We have made a lot of tests, changing only the batch size, the image size and/or learning rate scheduling.
We have tested with a bigger annealing, it’s doesn’t work better.
We think that the problem is not related with the annealing because the NaN loss appears mainly during the 10 first epochs.
One of logs with NaN loss:
To run with multigpu, please change --gpus based on the number of available GPUs in your machine.
Using TensorFlow backend.
2020-05-05 12:58:06,232 [INFO] /usr/local/lib/python2.7/dist-packages/iva/ssd/utils/spec_loader.pyc: Merging specification from /workspace/training/specs/ssd_train_mobilenetv2_kitti.txt
target/truncation is not updated to match the crop areaif the dataset contains target/truncation.
2020-05-05 12:58:08,910 [INFO] iva.ssd.scripts.train: Loading pretrained weights. This may take a while...
__________________________________________________________________________________________________
Layer (type) Output Shape Param # Connected to
Input (InputLayer) (1, 3, 384, 1184) 0
conv1_pad (ZeroPadding2D) (1, 3, 386, 1186) 0 Input[0][0]
conv1 (Conv2D) (1, 32, 192, 592) 864 conv1_pad[0][0]
bn_conv1 (BatchNormalization) (1, 32, 192, 592) 128 conv1[0][0]
re_lu_1 (ReLU) (1, 32, 192, 592) 0 bn_conv1[0][0]
expanded_conv_depthwise_pad (Ze (1, 32, 194, 594) 0 re_lu_1[0][0]
expanded_conv_depthwise (Depthw (1, 32, 192, 592) 288 expanded_conv_depthwise_pad[0][0]
expanded_conv_depthwise_bn (Bat (1, 32, 192, 592) 128 expanded_conv_depthwise[0][0]
expanded_conv_relu (ReLU) (1, 32, 192, 592) 0 expanded_conv_depthwise_bn[0][0]
expanded_conv_project (Conv2D) (1, 16, 192, 592) 512 expanded_conv_relu[0][0]
expanded_conv_project_bn (Batch (1, 16, 192, 592) 64 expanded_conv_project[0][0]
block_1_expand (Conv2D) (1, 96, 192, 592) 1536 expanded_conv_project_bn[0][0]
block_1_expand_bn (BatchNormali (1, 96, 192, 592) 384 block_1_expand[0][0]
re_lu_2 (ReLU) (1, 96, 192, 592) 0 block_1_expand_bn[0][0]
block_1_depthwise_pad (ZeroPadd (1, 96, 194, 594) 0 re_lu_2[0][0]
block_1_depthwise (DepthwiseCon (1, 96, 96, 296) 864 block_1_depthwise_pad[0][0]
block_1_depthwise_bn (BatchNorm (1, 96, 96, 296) 384 block_1_depthwise[0][0]
block_1_relu (ReLU) (1, 96, 96, 296) 0 block_1_depthwise_bn[0][0]
block_1_project (Conv2D) (1, 24, 96, 296) 2304 block_1_relu[0][0]
block_1_project_bn (BatchNormal (1, 24, 96, 296) 96 block_1_project[0][0]
block_2_expand (Conv2D) (1, 144, 96, 296) 3456 block_1_project_bn[0][0]
block_2_expand_bn (BatchNormali (1, 144, 96, 296) 576 block_2_expand[0][0]
re_lu_3 (ReLU) (1, 144, 96, 296) 0 block_2_expand_bn[0][0]
block_2_depthwise_pad (ZeroPadd (1, 144, 98, 298) 0 re_lu_3[0][0]
block_2_depthwise (DepthwiseCon (1, 144, 96, 296) 1296 block_2_depthwise_pad[0][0]
block_2_depthwise_bn (BatchNorm (1, 144, 96, 296) 576 block_2_depthwise[0][0]
block_2_relu (ReLU) (1, 144, 96, 296) 0 block_2_depthwise_bn[0][0]
block_2_project (Conv2D) (1, 24, 96, 296) 3456 block_2_relu[0][0]
block_2_projected_inputs (Conv2 (1, 24, 96, 296) 576 block_1_project_bn[0][0]
block_2_project_bn (BatchNormal (1, 24, 96, 296) 96 block_2_project[0][0]
block_2_add (Add) (1, 24, 96, 296) 0 block_2_projected_inputs[0][0]
block_2_project_bn[0][0]
block_3_expand (Conv2D) (1, 144, 96, 296) 3456 block_2_add[0][0]
block_3_expand_bn (BatchNormali (1, 144, 96, 296) 576 block_3_expand[0][0]
re_lu_4 (ReLU) (1, 144, 96, 296) 0 block_3_expand_bn[0][0]
block_3_depthwise_pad (ZeroPadd (1, 144, 98, 298) 0 re_lu_4[0][0]
block_3_depthwise (DepthwiseCon (1, 144, 48, 148) 1296 block_3_depthwise_pad[0][0]
block_3_depthwise_bn (BatchNorm (1, 144, 48, 148) 576 block_3_depthwise[0][0]
block_3_relu (ReLU) (1, 144, 48, 148) 0 block_3_depthwise_bn[0][0]
block_3_project (Conv2D) (1, 32, 48, 148) 4608 block_3_relu[0][0]
block_3_project_bn (BatchNormal (1, 32, 48, 148) 128 block_3_project[0][0]
block_4_expand (Conv2D) (1, 192, 48, 148) 6144 block_3_project_bn[0][0]
block_4_expand_bn (BatchNormali (1, 192, 48, 148) 768 block_4_expand[0][0]
re_lu_5 (ReLU) (1, 192, 48, 148) 0 block_4_expand_bn[0][0]
block_4_depthwise_pad (ZeroPadd (1, 192, 50, 150) 0 re_lu_5[0][0]
block_4_depthwise (DepthwiseCon (1, 192, 48, 148) 1728 block_4_depthwise_pad[0][0]
block_4_depthwise_bn (BatchNorm (1, 192, 48, 148) 768 block_4_depthwise[0][0]
block_4_relu (ReLU) (1, 192, 48, 148) 0 block_4_depthwise_bn[0][0]
block_4_project (Conv2D) (1, 32, 48, 148) 6144 block_4_relu[0][0]
block_4_projected_inputs (Conv2 (1, 32, 48, 148) 1024 block_3_project_bn[0][0]
block_4_project_bn (BatchNormal (1, 32, 48, 148) 128 block_4_project[0][0]
block_4_add (Add) (1, 32, 48, 148) 0 block_4_projected_inputs[0][0]
block_4_project_bn[0][0]
block_5_expand (Conv2D) (1, 192, 48, 148) 6144 block_4_add[0][0]
block_5_expand_bn (BatchNormali (1, 192, 48, 148) 768 block_5_expand[0][0]
re_lu_6 (ReLU) (1, 192, 48, 148) 0 block_5_expand_bn[0][0]
block_5_depthwise_pad (ZeroPadd (1, 192, 50, 150) 0 re_lu_6[0][0]
block_5_depthwise (DepthwiseCon (1, 192, 48, 148) 1728 block_5_depthwise_pad[0][0]
block_5_depthwise_bn (BatchNorm (1, 192, 48, 148) 768 block_5_depthwise[0][0]
block_5_relu (ReLU) (1, 192, 48, 148) 0 block_5_depthwise_bn[0][0]
block_5_project (Conv2D) (1, 32, 48, 148) 6144 block_5_relu[0][0]
block_5_projected_inputs (Conv2 (1, 32, 48, 148) 1024 block_4_add[0][0]
block_5_project_bn (BatchNormal (1, 32, 48, 148) 128 block_5_project[0][0]
block_5_add (Add) (1, 32, 48, 148) 0 block_5_projected_inputs[0][0]
block_5_project_bn[0][0]
block_6_expand (Conv2D) (1, 192, 48, 148) 6144 block_5_add[0][0]
block_6_expand_bn (BatchNormali (1, 192, 48, 148) 768 block_6_expand[0][0]
re_lu_7 (ReLU) (1, 192, 48, 148) 0 block_6_expand_bn[0][0]
block_6_depthwise_pad (ZeroPadd (1, 192, 50, 150) 0 re_lu_7[0][0]
block_6_depthwise (DepthwiseCon (1, 192, 24, 74) 1728 block_6_depthwise_pad[0][0]
block_6_depthwise_bn (BatchNorm (1, 192, 24, 74) 768 block_6_depthwise[0][0]
block_6_relu (ReLU) (1, 192, 24, 74) 0 block_6_depthwise_bn[0][0]
block_6_project (Conv2D) (1, 64, 24, 74) 12288 block_6_relu[0][0]
block_6_project_bn (BatchNormal (1, 64, 24, 74) 256 block_6_project[0][0]
block_7_expand (Conv2D) (1, 384, 24, 74) 24576 block_6_project_bn[0][0]
block_7_expand_bn (BatchNormali (1, 384, 24, 74) 1536 block_7_expand[0][0]
re_lu_8 (ReLU) (1, 384, 24, 74) 0 block_7_expand_bn[0][0]
block_7_depthwise_pad (ZeroPadd (1, 384, 26, 76) 0 re_lu_8[0][0]
block_7_depthwise (DepthwiseCon (1, 384, 24, 74) 3456 block_7_depthwise_pad[0][0]
block_7_depthwise_bn (BatchNorm (1, 384, 24, 74) 1536 block_7_depthwise[0][0]
block_7_relu (ReLU) (1, 384, 24, 74) 0 block_7_depthwise_bn[0][0]
block_7_project (Conv2D) (1, 64, 24, 74) 24576 block_7_relu[0][0]
block_7_projected_inputs (Conv2 (1, 64, 24, 74) 4096 block_6_project_bn[0][0]
block_7_project_bn (BatchNormal (1, 64, 24, 74) 256 block_7_project[0][0]
block_7_add (Add) (1, 64, 24, 74) 0 block_7_projected_inputs[0][0]
block_7_project_bn[0][0]
block_8_expand (Conv2D) (1, 384, 24, 74) 24576 block_7_add[0][0]
block_8_expand_bn (BatchNormali (1, 384, 24, 74) 1536 block_8_expand[0][0]
re_lu_9 (ReLU) (1, 384, 24, 74) 0 block_8_expand_bn[0][0]
block_8_depthwise_pad (ZeroPadd (1, 384, 26, 76) 0 re_lu_9[0][0]
block_8_depthwise (DepthwiseCon (1, 384, 24, 74) 3456 block_8_depthwise_pad[0][0]
block_8_depthwise_bn (BatchNorm (1, 384, 24, 74) 1536 block_8_depthwise[0][0]
block_8_relu (ReLU) (1, 384, 24, 74) 0 block_8_depthwise_bn[0][0]
block_8_project (Conv2D) (1, 64, 24, 74) 24576 block_8_relu[0][0]
block_8_projected_inputs (Conv2 (1, 64, 24, 74) 4096 block_7_add[0][0]
block_8_project_bn (BatchNormal (1, 64, 24, 74) 256 block_8_project[0][0]
block_8_add (Add) (1, 64, 24, 74) 0 block_8_projected_inputs[0][0]
block_8_project_bn[0][0]
block_9_expand (Conv2D) (1, 384, 24, 74) 24576 block_8_add[0][0]
block_9_expand_bn (BatchNormali (1, 384, 24, 74) 1536 block_9_expand[0][0]
re_lu_10 (ReLU) (1, 384, 24, 74) 0 block_9_expand_bn[0][0]
block_9_depthwise_pad (ZeroPadd (1, 384, 26, 76) 0 re_lu_10[0][0]
block_9_depthwise (DepthwiseCon (1, 384, 24, 74) 3456 block_9_depthwise_pad[0][0]
block_9_depthwise_bn (BatchNorm (1, 384, 24, 74) 1536 block_9_depthwise[0][0]
block_9_relu (ReLU) (1, 384, 24, 74) 0 block_9_depthwise_bn[0][0]
block_9_project (Conv2D) (1, 64, 24, 74) 24576 block_9_relu[0][0]
block_9_projected_inputs (Conv2 (1, 64, 24, 74) 4096 block_8_add[0][0]
block_9_project_bn (BatchNormal (1, 64, 24, 74) 256 block_9_project[0][0]
block_9_add (Add) (1, 64, 24, 74) 0 block_9_projected_inputs[0][0]
block_9_project_bn[0][0]
block_10_expand (Conv2D) (1, 384, 24, 74) 24576 block_9_add[0][0]
block_10_expand_bn (BatchNormal (1, 384, 24, 74) 1536 block_10_expand[0][0]
re_lu_11 (ReLU) (1, 384, 24, 74) 0 block_10_expand_bn[0][0]
block_10_depthwise_pad (ZeroPad (1, 384, 26, 76) 0 re_lu_11[0][0]
block_10_depthwise (DepthwiseCo (1, 384, 24, 74) 3456 block_10_depthwise_pad[0][0]
block_10_depthwise_bn (BatchNor (1, 384, 24, 74) 1536 block_10_depthwise[0][0]
block_10_relu (ReLU) (1, 384, 24, 74) 0 block_10_depthwise_bn[0][0]
block_10_project (Conv2D) (1, 96, 24, 74) 36864 block_10_relu[0][0]
block_10_project_bn (BatchNorma (1, 96, 24, 74) 384 block_10_project[0][0]
block_11_expand (Conv2D) (1, 576, 24, 74) 55296 block_10_project_bn[0][0]
block_11_expand_bn (BatchNormal (1, 576, 24, 74) 2304 block_11_expand[0][0]
re_lu_12 (ReLU) (1, 576, 24, 74) 0 block_11_expand_bn[0][0]
block_11_depthwise_pad (ZeroPad (1, 576, 26, 76) 0 re_lu_12[0][0]
block_11_depthwise (DepthwiseCo (1, 576, 24, 74) 5184 block_11_depthwise_pad[0][0]
block_11_depthwise_bn (BatchNor (1, 576, 24, 74) 2304 block_11_depthwise[0][0]
block_11_relu (ReLU) (1, 576, 24, 74) 0 block_11_depthwise_bn[0][0]
block_11_project (Conv2D) (1, 96, 24, 74) 55296 block_11_relu[0][0]
block_11_projected_inputs (Conv (1, 96, 24, 74) 9216 block_10_project_bn[0][0]
block_11_project_bn (BatchNorma (1, 96, 24, 74) 384 block_11_project[0][0]
block_11_add (Add) (1, 96, 24, 74) 0 block_11_projected_inputs[0][0]
block_11_project_bn[0][0]
block_12_expand (Conv2D) (1, 576, 24, 74) 55296 block_11_add[0][0]
block_12_expand_bn (BatchNormal (1, 576, 24, 74) 2304 block_12_expand[0][0]
re_lu_13 (ReLU) (1, 576, 24, 74) 0 block_12_expand_bn[0][0]
block_12_depthwise_pad (ZeroPad (1, 576, 26, 76) 0 re_lu_13[0][0]
block_12_depthwise (DepthwiseCo (1, 576, 24, 74) 5184 block_12_depthwise_pad[0][0]
block_12_depthwise_bn (BatchNor (1, 576, 24, 74) 2304 block_12_depthwise[0][0]
block_12_relu (ReLU) (1, 576, 24, 74) 0 block_12_depthwise_bn[0][0]
block_12_project (Conv2D) (1, 96, 24, 74) 55296 block_12_relu[0][0]
block_12_projected_inputs (Conv (1, 96, 24, 74) 9216 block_11_add[0][0]
block_12_project_bn (BatchNorma (1, 96, 24, 74) 384 block_12_project[0][0]
block_12_add (Add) (1, 96, 24, 74) 0 block_12_projected_inputs[0][0]
block_12_project_bn[0][0]
ssd_expand_block_1_conv_0 (Conv (1, 64, 24, 74) 6208 block_12_add[0][0]
ssd_expand_block_1_relu_0 (ReLU (1, 64, 24, 74) 0 ssd_expand_block_1_conv_0[0][0]
ssd_expand_block_1_conv_1 (Conv (1, 128, 12, 37) 73728 ssd_expand_block_1_relu_0[0][0]
ssd_expand_block_1_bn_1 (BatchN (1, 128, 12, 37) 512 ssd_expand_block_1_conv_1[0][0]
ssd_expand_block_1_relu_1 (ReLU (1, 128, 12, 37) 0 ssd_expand_block_1_bn_1[0][0]
ssd_expand_block_2_conv_0 (Conv (1, 64, 12, 37) 8256 ssd_expand_block_1_relu_1[0][0]
ssd_expand_block_2_relu_0 (ReLU (1, 64, 12, 37) 0 ssd_expand_block_2_conv_0[0][0]
ssd_expand_block_2_conv_1 (Conv (1, 128, 6, 19) 73728 ssd_expand_block_2_relu_0[0][0]
ssd_expand_block_2_bn_1 (BatchN (1, 128, 6, 19) 512 ssd_expand_block_2_conv_1[0][0]
ssd_expand_block_2_relu_1 (ReLU (1, 128, 6, 19) 0 ssd_expand_block_2_bn_1[0][0]
ssd_expand_block_3_conv_0 (Conv (1, 64, 6, 19) 8256 ssd_expand_block_2_relu_1[0][0]
ssd_expand_block_3_relu_0 (ReLU (1, 64, 6, 19) 0 ssd_expand_block_3_conv_0[0][0]
ssd_expand_block_3_conv_1 (Conv (1, 128, 3, 10) 73728 ssd_expand_block_3_relu_0[0][0]
ssd_expand_block_3_bn_1 (BatchN (1, 128, 3, 10) 512 ssd_expand_block_3_conv_1[0][0]
ssd_expand_block_3_relu_1 (ReLU (1, 128, 3, 10) 0 ssd_expand_block_3_bn_1[0][0]
ssd_expand_block_4_conv_0 (Conv (1, 64, 3, 10) 8256 ssd_expand_block_3_relu_1[0][0]
ssd_expand_block_4_relu_0 (ReLU (1, 64, 3, 10) 0 ssd_expand_block_4_conv_0[0][0]
ssd_expand_block_4_conv_1 (Conv (1, 128, 2, 5) 73728 ssd_expand_block_4_relu_0[0][0]
ssd_expand_block_4_bn_1 (BatchN (1, 128, 2, 5) 512 ssd_expand_block_4_conv_1[0][0]
ssd_expand_block_4_relu_1 (ReLU (1, 128, 2, 5) 0 ssd_expand_block_4_bn_1[0][0]
ssd_conf_0 (Conv2D) (1, 6, 48, 148) 10374 re_lu_7[0][0]
ssd_conf_1 (Conv2D) (1, 6, 24, 74) 5190 block_12_add[0][0]
ssd_conf_2 (Conv2D) (1, 6, 12, 37) 6918 ssd_expand_block_1_relu_1[0][0]
ssd_conf_3 (Conv2D) (1, 6, 6, 19) 6918 ssd_expand_block_2_relu_1[0][0]
ssd_conf_4 (Conv2D) (1, 6, 3, 10) 6918 ssd_expand_block_3_relu_1[0][0]
ssd_conf_5 (Conv2D) (1, 6, 2, 5) 6918 ssd_expand_block_4_relu_1[0][0]
permute_13 (Permute) (1, 48, 148, 6) 0 ssd_conf_0[0][0]
permute_15 (Permute) (1, 24, 74, 6) 0 ssd_conf_1[0][0]
permute_17 (Permute) (1, 12, 37, 6) 0 ssd_conf_2[0][0]
permute_19 (Permute) (1, 6, 19, 6) 0 ssd_conf_3[0][0]
permute_21 (Permute) (1, 3, 10, 6) 0 ssd_conf_4[0][0]
permute_23 (Permute) (1, 2, 5, 6) 0 ssd_conf_5[0][0]
ssd_loc_0 (Conv2D) (1, 24, 48, 148) 41496 re_lu_7[0][0]
ssd_loc_1 (Conv2D) (1, 24, 24, 74) 20760 block_12_add[0][0]
ssd_loc_2 (Conv2D) (1, 24, 12, 37) 27672 ssd_expand_block_1_relu_1[0][0]
ssd_loc_3 (Conv2D) (1, 24, 6, 19) 27672 ssd_expand_block_2_relu_1[0][0]
ssd_loc_4 (Conv2D) (1, 24, 3, 10) 27672 ssd_expand_block_3_relu_1[0][0]
ssd_loc_5 (Conv2D) (1, 24, 2, 5) 27672 ssd_expand_block_4_relu_1[0][0]
conf_reshape_0 (Reshape) (1, 42624, 1, 1) 0 permute_13[0][0]
conf_reshape_1 (Reshape) (1, 10656, 1, 1) 0 permute_15[0][0]
conf_reshape_2 (Reshape) (1, 2664, 1, 1) 0 permute_17[0][0]
conf_reshape_3 (Reshape) (1, 684, 1, 1) 0 permute_19[0][0]
conf_reshape_4 (Reshape) (1, 180, 1, 1) 0 permute_21[0][0]
conf_reshape_5 (Reshape) (1, 60, 1, 1) 0 permute_23[0][0]
permute_14 (Permute) (1, 48, 148, 24) 0 ssd_loc_0[0][0]
permute_16 (Permute) (1, 24, 74, 24) 0 ssd_loc_1[0][0]
permute_18 (Permute) (1, 12, 37, 24) 0 ssd_loc_2[0][0]
permute_20 (Permute) (1, 6, 19, 24) 0 ssd_loc_3[0][0]
permute_22 (Permute) (1, 3, 10, 24) 0 ssd_loc_4[0][0]
permute_24 (Permute) (1, 2, 5, 24) 0 ssd_loc_5[0][0]
ssd_anchor_0 (AnchorBoxes) (1, 7104, 6, 8) 0 ssd_loc_0[0][0]
ssd_anchor_1 (AnchorBoxes) (1, 1776, 6, 8) 0 ssd_loc_1[0][0]
ssd_anchor_2 (AnchorBoxes) (1, 444, 6, 8) 0 ssd_loc_2[0][0]
ssd_anchor_3 (AnchorBoxes) (1, 114, 6, 8) 0 ssd_loc_3[0][0]
ssd_anchor_4 (AnchorBoxes) (1, 30, 6, 8) 0 ssd_loc_4[0][0]
ssd_anchor_5 (AnchorBoxes) (1, 10, 6, 8) 0 ssd_loc_5[0][0]
mbox_conf (Concatenate) (1, 56868, 1, 1) 0 conf_reshape_0[0][0]
conf_reshape_1[0][0]
conf_reshape_2[0][0]
conf_reshape_3[0][0]
conf_reshape_4[0][0]
conf_reshape_5[0][0]
loc_reshape_0 (Reshape) (1, 42624, 1, 4) 0 permute_14[0][0]
loc_reshape_1 (Reshape) (1, 10656, 1, 4) 0 permute_16[0][0]
loc_reshape_2 (Reshape) (1, 2664, 1, 4) 0 permute_18[0][0]
loc_reshape_3 (Reshape) (1, 684, 1, 4) 0 permute_20[0][0]
loc_reshape_4 (Reshape) (1, 180, 1, 4) 0 permute_22[0][0]
loc_reshape_5 (Reshape) (1, 60, 1, 4) 0 permute_24[0][0]
anchor_reshape_0 (Reshape) (1, 42624, 1, 8) 0 ssd_anchor_0[0][0]
anchor_reshape_1 (Reshape) (1, 10656, 1, 8) 0 ssd_anchor_1[0][0]
anchor_reshape_2 (Reshape) (1, 2664, 1, 8) 0 ssd_anchor_2[0][0]
anchor_reshape_3 (Reshape) (1, 684, 1, 8) 0 ssd_anchor_3[0][0]
anchor_reshape_4 (Reshape) (1, 180, 1, 8) 0 ssd_anchor_4[0][0]
anchor_reshape_5 (Reshape) (1, 60, 1, 8) 0 ssd_anchor_5[0][0]
mbox_conf_sigmoid (Activation) (1, 56868, 1, 1) 0 mbox_conf[0][0]
mbox_loc (Concatenate) (1, 56868, 1, 4) 0 loc_reshape_0[0][0]
loc_reshape_1[0][0]
loc_reshape_2[0][0]
loc_reshape_3[0][0]
loc_reshape_4[0][0]
loc_reshape_5[0][0]
mbox_priorbox (Concatenate) (1, 56868, 1, 8) 0 anchor_reshape_0[0][0]
anchor_reshape_1[0][0]
anchor_reshape_2[0][0]
anchor_reshape_3[0][0]
anchor_reshape_4[0][0]
anchor_reshape_5[0][0]
concatenate_2 (Concatenate) (1, 56868, 1, 13) 0 mbox_conf_sigmoid[0][0]
mbox_loc[0][0]
mbox_priorbox[0][0]
ssd_predictions (Reshape) (1, 56868, 13) 0 concatenate_2[0][0]
Total params: 1,136,116
Trainable params: 1,118,964
Non-trainable params: 17,152
2020-05-05 12:59:49,180 [INFO] iva.ssd.scripts.train: Number of images in the training dataset: 3398
2020-05-05 12:59:49,180 [INFO] iva.ssd.scripts.train: Number of images in the validation dataset: 849
Epoch 1/80
3398/3398 [==============================] - 494s 145ms/step - loss: 10.2165
Epoch 00001: saving model to /workspace/training/exp/experiment_dir_unpruned/weights/ssd_mobilenet_v2_epoch_001.tlt
Epoch 2/80
3398/3398 [==============================] - 486s 143ms/step - loss: 2.1691
Epoch 00002: saving model to /workspace/training/exp/experiment_dir_unpruned/weights/ssd_mobilenet_v2_epoch_002.tlt
Epoch 3/80
3398/3398 [==============================] - 489s 144ms/step - loss: 1.7975
Epoch 00003: saving model to /workspace/training/exp/experiment_dir_unpruned/weights/ssd_mobilenet_v2_epoch_003.tlt
Epoch 4/80
3398/3398 [==============================] - 487s 143ms/step - loss: 1.5132
Epoch 00004: saving model to /workspace/training/exp/experiment_dir_unpruned/weights/ssd_mobilenet_v2_epoch_004.tlt
Epoch 5/80
3398/3398 [==============================] - 490s 144ms/step - loss: 1.7766
Epoch 00005: saving model to /workspace/training/exp/experiment_dir_unpruned/weights/ssd_mobilenet_v2_epoch_005.tlt
Epoch 6/80
1326/3398 [==========>...................] - ETA: 5:01 - loss: nan Batch 1325: Invalid loss, terminating training
Epoch 00006: saving model to /workspace/training/exp/experiment_dir_unpruned/weights/ssd_mobilenet_v2_epoch_006.tlt
The associated spec file:
random_seed: 42
ssd_config {
aspect_ratios_global: "[1.0, 2.0, 0.5, 3.0, 1.0/3.0]"
scales: "[0.05, 0.1, 0.25, 0.4, 0.55, 0.7, 0.85]"
two_boxes_for_ar1: true
clip_boxes: false
loss_loc_weight: 0.8
focal_loss_alpha: 0.25
focal_loss_gamma: 2.0
variances: "[0.1, 0.1, 0.2, 0.2]"
arch: "mobilenet_v2"
freeze_bn: false
training_config {
batch_size_per_gpu: 1
num_epochs: 80
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 5e-5
max_learning_rate: 2e-2
soft_start: 0.15
annealing: 0.5
regularizer {
type: L1
weight: 3e-06
eval_config {
validation_period_during_training: 10
average_precision_mode: SAMPLE
batch_size: 1
matching_iou_threshold: 0.5
nms_config {
confidence_threshold: 0.01
clustering_iou_threshold: 0.6
top_k: 200
augmentation_config {
preprocessing {
output_image_width: 1184
output_image_height: 384
output_image_channel: 3
crop_right: 1184
crop_bottom: 384
min_bbox_width: 1.0
min_bbox_height: 1.0
spatial_augmentation {
hflip_probability: 0.5
vflip_probability: 0.0
zoom_min: 0.7
zoom_max: 1.8
translate_max_x: 8.0
translate_max_y: 8.0
color_augmentation {
hue_rotation_max: 25.0
saturation_shift_max: 0.20000000298
contrast_scale_max: 0.10000000149
contrast_center: 0.5
dataset_config {
data_sources: {
tfrecords_path: "/workspace/training/data/tfrecords//kitti_trainval*"
image_directory_path: "/workspace/training/data/train"
image_extension: "png"
target_class_mapping {
key: "myclass"
value: "myclass"
validation_fold: 0
