Dear All,
Jetpack-4.6.1( l4t_r32.7.1)
BSP
Extend from this post(Xavier NX)
System reboot when SD CARD insert
We’ve design a Carrier Board for Xavier NX/NANO.
In SD-Card Slot Side, there is the GPIO-7 for Control VDD SD
GPIO08 for SD Card Detect
For the post above for Xavier NX Side. We’re success bring up the SDMMC3 and work well. But there is some trouble in NANO Side, It will shows those message as below
# mount /dev/mmcblk1p1 /media
[ 123.020426] mmcblk1: error -110 sending status command, retrying
[ 123.026923] mmcblk1: error -110 sending status command, retrying
[ 123.033539] mmcblk1: error -110 sending status command, aborting
[ 123.094186] mmc1: CMD CRC or end bit error, int mask 0xc0001
[ 123.101054] mmc1: CMD CRC or end bit error, int mask 0xc0000
[ 123.107804] mmc1: CMD CRC or end bit error, int mask 0xc0001
[ 123.114624] mmc1: CMD CRC or end bit error, int mask 0xc0001
[ 123.121616] mmc1: CMD CRC or end bit error, int mask 0xc0001
[ 123.127938] mmc1: tried to reset card, got error -84
[ 123.133280] blk_update_request: I/O error, dev mmcblk1, sector 60637056
[ 123.142135] mmc1: CMD CRC or end bit error, int mask 0xc0001
[ 123.149021] mmc1: CMD CRC or end bit error, int mask 0xc0001
[ 123.155614] mmcblk1: error -84 sending status command, retrying
[ 123.162394] mmc1: CMD CRC or end bit error, int mask 0xc0001
[ 123.169214] mmcblk1: error -84 sending status command, retrying
[ 123.175918] mmc1: CMD CRC or end bit error, int mask 0xc0001
[ 123.182457] mmcblk1: error -84 sending status command, aborting
[ 123.188917] blk_update_request: I/O error, dev mmcblk1, sector 60637056
[ 123.195913] Buffer I/O error on dev mmcblk1p1, logical block 7578608, async page read
[ 123.209158] mmc1: CMD CRC or end bit error, int mask 0xc0001
[ 123.215983] mmc1: CMD CRC or end bit error, int mask 0xc0001
[ 123.222357] mmcblk1: error -84 sending status command, retrying
[ 123.229194] mmc1: CMD CRC or end bit error, int mask 0xc0001
[ 123.235547] mmcblk1: error -84 sending status command, retrying
[ 123.242498] mmc1: CMD CRC or end bit error, int mask 0xc0001
[ 123.248980] mmcblk1: error -84 sending status command, aborting
[ 123.255356] blk_update_request: I/O error, dev mmcblk1, sector 8194
[ 123.262471] EXT4-fs (mmcblk1p1): unable to read superblock
[ 123.270572] mmc1: CMD CRC or end bit error, int mask 0xc0001
[ 123.277731] mmc1: CMD CRC or end bit error, int mask 0xc0001
[ 123.284075] mmcblk1: error -84 sending status command, retrying
[ 123.290843] mmc1: CMD CRC or end bit error, int mask 0xc0001
[ 123.297235] mmcblk1: error -84 sending status command, retrying
[ 123.303889] mmc1: CMD CRC or end bit error, int mask 0xc0000
[ 123.310282] mmcblk1: error -84 sending status command, aborting
[ 123.316647] blk_update_request: I/O error, dev mmcblk1, sector 8194
[ 123.323921] EXT4-fs (mmcblk1p1): unable to read superblock
[ 123.330710] mmc1: CMD CRC or end bit error, int mask 0xc0000
[ 123.336956] mmc1: CMD CRC or end bit error, int mask 0xc0000
[ 123.342969] mmcblk1: error -84 sending status command, retrying
[ 123.349648] mmc1: CMD CRC or end bit error, int mask 0xc0000
[ 123.355781] mmcblk1: error -84 sending status command, retrying
[ 123.362597] mmc1: CMD CRC or end bit error, int mask 0xc0001
[ 123.369040] mmcblk1: error -84 sending status command, aborting
[ 123.375407] blk_update_request: I/O error, dev mmcblk1, sector 8194
[ 123.382567] EXT4-fs (mmcblk1p1): unable to read superblock
[ 123.389256] mmc1: CMD CRC or end bit error, int mask 0xc0001
[ 123.395614] mmc1: CMD CRC or end bit error, int mask 0xc0000
[ 123.401645] mmcblk1: error -84 sending status command, retrying
[ 123.408059] mmc1: CMD CRC or end bit error, int mask 0xc0000
[ 123.414114] mmcblk1: error -84 sending status command, retrying
[ 123.420933] mmc1: CMD CRC or end bit error, int mask 0xc0001
[ 123.427128] mmcblk1: error -84 sending status command, aborting
[ 123.433542] blk_update_request: I/O error, dev mmcblk1, sector 8192
[ 123.440540] SQUASHFS error: squashfs_read_data failed to read block 0x0
[ 123.447269] squashfs: SQUASHFS error: unable to read squashfs_super_block
mount: /media: can't read superblock on /dev/mmcblk1p1.
There is the log file that include
- NANO Booting info
- device tree info
- pinmux reg
- partitons
- mount
- dmesg
NANO_SDCard_20220901_2027 (95.2 KB)
Xavier NX dts for Reference
tegra194-p3668-all-p3509-0000.dts (230.5 KB)
NANO dts
tegra210-p3448-0002-p3449-0000-b00.dts (293.9 KB)
dts change list
0. Mark GPIOZ,2 be used in other side.
Refer Error -84 whilst initialising SD CARD in Jetson Nano EMMC custom board
--- sources_tegra_l4t_r32.7.1/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-cv-base-p2597-2180-a00.dts 2022-06-20 17:59:50.308038620 +0800
+++ sources/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-cv-base-p2597-2180-a00.dts 2022-09-01 18:33:42.379537408 +0800
- interrupt-parent = <&gpio>;
- interrupts = <TEGRA_GPIO(Z, 2) 0x0>;
+//lanner++Remove GPIOZ,2 in tca9539 for SDCard
+// interrupt-parent = <&gpio>;
+// interrupts = <TEGRA_GPIO(Z, 2) 0x0>;
--- sources_tegra_l4t_r32.7.1/hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-porg-pwm-fan.dtsi 2022-06-20 17:59:52.035956021 +0800
+++ sources/hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-porg-pwm-fan.dtsi 2022-09-01 16:50:19.988826491 +0800
- tach_gpio = <&gpio TEGRA_GPIO(Z, 2) GPIO_ACTIVE_LOW>; /* TEGRA_GPIO_PZ2 */
+//lanner++Remove GPIOZ,2 in pwm for SDCard
+// tach_gpio = <&gpio TEGRA_GPIO(Z, 2) GPIO_ACTIVE_LOW>; /* TEGRA_GPIO_PZ2 */
+//lanner--
- Add Regulator
--- sources_tegra_l4t_r32.7.1/hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-porg-fixed-p3448-0000-a00.dtsi 2022-06-20 17:59:52.031956213 +0800
+++ sources/hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-porg-fixed-p3448-0000-a00.dtsi 2022-08-31 19:46:04.950781106 +0800
+//Refer p3448_vdd_3v3_sd: regulator@3
+ p3448_vdd_3v3_sd3: regulator@11 {
+ compatible = "regulator-fixed-sync";
+// compatible = "regulator-fixed";
+ reg = <11>;
+// regulator-name = "vdd-3v3-sd";
+ regulator-name = "vdd-sdmmc3-sw";
+ regulator-min-microvolt = <3300000>;
+ regulator-max-microvolt = <3300000>;
+ gpio = <&gpio TEGRA_GPIO(V, 0) 1>;
+ enable-active-low;
+ regulator-boot-on;
+ vin-supply = <&p3448_vdd_3v3_sys>;
- Remove vqmmc-supply, adjust vmmc-supply
--- sources_tegra_l4t_r32.7.1/hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-porg-power-tree-p3448-0000-a00.dtsi 2022-06-20 17:59:52.035956021 +0800
+++ sources/hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-porg-power-tree-p3448-0000-a00.dtsi 2022-08-31 20:15:54.313755287 +0800
- vqmmc-supply = <&max77620_sd3>; /* SDMMC3 for 2nd Wifi on loki */
- vmmc-supply = <&p3448_vdd_3v3_sys>; /* SDMMC3 no stuff for full size SD on foster */
+// vqmmc-supply = <&max77620_sd3>; /* SDMMC3 for 2nd Wifi on loki */
+// vmmc-supply = <&p3448_vdd_3v3_sys>; /* SDMMC3 no stuff for full size SD on foster */
+ vmmc-supply = <&p3448_vdd_3v3_sd3>;
- sdhci@700b0400 Tune
--- sources_tegra_l4t_r32.7.1/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-porg-p3448-common.dtsi 2022-06-20 17:59:52.035956021 +0800
+++ sources/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-porg-p3448-common.dtsi 2022-09-01 20:13:43.538323617 +0800
sdhci@700b0400 {
- status = "disabled";
+// status = "disabled";
+ status = "okay";
/delete-property/ keep-power-in-suspend;
/delete-property/ non-removable;
+// dma-coherent;
+ cd-gpios = <&gpio TEGRA_GPIO(Z, 2) 0>;
mmc-ddr-1_8v;
+// mmc-hs200-1_8v;
+// nvidia,cd-wakeup-capable;
mmc-ocr-mask = <3>;
+// mmc-ocr-mask = <0>;
uhs-mask = <0x0>;
+// uhs-mask = <0x8>;
tap-delay = <3>;
--- sources_tegra_l4t_r32.7.1/hardware/nvidia/soc/t210/kernel-dts/tegra210-soc/tegra210-sdhci.dtsi 2022-06-20 17:59:45.788254696 +0800
+++ sources/hardware/nvidia/soc/t210/kernel-dts/tegra210-soc/tegra210-sdhci.dtsi 2022-09-01 19:40:44.728522069 +0800
sdmmc3: sdhci@700b0400 {
- wp-inverted;
+// wp-inverted;
Would you mind help us to check these setting which could add/remove for that??
Best Regards,
MOMO Chen
