Ndivia-smi command failing silently
from yesterday my nvidia-smi command is failing silently, I was building a multimodal vision model when my running device changed to CPU as GPU was not being detected. when I checked my nvidia-smi was failing silently, even though the graphics card was detected, kernel drivers running properly, I was using the latest driver as well. I tried uninstalling the driver and reinstalling the previous version but didn’t yield any result. later I also checked my disk health and other stuff but couldn’t find any issue. later to find this in my event viewer:
The description for Event ID 153 from source nvlddmkm cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
anybody nows how to fix this??
Have you tried power-cycling the system?
