it says in your current fortran reference guide (pgifortref.pdf from your website, page 35) that “A pointer-based variable […] may not appear in a NAMELIST”
and indeed when I try with pgfortran (our latest version on site, 14.4), I get the
following error : S108 Illegal variable, $, in NAMELIST group $ which is consistent.
This was the case with older standards, however, my understanding of F03 is that this constraint has been relaxed?
I certainly can’t find a mention of it in the standard, in any case.
Could someone tell me if I’m misunderstanding the standard, or whether this is a bug in 14.4 which has since been corrected?
Thanks,
We believe that you are correct in that this restriction should have be relaxed with the F2003 standard. I’ve added a problem report, TPR#21310, and sent it to engineering for further investigation.
Engineering let me know that we do support pointer variables in a namelist, though the reference guide wasn’t updated. They’ll get that fixed.
Would you mind sending PGI Customer Service (trs@pgroup.com) a reproducing example? We’re not sure if this is a bug with pointers in namelists, or is something else triggering your error.
