linux-gnu/libnetcdf.so.13 (0x0000007f485a7000)
libhdf5_serial.so.100 => /usr/lib/aarch64-linux-gnu/libhdf5_serial.so.100 (0x0000007f4826e000)
libmfhdfalt.so.0 => /usr/lib/libmfhdfalt.so.0 (0x0000007f4823b000)
libdfalt.so.0 => /usr/lib/libdfalt.so.0 (0x0000007f48192000)
libogdi.so.3.2 => /usr/lib/libogdi.so.3.2 (0x0000007f48165000)
libgif.so.7 => /usr/lib/aarch64-linux-gnu/libgif.so.7 (0x0000007f4814d000)
libgeotiff.so.2 => /usr/lib/aarch64-linux-gnu/libgeotiff.so.2 (0x0000007f48108000)
libpq.so.5 => /usr/lib/aarch64-linux-gnu/libpq.so.5 (0x0000007f480b6000)
libdapclient.so.6 => /usr/lib/aarch64-linux-gnu/libdapclient.so.6 (0x0000007f48067000)
libdap.so.25 => /usr/lib/aarch64-linux-gnu/libdap.so.25 (0x0000007f47ec7000)
libspatialite.so.7 => /usr/lib/aarch64-linux-gnu/libspatialite.so.7 (0x0000007f479c3000)
libcurl-gnutls.so.4 => /usr/lib/aarch64-linux-gnu/libcurl-gnutls.so.4 (0x0000007f47948000)
libfyba.so.0 => /usr/lib/aarch64-linux-gnu/libfyba.so.0 (0x0000007f478e5000)
libxml2.so.2 => /usr/lib/aarch64-linux-gnu/libxml2.so.2 (0x0000007f47745000)
libmysqlclient.so.20 => /usr/lib/aarch64-linux-gnu/libmysqlclient.so.20 (0x0000007f4738e000)
libselinux.so.1 => /lib/aarch64-linux-gnu/libselinux.so.1 (0x0000007f47359000)
libmount.so.1 => /lib/aarch64-linux-gnu/libmount.so.1 (0x0000007f472fc000)
libharfbuzz.so.0 => /usr/lib/aarch64-linux-gnu/libharfbuzz.so.0 (0x0000007f4725c000)
libthai.so.0 => /usr/lib/aarch64-linux-gnu/libthai.so.0 (0x0000007f47244000)
libwind.so.0 => /usr/lib/aarch64-linux-gnu/libwind.so.0 (0x0000007f4720a000)
libheimbase.so.1 => /usr/lib/aarch64-linux-gnu/libheimbase.so.1 (0x0000007f471ed000)
libhx509.so.5 => /usr/lib/aarch64-linux-gnu/libhx509.so.5 (0x0000007f4719b000)
libsqlite3.so.0 => /usr/lib/aarch64-linux-gnu/libsqlite3.so.0 (0x0000007f470a0000)
libcrypt.so.1 => /lib/aarch64-linux-gnu/libcrypt.so.1 (0x0000007f4705a000)
libblas.so.3 => /usr/lib/aarch64-linux-gnu/libblas.so.3 (0x0000007f46ff8000)
liblapack.so.3 => /usr/lib/aarch64-linux-gnu/liblapack.so.3 (0x0000007f46b0b000)
libarpack.so.2 => /usr/lib/aarch64-linux-gnu/libarpack.so.2 (0x0000007f46abb000)
libsuperlu.so.5 => /usr/lib/aarch64-linux-gnu/libsuperlu.so.5 (0x0000007f46a53000)
libnss3.so => /usr/lib/aarch64-linux-gnu/libnss3.so (0x0000007f46938000)
libsmime3.so => /usr/lib/aarch64-linux-gnu/libsmime3.so (0x0000007f46901000)
libnspr4.so => /usr/lib/aarch64-linux-gnu/libnspr4.so (0x0000007f468ba000)
liblcms2.so.2 => /usr/lib/aarch64-linux-gnu/liblcms2.so.2 (0x0000007f46860000)
libgeos-3.6.2.so => /usr/lib/aarch64-linux-gnu/libgeos-3.6.2.so (0x0000007f466b5000)
libltdl.so.7 => /usr/lib/aarch64-linux-gnu/libltdl.so.7 (0x0000007f4669c000)
libminizip.so.1 => /usr/lib/aarch64-linux-gnu/libminizip.so.1 (0x0000007f46682000)
liburiparser.so.1 => /usr/lib/aarch64-linux-gnu/liburiparser.so.1 (0x0000007f4665b000)
libicuuc.so.60 => /usr/lib/aarch64-linux-gnu/libicuuc.so.60 (0x0000007f46487000)
libhdf5_serial_hl.so.100 => /usr/lib/aarch64-linux-gnu/libhdf5_serial_hl.so.100 (0x0000007f46457000)
libsz.so.2 => /usr/lib/aarch64-linux-gnu/libsz.so.2 (0x0000007f46444000)
libfyut.so.0 => /usr/lib/aarch64-linux-gnu/libfyut.so.0 (0x0000007f46428000)
libfygm.so.0 => /usr/lib/aarch64-linux-gnu/libfygm.so.0 (0x0000007f46412000)
libblkid.so.1 => /lib/aarch64-linux-gnu/libblkid.so.1 (0x0000007f463bd000)
libgraphite2.so.3 => /usr/lib/aarch64-linux-gnu/libgraphite2.so.3 (0x0000007f4638c000)
libdatrie.so.1 => /usr/lib/aarch64-linux-gnu/libdatrie.so.1 (0x0000007f46376000)
libgfortran.so.4 => /usr/lib/aarch64-linux-gnu/libgfortran.so.4 (0x0000007f46271000)
libnssutil3.so => /usr/lib/aarch64-linux-gnu/libnssutil3.so (0x0000007f46235000)
libplc4.so => /usr/lib/aarch64-linux-gnu/libplc4.so (0x0000007f46220000)
libplds4.so => /usr/lib/aarch64-linux-gnu/libplds4.so (0x0000007f4620c000)
libicudata.so.60 => /usr/lib/aarch64-linux-gnu/libicudata.so.60 (0x0000007f44853000)
libaec.so.0 => /usr/lib/aarch64-linux-gnu/libaec.so.0 (0x0000007f4483a000)
By running
ldconfig
I have a trouble:
root@Sayna122:/home/nano/Documents/Projects/Velocity/builds/Debug# ldconfig
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libnvcaffe_parser.so.5.1.6 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libnvparsers.so.5.1.6 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libnvparsers.so.5 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libnvonnxparser.so.0.1.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libcudnn.so.7 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libnvidia-eglcore.so.32.2.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libnvonnxparser.so.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libnvidia-glcore.so.32.2.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libnvidia-ptxjitcompiler.so.32.2.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libnvidia-tls.so.32.2.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libcudnn.so.7.5.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libnvidia-fatbinaryloader.so.32.2.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libnvonnxparser_runtime.so.0.1.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libnvidia-glsi.so.32.2.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libnvcaffe_parser.so.5 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvidia-glvkspirv.so.32.2.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvidia-eglcore.so.32.2.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvidia-glcore.so.32.2.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvidia-ptxjitcompiler.so.32.2.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvidia-tls.so.32.2.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.2.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvidia-rmapi-tegra.so.32.2.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvidia-glsi.so.32.2.0 is empty, not checked.
Comment 1:
It’s necessary to say that I created docker image via
save
command and load it via,
load
Comment 2: Trouble in run docker container directly.
I tried to transfer docker container(directly) from Jetpack 4.2.1 to Jetpack 4.4:
create docker container via
export
command and import it via,
cat exampleimage.tar | docker import - rl_s:latest
create a new container by :
docker start dockerimage_id
docker exec -it container_id bash
now by running my program:
./Velocity: error while loading shared libraries: /usr/lib/aarch64-linux-gnu/libcudnn.so.7: file too short
also by checking ldd dependencies:
ldd Velocity
by checking ldconfig inorder to for loading libraries:
ldconfig
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libGLESv2_nvidia.so.2 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libcuda.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libcuda.so.1 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libnvidia-ptxjitcompiler.so.1 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libcuda.so.1.1 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libgstnvivameta.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libv4l2.so.0.0.999999 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libv4l2.so.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libv4lconvert.so.0.0.999999 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libgstnvexifmeta.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libGLX_nvidia.so.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libnvonnxparser_runtime.so.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libv4lconvert.so.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libgstnvegl-1.0.so.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libGLESv1_CM_nvidia.so.1 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libEGL_nvidia.so.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libnvsample_cudaprocess.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvmm_contentpipe.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvddk_vic.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvbuf_fdmap.so.1.0.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvodm_imager.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvcamerautils.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvgov_gpucompute.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvv4lconvert.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvbuf_utils.so.1.0.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libcuda.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvmm_utils.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnveglstreamproducer.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvv4l2.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvgov_graphics.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvparser.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libv4l2_nvvidconv.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvphs.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvcameratools.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvmmlite_utils.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvll.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvjpeg.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvcolorutil.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvargus.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvtvmr.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvidia-ptxjitcompiler.so.1 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvvulkan-producer.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvtracebuf.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvrm_graphics.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvgov_generic.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnveglstream_camconsumer.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnveventlib.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvscf.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libsensors.hal-client.nvs.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libv4l2.so.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvargus_socketserver.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvomxilclient.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvmm.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvgov_ui.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvos.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvdsbufferpool.so.1.0.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvgov_camera.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvomx.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libtegrav4l2.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libGLX_nvidia.so.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvrm_gpu.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvrm.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libGLX_indirect.so.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvmedia.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvtnr.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libv4lconvert.so.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvgov_spincircle.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvexif.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvcamlog.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvosd.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvavp.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvphsd.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvtestresults.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvmmlite_image.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvimp.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libdrm.so.2 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvidia-egl-wayland.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvgov_tbc.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libv4l2_nvvideocodec.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvfnetstorehdfx.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvfnetstoredefog.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvwinsys.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvdc.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvmmlite.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvofsdk.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvfnet.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurface.so.1.0.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvidia-egl-wayland.so.1 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvcam_imageencoder.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvddk_2d_v2.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvmmlite_video.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libsensors_hal.nvs.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvcamv4l2.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvapputil.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvgov_boot.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvmm_parser.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvgov_il.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvid_mapper.so.1.0.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvgov_force.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libsensors.l4t.no_fusion.nvs.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvargus_socketclient.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurftransform.so.1.0.0 is empty, not checked.
/sbin/ldconfig.real: /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurftransform.so.1.0.0 is not a symbolic link
/sbin/ldconfig.real: /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurface.so.1.0.0 is not a symbolic link
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra-egl/libGLESv2_nvidia.so.2 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra-egl/libGLESv1_CM_nvidia.so.1 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra-egl/libEGL_nvidia.so.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/libvisionworks_sfm.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/libvisionworks_tracking.so.0.88.2 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/libvisionworks.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/libvisionworks_sfm.so.0.90.4 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/libvisionworks_sfm.so.0.90 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/libvisionworks_tracking.so is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/libvisionworks_tracking.so.0.88 is empty, not checked.
what I see here is conflict between different version of cudnn,cuda,tensort for host and docker. Am I right? But docker should be independent of host.
