Dear all,
I installed CUDA 4.0 on my XP and vista machine.
I set up Visual++ express 2008.
I started a project.
I wrote a simple program as below.
global void kernel(void) {
int main(void) {
kernel <<1,1>>;
printf(“Hello, world\n”);
return(0);
I failed to build it. I got this message
1>------ Build started: Project: cuda_helloworld, Configuration: Debug Win32 ------
1>Compiling with CUDA Build Rule…
1>“C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v4.0\bin\nvcc.exe” -arch sm_10 -ccbin “c:\Program Files\Microsoft Visual Studio 9.0\VC\bin” -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v4.0\include" -maxrregcount=0 -m32 -cubin -o “C:\Users\hptang\Documents\Visual Studio 2008\Projects\cuda_helloworld\Debug/helloworld.cubin” helloworld.cu
1>helloworld.cu
1>Internal error: assertion failed at: “D:/Bld/rel/gpgpu/toolkit/r4.0/compiler/edg/EDG_4.2/src/host_envir.c”, line 4677
1>1 catastrophic error detected in this compilation.
1>Compilation aborted.
1>This application has requested the Runtime to terminate it in an unusual way.
1>Please contact the application’s support team for more information.
1>Project : error PRJ0019: A tool returned an error code from “Compiling with CUDA Build Rule…”
May you give any suggestion on what is wrong. I try to set MinGW and Eclipse Indigo. I got the same error message. Thanks for your helps in advance.
Regards,
Ken
