Unable to train SSD-Resnet-34
I am trying to train a SSD model with resnet-34 backbone
Here is the training spec file:
random_seed: 42
ssd_config {
  aspect_ratios_global: "[1.0, 2.0, 0.5, 3.0, 1.0/3.0]"
  scales: "[0.05, 0.1, 0.25, 0.4, 0.55, 0.7, 0.85]"
  two_boxes_for_ar1: true
  clip_boxes: false
  loss_loc_weight: 0.8
  focal_loss_alpha: 0.25
  focal_loss_gamma: 2.0
  variances: "[0.1, 0.1, 0.2, 0.2]"
  arch: "resnet"
  nlayers: 34
  freeze_bn: false
training_config {
  batch_size_per_gpu: 32
  num_epochs: 120
  learning_rate {
  soft_start_annealing_schedule {
    min_learning_rate: 5e-5
    max_learning_rate: 2e-2
    soft_start: 0.15
    annealing: 0.5
  regularizer {
    type: L1
    weight: 3e-06
eval_config {
  validation_period_during_training: 10
  average_precision_mode: SAMPLE
  batch_size: 32
  matching_iou_threshold: 0.5
nms_config {
  confidence_threshold: 0.01
  clustering_iou_threshold: 0.6
  top_k: 200
augmentation_config {
  preprocessing {
    output_image_width: 1280
    output_image_height: 720
    output_image_channel: 3
    crop_right: 1280
    crop_bottom: 720
    min_bbox_width: 1.0
    min_bbox_height: 1.0
  spatial_augmentation {
    hflip_probability: 0.5
    vflip_probability: 0.0
    zoom_min: 0.7
    zoom_max: 1.8
    translate_max_x: 8.0
    translate_max_y: 8.0
  color_augmentation {
    hue_rotation_max: 25.0
    saturation_shift_max: 0.20000000298
    contrast_scale_max: 0.10000000149
    contrast_center: 0.5
dataset_config {
  data_sources: {
    tfrecords_path: "/nitin/tlt-workspace/face_person_ssd/tf_records/*"
    image_directory_path: "/nitin/tlt-workspace/face_person_ssd/dataset"
  image_extension: "jpg"
  target_class_mapping {
      key: "face"
      value: "face"
      key: "person"
      value: "person"
validation_fold: 0
pretrained weight used:
nvidia/tlt_pretrained_object_detection:resnet34
Error:
Using TensorFlow backend.
2020-05-21 08:44:34,158 [INFO] /usr/local/lib/python2.7/dist-packages/iva/ssd/utils/spec_loader.pyc: Merging specification from specs/train.txt
target/truncation is not updated to match the crop areaif the dataset contains target/truncation.
2020-05-21 08:45:18,799 [INFO] iva.ssd.scripts.train: Loading pretrained weights. This may take a while...
__________________________________________________________________________________________________
Layer (type)                    Output Shape         Param #     Connected to
Input (InputLayer)              (32, 3, 720, 1280)   0
conv1 (Conv2D)                  (32, 64, 360, 640)   9408        Input[0][0]
bn_conv1 (BatchNormalization)   (32, 64, 360, 640)   256         conv1[0][0]
activation_2 (Activation)       (32, 64, 360, 640)   0           bn_conv1[0][0]
block_1a_conv_1 (Conv2D)        (32, 64, 180, 320)   36864       activation_2[0][0]
block_1a_bn_1 (BatchNormalizati (32, 64, 180, 320)   256         block_1a_conv_1[0][0]
block_1a_relu_1 (Activation)    (32, 64, 180, 320)   0           block_1a_bn_1[0][0]
block_1a_conv_2 (Conv2D)        (32, 64, 180, 320)   36864       block_1a_relu_1[0][0]
block_1a_conv_shortcut (Conv2D) (32, 64, 180, 320)   4096        activation_2[0][0]
block_1a_bn_2 (BatchNormalizati (32, 64, 180, 320)   256         block_1a_conv_2[0][0]
block_1a_bn_shortcut (BatchNorm (32, 64, 180, 320)   256         block_1a_conv_shortcut[0][0]
add_17 (Add)                    (32, 64, 180, 320)   0           block_1a_bn_2[0][0]
        block_1a_bn_shortcut[0][0]
block_1a_relu (Activation)      (32, 64, 180, 320)   0           add_17[0][0]
block_1b_conv_1 (Conv2D)        (32, 64, 180, 320)   36864       block_1a_relu[0][0]
block_1b_bn_1 (BatchNormalizati (32, 64, 180, 320)   256         block_1b_conv_1[0][0]
block_1b_relu_1 (Activation)    (32, 64, 180, 320)   0           block_1b_bn_1[0][0]
block_1b_conv_2 (Conv2D)        (32, 64, 180, 320)   36864       block_1b_relu_1[0][0]
block_1b_conv_shortcut (Conv2D) (32, 64, 180, 320)   4096        block_1a_relu[0][0]
block_1b_bn_2 (BatchNormalizati (32, 64, 180, 320)   256         block_1b_conv_2[0][0]
block_1b_bn_shortcut (BatchNorm (32, 64, 180, 320)   256         block_1b_conv_shortcut[0][0]
add_18 (Add)                    (32, 64, 180, 320)   0           block_1b_bn_2[0][0]
        block_1b_bn_shortcut[0][0]
block_1b_relu (Activation)      (32, 64, 180, 320)   0           add_18[0][0]
block_1c_conv_1 (Conv2D)        (32, 64, 180, 320)   36864       block_1b_relu[0][0]
block_1c_bn_1 (BatchNormalizati (32, 64, 180, 320)   256         block_1c_conv_1[0][0]
block_1c_relu_1 (Activation)    (32, 64, 180, 320)   0           block_1c_bn_1[0][0]
block_1c_conv_2 (Conv2D)        (32, 64, 180, 320)   36864       block_1c_relu_1[0][0]
block_1c_conv_shortcut (Conv2D) (32, 64, 180, 320)   4096        block_1b_relu[0][0]
block_1c_bn_2 (BatchNormalizati (32, 64, 180, 320)   256         block_1c_conv_2[0][0]
block_1c_bn_shortcut (BatchNorm (32, 64, 180, 320)   256         block_1c_conv_shortcut[0][0]
add_19 (Add)                    (32, 64, 180, 320)   0           block_1c_bn_2[0][0]
        block_1c_bn_shortcut[0][0]
block_1c_relu (Activation)      (32, 64, 180, 320)   0           add_19[0][0]
block_2a_conv_1 (Conv2D)        (32, 128, 90, 160)   73728       block_1c_relu[0][0]
block_2a_bn_1 (BatchNormalizati (32, 128, 90, 160)   512         block_2a_conv_1[0][0]
block_2a_relu_1 (Activation)    (32, 128, 90, 160)   0           block_2a_bn_1[0][0]
block_2a_conv_2 (Conv2D)        (32, 128, 90, 160)   147456      block_2a_relu_1[0][0]
block_2a_conv_shortcut (Conv2D) (32, 128, 90, 160)   8192        block_1c_relu[0][0]
block_2a_bn_2 (BatchNormalizati (32, 128, 90, 160)   512         block_2a_conv_2[0][0]
block_2a_bn_shortcut (BatchNorm (32, 128, 90, 160)   512         block_2a_conv_shortcut[0][0]
add_20 (Add)                    (32, 128, 90, 160)   0           block_2a_bn_2[0][0]
        block_2a_bn_shortcut[0][0]
block_2a_relu (Activation)      (32, 128, 90, 160)   0           add_20[0][0]
block_2b_conv_1 (Conv2D)        (32, 128, 90, 160)   147456      block_2a_relu[0][0]
block_2b_bn_1 (BatchNormalizati (32, 128, 90, 160)   512         block_2b_conv_1[0][0]
block_2b_relu_1 (Activation)    (32, 128, 90, 160)   0           block_2b_bn_1[0][0]
block_2b_conv_2 (Conv2D)        (32, 128, 90, 160)   147456      block_2b_relu_1[0][0]
block_2b_conv_shortcut (Conv2D) (32, 128, 90, 160)   16384       block_2a_relu[0][0]
block_2b_bn_2 (BatchNormalizati (32, 128, 90, 160)   512         block_2b_conv_2[0][0]
block_2b_bn_shortcut (BatchNorm (32, 128, 90, 160)   512         block_2b_conv_shortcut[0][0]
add_21 (Add)                    (32, 128, 90, 160)   0           block_2b_bn_2[0][0]
        block_2b_bn_shortcut[0][0]
block_2b_relu (Activation)      (32, 128, 90, 160)   0           add_21[0][0]
block_2c_conv_1 (Conv2D)        (32, 128, 90, 160)   147456      block_2b_relu[0][0]
block_2c_bn_1 (BatchNormalizati (32, 128, 90, 160)   512         block_2c_conv_1[0][0]
block_2c_relu_1 (Activation)    (32, 128, 90, 160)   0           block_2c_bn_1[0][0]
block_2c_conv_2 (Conv2D)        (32, 128, 90, 160)   147456      block_2c_relu_1[0][0]
block_2c_conv_shortcut (Conv2D) (32, 128, 90, 160)   16384       block_2b_relu[0][0]
block_2c_bn_2 (BatchNormalizati (32, 128, 90, 160)   512         block_2c_conv_2[0][0]
block_2c_bn_shortcut (BatchNorm (32, 128, 90, 160)   512         block_2c_conv_shortcut[0][0]
add_22 (Add)                    (32, 128, 90, 160)   0           block_2c_bn_2[0][0]
        block_2c_bn_shortcut[0][0]
block_2c_relu (Activation)      (32, 128, 90, 160)   0           add_22[0][0]
block_2d_conv_1 (Conv2D)        (32, 128, 90, 160)   147456      block_2c_relu[0][0]
block_2d_bn_1 (BatchNormalizati (32, 128, 90, 160)   512         block_2d_conv_1[0][0]
block_2d_relu_1 (Activation)    (32, 128, 90, 160)   0           block_2d_bn_1[0][0]
block_2d_conv_2 (Conv2D)        (32, 128, 90, 160)   147456      block_2d_relu_1[0][0]
block_2d_conv_shortcut (Conv2D) (32, 128, 90, 160)   16384       block_2c_relu[0][0]
block_2d_bn_2 (BatchNormalizati (32, 128, 90, 160)   512         block_2d_conv_2[0][0]
block_2d_bn_shortcut (BatchNorm (32, 128, 90, 160)   512         block_2d_conv_shortcut[0][0]
add_23 (Add)                    (32, 128, 90, 160)   0           block_2d_bn_2[0][0]
        block_2d_bn_shortcut[0][0]
block_2d_relu (Activation)      (32, 128, 90, 160)   0           add_23[0][0]
block_3a_conv_1 (Conv2D)        (32, 256, 45, 80)    294912      block_2d_relu[0][0]
block_3a_bn_1 (BatchNormalizati (32, 256, 45, 80)    1024        block_3a_conv_1[0][0]
block_3a_relu_1 (Activation)    (32, 256, 45, 80)    0           block_3a_bn_1[0][0]
block_3a_conv_2 (Conv2D)        (32, 256, 45, 80)    589824      block_3a_relu_1[0][0]
block_3a_conv_shortcut (Conv2D) (32, 256, 45, 80)    32768       block_2d_relu[0][0]
block_3a_bn_2 (BatchNormalizati (32, 256, 45, 80)    1024        block_3a_conv_2[0][0]
block_3a_bn_shortcut (BatchNorm (32, 256, 45, 80)    1024        block_3a_conv_shortcut[0][0]
add_24 (Add)                    (32, 256, 45, 80)    0           block_3a_bn_2[0][0]
        block_3a_bn_shortcut[0][0]
block_3a_relu (Activation)      (32, 256, 45, 80)    0           add_24[0][0]
block_3b_conv_1 (Conv2D)        (32, 256, 45, 80)    589824      block_3a_relu[0][0]
block_3b_bn_1 (BatchNormalizati (32, 256, 45, 80)    1024        block_3b_conv_1[0][0]
block_3b_relu_1 (Activation)    (32, 256, 45, 80)    0           block_3b_bn_1[0][0]
block_3b_conv_2 (Conv2D)        (32, 256, 45, 80)    589824      block_3b_relu_1[0][0]
block_3b_conv_shortcut (Conv2D) (32, 256, 45, 80)    65536       block_3a_relu[0][0]
block_3b_bn_2 (BatchNormalizati (32, 256, 45, 80)    1024        block_3b_conv_2[0][0]
block_3b_bn_shortcut (BatchNorm (32, 256, 45, 80)    1024        block_3b_conv_shortcut[0][0]
add_25 (Add)                    (32, 256, 45, 80)    0           block_3b_bn_2[0][0]
        block_3b_bn_shortcut[0][0]
block_3b_relu (Activation)      (32, 256, 45, 80)    0           add_25[0][0]
block_3c_conv_1 (Conv2D)        (32, 256, 45, 80)    589824      block_3b_relu[0][0]
block_3c_bn_1 (BatchNormalizati (32, 256, 45, 80)    1024        block_3c_conv_1[0][0]
block_3c_relu_1 (Activation)    (32, 256, 45, 80)    0           block_3c_bn_1[0][0]
block_3c_conv_2 (Conv2D)        (32, 256, 45, 80)    589824      block_3c_relu_1[0][0]
block_3c_conv_shortcut (Conv2D) (32, 256, 45, 80)    65536       block_3b_relu[0][0]
block_3c_bn_2 (BatchNormalizati (32, 256, 45, 80)    1024        block_3c_conv_2[0][0]
block_3c_bn_shortcut (BatchNorm (32, 256, 45, 80)    1024        block_3c_conv_shortcut[0][0]
add_26 (Add)                    (32, 256, 45, 80)    0           block_3c_bn_2[0][0]
        block_3c_bn_shortcut[0][0]
block_3c_relu (Activation)      (32, 256, 45, 80)    0           add_26[0][0]
block_3d_conv_1 (Conv2D)        (32, 256, 45, 80)    589824      block_3c_relu[0][0]
block_3d_bn_1 (BatchNormalizati (32, 256, 45, 80)    1024        block_3d_conv_1[0][0]
block_3d_relu_1 (Activation)    (32, 256, 45, 80)    0           block_3d_bn_1[0][0]
block_3d_conv_2 (Conv2D)        (32, 256, 45, 80)    589824      block_3d_relu_1[0][0]
block_3d_conv_shortcut (Conv2D) (32, 256, 45, 80)    65536       block_3c_relu[0][0]
block_3d_bn_2 (BatchNormalizati (32, 256, 45, 80)    1024        block_3d_conv_2[0][0]
block_3d_bn_shortcut (BatchNorm (32, 256, 45, 80)    1024        block_3d_conv_shortcut[0][0]
add_27 (Add)                    (32, 256, 45, 80)    0           block_3d_bn_2[0][0]
        block_3d_bn_shortcut[0][0]
block_3d_relu (Activation)      (32, 256, 45, 80)    0           add_27[0][0]
block_3e_conv_1 (Conv2D)        (32, 256, 45, 80)    589824      block_3d_relu[0][0]
block_3e_bn_1 (BatchNormalizati (32, 256, 45, 80)    1024        block_3e_conv_1[0][0]
block_3e_relu_1 (Activation)    (32, 256, 45, 80)    0           block_3e_bn_1[0][0]
block_3e_conv_2 (Conv2D)        (32, 256, 45, 80)    589824      block_3e_relu_1[0][0]
block_3e_conv_shortcut (Conv2D) (32, 256, 45, 80)    65536       block_3d_relu[0][0]
block_3e_bn_2 (BatchNormalizati (32, 256, 45, 80)    1024        block_3e_conv_2[0][0]
block_3e_bn_shortcut (BatchNorm (32, 256, 45, 80)    1024        block_3e_conv_shortcut[0][0]
add_28 (Add)                    (32, 256, 45, 80)    0           block_3e_bn_2[0][0]
        block_3e_bn_shortcut[0][0]
block_3e_relu (Activation)      (32, 256, 45, 80)    0           add_28[0][0]
block_3f_conv_1 (Conv2D)        (32, 256, 45, 80)    589824      block_3e_relu[0][0]
block_3f_bn_1 (BatchNormalizati (32, 256, 45, 80)    1024        block_3f_conv_1[0][0]
block_3f_relu_1 (Activation)    (32, 256, 45, 80)    0           block_3f_bn_1[0][0]
block_3f_conv_2 (Conv2D)        (32, 256, 45, 80)    589824      block_3f_relu_1[0][0]
block_3f_conv_shortcut (Conv2D) (32, 256, 45, 80)    65536       block_3e_relu[0][0]
block_3f_bn_2 (BatchNormalizati (32, 256, 45, 80)    1024        block_3f_conv_2[0][0]
block_3f_bn_shortcut (BatchNorm (32, 256, 45, 80)    1024        block_3f_conv_shortcut[0][0]
add_29 (Add)                    (32, 256, 45, 80)    0           block_3f_bn_2[0][0]
        block_3f_bn_shortcut[0][0]
block_3f_relu (Activation)      (32, 256, 45, 80)    0           add_29[0][0]
block_4a_conv_1 (Conv2D)        (32, 512, 45, 80)    1179648     block_3f_relu[0][0]
block_4a_bn_1 (BatchNormalizati (32, 512, 45, 80)    2048        block_4a_conv_1[0][0]
block_4a_relu_1 (Activation)    (32, 512, 45, 80)    0           block_4a_bn_1[0][0]
block_4a_conv_2 (Conv2D)        (32, 512, 45, 80)    2359296     block_4a_relu_1[0][0]
block_4a_conv_shortcut (Conv2D) (32, 512, 45, 80)    131072      block_3f_relu[0][0]
block_4a_bn_2 (BatchNormalizati (32, 512, 45, 80)    2048        block_4a_conv_2[0][0]
block_4a_bn_shortcut (BatchNorm (32, 512, 45, 80)    2048        block_4a_conv_shortcut[0][0]
add_30 (Add)                    (32, 512, 45, 80)    0           block_4a_bn_2[0][0]
        block_4a_bn_shortcut[0][0]
block_4a_relu (Activation)      (32, 512, 45, 80)    0           add_30[0][0]
block_4b_conv_1 (Conv2D)        (32, 512, 45, 80)    2359296     block_4a_relu[0][0]
block_4b_bn_1 (BatchNormalizati (32, 512, 45, 80)    2048        block_4b_conv_1[0][0]
block_4b_relu_1 (Activation)    (32, 512, 45, 80)    0           block_4b_bn_1[0][0]
block_4b_conv_2 (Conv2D)        (32, 512, 45, 80)    2359296     block_4b_relu_1[0][0]
block_4b_conv_shortcut (Conv2D) (32, 512, 45, 80)    262144      block_4a_relu[0][0]
block_4b_bn_2 (BatchNormalizati (32, 512, 45, 80)    2048        block_4b_conv_2[0][0]
block_4b_bn_shortcut (BatchNorm (32, 512, 45, 80)    2048        block_4b_conv_shortcut[0][0]
add_31 (Add)                    (32, 512, 45, 80)    0           block_4b_bn_2[0][0]
        block_4b_bn_shortcut[0][0]
block_4b_relu (Activation)      (32, 512, 45, 80)    0           add_31[0][0]
block_4c_conv_1 (Conv2D)        (32, 512, 45, 80)    2359296     block_4b_relu[0][0]
block_4c_bn_1 (BatchNormalizati (32, 512, 45, 80)    2048        block_4c_conv_1[0][0]
block_4c_relu_1 (Activation)    (32, 512, 45, 80)    0           block_4c_bn_1[0][0]
block_4c_conv_2 (Conv2D)        (32, 512, 45, 80)    2359296     block_4c_relu_1[0][0]
block_4c_conv_shortcut (Conv2D) (32, 512, 45, 80)    262144      block_4b_relu[0][0]
block_4c_bn_2 (BatchNormalizati (32, 512, 45, 80)    2048        block_4c_conv_2[0][0]
block_4c_bn_shortcut (BatchNorm (32, 512, 45, 80)    2048        block_4c_conv_shortcut[0][0]
add_32 (Add)                    (32, 512, 45, 80)    0           block_4c_bn_2[0][0]
        block_4c_bn_shortcut[0][0]
block_4c_relu (Activation)      (32, 512, 45, 80)    0           add_32[0][0]
ssd_expand_block_0_conv_0 (Conv (32, 256, 45, 80)    131328      block_4c_relu[0][0]
ssd_expand_block_0_relu_0 (ReLU (32, 256, 45, 80)    0           ssd_expand_block_0_conv_0[0][0]
ssd_expand_block_0_conv_1 (Conv (32, 256, 45, 80)    589824      ssd_expand_block_0_relu_0[0][0]
ssd_expand_block_0_bn_1 (BatchN (32, 256, 45, 80)    1024        ssd_expand_block_0_conv_1[0][0]
ssd_expand_block_0_relu_1 (ReLU (32, 256, 45, 80)    0           ssd_expand_block_0_bn_1[0][0]
ssd_expand_block_1_conv_0 (Conv (32, 128, 45, 80)    32896       ssd_expand_block_0_relu_1[0][0]
ssd_expand_block_1_relu_0 (ReLU (32, 128, 45, 80)    0           ssd_expand_block_1_conv_0[0][0]
ssd_expand_block_1_conv_1 (Conv (32, 256, 23, 40)    294912      ssd_expand_block_1_relu_0[0][0]
ssd_expand_block_1_bn_1 (BatchN (32, 256, 23, 40)    1024        ssd_expand_block_1_conv_1[0][0]
ssd_expand_block_1_relu_1 (ReLU (32, 256, 23, 40)    0           ssd_expand_block_1_bn_1[0][0]
ssd_expand_block_2_conv_0 (Conv (32, 64, 23, 40)     16448       ssd_expand_block_1_relu_1[0][0]
ssd_expand_block_2_relu_0 (ReLU (32, 64, 23, 40)     0           ssd_expand_block_2_conv_0[0][0]
ssd_expand_block_2_conv_1 (Conv (32, 128, 12, 20)    73728       ssd_expand_block_2_relu_0[0][0]
ssd_expand_block_2_bn_1 (BatchN (32, 128, 12, 20)    512         ssd_expand_block_2_conv_1[0][0]
ssd_expand_block_2_relu_1 (ReLU (32, 128, 12, 20)    0           ssd_expand_block_2_bn_1[0][0]
ssd_expand_block_3_conv_0 (Conv (32, 64, 12, 20)     8256        ssd_expand_block_2_relu_1[0][0]
ssd_expand_block_3_relu_0 (ReLU (32, 64, 12, 20)     0           ssd_expand_block_3_conv_0[0][0]
ssd_expand_block_3_conv_1 (Conv (32, 128, 6, 10)     73728       ssd_expand_block_3_relu_0[0][0]
ssd_expand_block_3_bn_1 (BatchN (32, 128, 6, 10)     512         ssd_expand_block_3_conv_1[0][0]
ssd_expand_block_3_relu_1 (ReLU (32, 128, 6, 10)     0           ssd_expand_block_3_bn_1[0][0]
ssd_expand_block_4_conv_0 (Conv (32, 64, 6, 10)      8256        ssd_expand_block_3_relu_1[0][0]
ssd_expand_block_4_relu_0 (ReLU (32, 64, 6, 10)      0           ssd_expand_block_4_conv_0[0][0]
ssd_expand_block_4_conv_1 (Conv (32, 128, 3, 5)      73728       ssd_expand_block_4_relu_0[0][0]
ssd_expand_block_4_bn_1 (BatchN (32, 128, 3, 5)      512         ssd_expand_block_4_conv_1[0][0]
ssd_expand_block_4_relu_1 (ReLU (32, 128, 3, 5)      0           ssd_expand_block_4_bn_1[0][0]
ssd_conf_0 (Conv2D)             (32, 12, 90, 160)    13836       block_2d_relu[0][0]
ssd_conf_1 (Conv2D)             (32, 12, 45, 80)     27660       ssd_expand_block_0_relu_1[0][0]
ssd_conf_2 (Conv2D)             (32, 12, 23, 40)     27660       ssd_expand_block_1_relu_1[0][0]
ssd_conf_3 (Conv2D)             (32, 12, 12, 20)     13836       ssd_expand_block_2_relu_1[0][0]
ssd_conf_4 (Conv2D)             (32, 12, 6, 10)      13836       ssd_expand_block_3_relu_1[0][0]
ssd_conf_5 (Conv2D)             (32, 12, 3, 5)       13836       ssd_expand_block_4_relu_1[0][0]
permute_13 (Permute)            (32, 90, 160, 12)    0           ssd_conf_0[0][0]
permute_15 (Permute)            (32, 45, 80, 12)     0           ssd_conf_1[0][0]
permute_17 (Permute)            (32, 23, 40, 12)     0           ssd_conf_2[0][0]
permute_19 (Permute)            (32, 12, 20, 12)     0           ssd_conf_3[0][0]
permute_21 (Permute)            (32, 6, 10, 12)      0           ssd_conf_4[0][0]
permute_23 (Permute)            (32, 3, 5, 12)       0           ssd_conf_5[0][0]
ssd_loc_0 (Conv2D)              (32, 24, 90, 160)    27672       block_2d_relu[0][0]
ssd_loc_1 (Conv2D)              (32, 24, 45, 80)     55320       ssd_expand_block_0_relu_1[0][0]
ssd_loc_2 (Conv2D)              (32, 24, 23, 40)     55320       ssd_expand_block_1_relu_1[0][0]
ssd_loc_3 (Conv2D)              (32, 24, 12, 20)     27672       ssd_expand_block_2_relu_1[0][0]
ssd_loc_4 (Conv2D)              (32, 24, 6, 10)      27672       ssd_expand_block_3_relu_1[0][0]
ssd_loc_5 (Conv2D)              (32, 24, 3, 5)       27672       ssd_expand_block_4_relu_1[0][0]
conf_reshape_0 (Reshape)        (32, 86400, 1, 2)    0           permute_13[0][0]
conf_reshape_1 (Reshape)        (32, 21600, 1, 2)    0           permute_15[0][0]
conf_reshape_2 (Reshape)        (32, 5520, 1, 2)     0           permute_17[0][0]
conf_reshape_3 (Reshape)        (32, 1440, 1, 2)     0           permute_19[0][0]
conf_reshape_4 (Reshape)        (32, 360, 1, 2)      0           permute_21[0][0]
conf_reshape_5 (Reshape)        (32, 90, 1, 2)       0           permute_23[0][0]
permute_14 (Permute)            (32, 90, 160, 24)    0           ssd_loc_0[0][0]
permute_16 (Permute)            (32, 45, 80, 24)     0           ssd_loc_1[0][0]
permute_18 (Permute)            (32, 23, 40, 24)     0           ssd_loc_2[0][0]
permute_20 (Permute)            (32, 12, 20, 24)     0           ssd_loc_3[0][0]
permute_22 (Permute)            (32, 6, 10, 24)      0           ssd_loc_4[0][0]
permute_24 (Permute)            (32, 3, 5, 24)       0           ssd_loc_5[0][0]
ssd_anchor_0 (AnchorBoxes)      (32, 14400, 6, 8)    0           ssd_loc_0[0][0]
ssd_anchor_1 (AnchorBoxes)      (32, 3600, 6, 8)     0           ssd_loc_1[0][0]
ssd_anchor_2 (AnchorBoxes)      (32, 920, 6, 8)      0           ssd_loc_2[0][0]
ssd_anchor_3 (AnchorBoxes)      (32, 240, 6, 8)      0           ssd_loc_3[0][0]
ssd_anchor_4 (AnchorBoxes)      (32, 60, 6, 8)       0           ssd_loc_4[0][0]
ssd_anchor_5 (AnchorBoxes)      (32, 15, 6, 8)       0           ssd_loc_5[0][0]
mbox_conf (Concatenate)         (32, 115410, 1, 2)   0           conf_reshape_0[0][0]
        conf_reshape_1[0][0]
        conf_reshape_2[0][0]
        conf_reshape_3[0][0]
        conf_reshape_4[0][0]
        conf_reshape_5[0][0]
loc_reshape_0 (Reshape)         (32, 86400, 1, 4)    0           permute_14[0][0]
loc_reshape_1 (Reshape)         (32, 21600, 1, 4)    0           permute_16[0][0]
loc_reshape_2 (Reshape)         (32, 5520, 1, 4)     0           permute_18[0][0]
loc_reshape_3 (Reshape)         (32, 1440, 1, 4)     0           permute_20[0][0]
loc_reshape_4 (Reshape)         (32, 360, 1, 4)      0           permute_22[0][0]
loc_reshape_5 (Reshape)         (32, 90, 1, 4)       0           permute_24[0][0]
anchor_reshape_0 (Reshape)      (32, 86400, 1, 8)    0           ssd_anchor_0[0][0]
anchor_reshape_1 (Reshape)      (32, 21600, 1, 8)    0           ssd_anchor_1[0][0]
anchor_reshape_2 (Reshape)      (32, 5520, 1, 8)     0           ssd_anchor_2[0][0]
anchor_reshape_3 (Reshape)      (32, 1440, 1, 8)     0           ssd_anchor_3[0][0]
anchor_reshape_4 (Reshape)      (32, 360, 1, 8)      0           ssd_anchor_4[0][0]
anchor_reshape_5 (Reshape)      (32, 90, 1, 8)       0           ssd_anchor_5[0][0]
mbox_conf_sigmoid (Activation)  (32, 115410, 1, 2)   0           mbox_conf[0][0]
mbox_loc (Concatenate)          (32, 115410, 1, 4)   0           loc_reshape_0[0][0]
        loc_reshape_1[0][0]
        loc_reshape_2[0][0]
        loc_reshape_3[0][0]
        loc_reshape_4[0][0]
        loc_reshape_5[0][0]
mbox_priorbox (Concatenate)     (32, 115410, 1, 8)   0           anchor_reshape_0[0][0]
        anchor_reshape_1[0][0]
        anchor_reshape_2[0][0]
        anchor_reshape_3[0][0]
        anchor_reshape_4[0][0]
        anchor_reshape_5[0][0]
concatenate_2 (Concatenate)     (32, 115410, 1, 14)  0           mbox_conf_sigmoid[0][0]
        mbox_loc[0][0]
        mbox_priorbox[0][0]
ssd_predictions (Reshape)       (32, 115410, 14)     0           concatenate_2[0][0]
Total params: 23,865,304
Trainable params: 23,840,728
Non-trainable params: 24,576
2020-05-21 08:57:49,560 [INFO] iva.ssd.scripts.train: Number of images in the training dataset:	 18810
2020-05-21 08:57:49,561 [INFO] iva.ssd.scripts.train: Number of images in the validation dataset:	  3062
Epoch 1/120
  File "/usr/local/bin/tlt-train-g1", line 8, in <module>
    sys.exit(main())
  File "./common/magnet_train.py", line 37, in main
  File "./ssd/scripts/train.py", line 245, in main
  File "./ssd/scripts/train.py", line 182, in run_experiment
  File "/usr/local/lib/python2.7/dist-packages/keras/engine/training.py", line 1039, in fit
    validation_steps=validation_steps)
  File "/usr/local/lib/python2.7/dist-packages/keras/engine/training_arrays.py", line 154, in fit_loop
    outs = f(ins)
  File "/usr/local/lib/python2.7/dist-packages/keras/backend/tensorflow_backend.py", line 2715, in __call__
    return self._call(inputs)
  File "/usr/local/lib/python2.7/dist-packages/keras/backend/tensorflow_backend.py", line 2675, in _call
    fetched = self._callable_fn(*array_vals)
  File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/client/session.py", line 1439, in __call__
    run_metadata_ptr)
  File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/framework/errors_impl.py", line 528, in __exit__
    c_api.TF_GetCode(self.status.status))
tensorflow.python.framework.errors_impl.ResourceExhaustedError: OOM when allocating tensor with shape[32,512,45,80] and type float on /job:localhost/replica:0/task:0/device:GPU:0 by allocator GPU_0_bfc
	 [[{{node block_4b_bn_2_1/FusedBatchNorm}}]]
Hint: If you want to see a list of allocated tensors when OOM happens, add report_tensor_allocations_upon_oom to RunOptions for current allocation info.
	 [[{{node loss_1/add_70}}]]
please help, what’s the exact problem.
This is OOM issue. Please consider below.
  1. lower batch-size
    or 2) resize images/labels to lower resolution
    or 3) run with multi-gpus
I tried a lower batch size and also reduced image size
Error:
2020-05-21 09:52:34,733 [INFO] /usr/local/lib/python2.7/dist-packages/iva/ssd/utils/spec_loader.pyc: Merging specification from specs/train.txt
2020-05-21 09:52:34,743 [INFO] /usr/local/lib/python2.7/dist-packages/iva/ssd/utils/spec_loader.pyc: Merging specification from specs/train.txt
2020-05-21 09:52:34,756 [INFO] /usr/local/lib/python2.7/dist-packages/iva/ssd/utils/spec_loader.pyc: Merging specification from specs/train.txt
    sys.exit(main())
  File "./ssd/scripts/train.py", line 95, in run_experiment
  File "./ssd/builders/model_builder.py", line 79, in build
  File "./ssd/builders/inputs_builder.py", line 51, in __init__
  File "./detectnet_v2/dataloader/default_dataloader.py", line 187, in get_dataset_tensors
  File "./detectnet_v2/dataloader/utilities.py", line 138, in get_tfrecords_iterator
  File "./detectnet_v2/dataloader/utilities.py", line 114, in get_num_samples
  File "./detectnet_v2/dataloader/utilities.py", line 113, in <genexpr>
  File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/lib/io/tf_record.py", line 181, in tf_record_iterator
    reader.GetNext()
  File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/pywrap_tensorflow_internal.py", line 489, in GetNext
    return _pywrap_tensorflow_internal.PyRecordReader_GetNext(self)
tensorflow.python.framework.errors_impl.DataLossError: truncated record at 1223947
    sys.exit(main())
    reader.GetNext()
    sys.exit(main())
    reader.GetNext()
2020-05-21 09:52:34,807 [INFO] /usr/local/lib/python2.7/dist-packages/iva/ssd/utils/spec_loader.pyc: Merging specification from specs/train.txt
2020-05-21 09:52:34,811 [INFO] /usr/local/lib/python2.7/dist-packages/iva/ssd/utils/spec_loader.pyc: Merging specification from specs/train.txt
2020-05-21 09:52:34,839 [INFO] /usr/local/lib/python2.7/dist-packages/iva/ssd/utils/spec_loader.pyc: Merging specification from specs/train.txt
    sys.exit(main())
    sys.exit(main())
    reader.GetNext()
tensorflow.python.framework.errors_impl.DataLossError  File "./detectnet_v2/dataloader/utilities.py", line 138, in get_tfrecords_iterator
    reader.GetNext()
    sys.exit(main())
    reader.GetNext()
2020-05-21 09:52:34,852 [INFO] /usr/local/lib/python2.7/dist-packages/iva/ssd/utils/spec_loader.pyc: Merging specification from specs/train.txt
    sys.exit(main())
    reader.GetNext()
    sys.exit(main())
    reader.GetNext()
Primary job  terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun.real detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
  Process name: [[47740,1],7]
  Exit code:    1
For “resize images/labels to lower resolution“,need to write scripts to resize your current images/labels offline, and set the width/height accordingly in the spec.
yes that is already taken care of.
What is your current resolution of training images?
Morgan,
The images are resized to 300x300 @ batch size of 32 on DGX1, with ResNet 34. It frooze, we will try to rerun the experiment and keep you posted.
Thanks Ravik for the info. Please let me know if any issue needs help.
Hi Morgan,
Issue is solved.
