Hello Guys
Have a switch Mellanox and need to know if is possible this configuration.
The Datacenter assign a segment of six public IP Address a I need to connect directly to port swp1 and assign a IP public.
- interface swp1
- address 200.200.200.2
- gateway 200.200.200.1
In the switch create vlan 50 in L3 con segment 192.168.50.x/29 and from port swp2 to swp5 and 4 servers were connected and assigned IP of VLAN 50.
Now need to know if is possible create a NAT where permit access to Internet (Specified ports) of the segment 192.168.50.0/29
- interface vlan50
- address 192.168.50.1/29
- vlan-id 50
- vlan-raw-device bridge
In the port I assign in access mode the vlan 50
- interface swp2
- bridge-access 50
- interface swp3
- bridge-access 50
- interface swp3
- bridge-access 50
- interface swp4
- bridge-access 50
I need is to see if with a NAT rule indicate that everything that comes from the 192.168.50.0/24 segment goes through the public IP 200.200.200.1 assigned to port swp1
If possible how should i configure a rule on the switch?
Thanks for your comments.
