It would be possible in hardware, but it is not implemented at the moment. By default frames are not allowed to be forwarded on the same port they were received on.
However, could you explain how you are using this feature? Perhaps there are different solutions with the multiple vlan-aware bridge for example.
I’d like to use a Mellanox SN2010 to terminate a connection to a fibre to the home network - where the fibre network provides about 15 VLANs, one VLAN per geographic area. Ideally I want all the VLANs (and customer MACs) in one bridge where a DHCP server provides them with IPs from a single pool.
I have this working with a linux software router at the moment, but we’d like to change to a hardware solution.
I believe in Arista lingo this feature is called “Layer 2 Subinterfaces”:
“A Layer 2 subinterface is a logical bridging endpoint associated with traffic on an interface distinguished by 802.1Q tags, where each interface, 802.1q tag tuple is treated as a first-class bridging interface.”
If they are 15 different VLANs (in your case for separating geographic areas), wouldn’t you want to start routing at that aggregation point? I have to assume the gateway for all VLANs exist on the 2010. With your suggestion you would be bridging the different VLANs which is typically not such a good idea.
If the sole purpose it to provide DHCP services, you can do that routed with a dhcp relay agent as well.
Thanks, I tested some routing ideas using the Cumulus VX Air lab - seems to work as expected. We’ll look into using dhcp relays and adding /32 routes for each customer.
