Hello, I’m trying to flash my Jetson Orin NX in two parts. First part is to make the files needed to flash and then the second part is to flash using those files. My goal is to flash an Orin NX using ONLY those files generated and delete everything else not needed in Linux_for_Tegra. So far, I’m having trouble.
This is the original command used to flash in one step. This is from Quick Start — Jetson Linux Developer Guide documentation (nvidia.com) . I used it and it works.
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1
-c tools/kernel_flash/flash_l4t_external.xml -p “-c bootloader/t186ref/cfg/flash_t234_qspi.xml”
–showlogs --network usb0 p3509-a02+p3767-0000 internal
These are the commands I use to do it in two parts. It is based on the readme file of the initrd flash script.
export BOARD=p3509-a02+p3767-0000
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" --showlogs --network usb0 --no-flash ${BOARD} internal
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" --showlogs --network usb0 --flash-only ${BOARD} internal
After doing it in two parts, it’s not clear to me where the required files generated are located. Also, I was told from the log from running part 1 to run a txt file that has the flash command and it didn’t work as I get an error.
cat bootloader/flashcmd.txt
./tegraflash.py --bl uefi_jetson_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev --bldtb tegra234-p3767-0000-p3509-a02.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd “rcmboot” --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt --bins “psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt; sce_fw camera-rtcpu-sce_sigheader.img.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot.img; kernel_dtb tegra234-p3767-0000-p3509-a02.dtb” --secondary_gpt_backup --bct_backup
sudo ./tegraflash.py --bl uefi_jetson_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev --bldtb tegra234-p3767-0000-p3509-a02.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd “rcmboot” --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt --bins “psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt; sce_fw camera-rtcpu-sce_sigheader.img.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot.img; kernel_dtb tegra234-p3767-0000-p3509-a02.dtb” --secondary_gpt_backup --bct_backup
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
Entering RCM boot
[ 0.0250 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin
[ 0.0250 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin
[ 0.0250 ] rcm boot with presigned binaries
[ 0.0276 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.0285 ] BR_CID: 0x80012344705E36425C000000030080C0
[ 0.2295 ] Sending bct_br
[ 0.4441 ] Sending mb1
[ 0.4452 ] Sending psc_bl1
[ 0.4552 ] Sending bct_mb1
[ 0.4612 ] Generating blob for T23x
[ 0.4673 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[ 0.4705 ] The number of images in blob is 18
[ 0.4715 ] blobsize is 61498182
[ 0.4716 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 2920512
[ 0.4994 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 375168
[ 0.5000 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 190592
[ 0.5007 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 277312
[ 0.5012 ] Not supported type: mb2_applet
[ 0.5015 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 438768
[ 0.5022 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[ 0.5027 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 9097216
[ 0.5080 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[ 0.5093 ] Added binary blob_bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt of size 1051136
[ 0.5102 ] Added binary blob_tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt of size 258688
[ 0.5110 ] Added binary blob_camera-rtcpu-sce_sigheader.img.encrypt of size 166304
[ 0.5117 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 537952
[ 0.5123 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 400864
[ 0.5128 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[ 0.5133 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1127568
[ 0.5138 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[ 0.5143 ] Added binary blob_boot.img of size 43569152
[ 0.5393 ] Added binary blob_tegra234-p3767-0000-p3509-a02.dtb of size 346502
[ 0.5840 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[ 0.5850 ] BL: version 1.2.0.0-t234-54845784-562369e5 last_boot_error: 0
[ 0.7821 ] Sending bct_mem
[ 0.9922 ] Sending blob
[ 3.5952 ] RCM-boot started
Jetson Orin Serial Line Log from running flash cmd txt file
[ 9.624551] pci 0008:01:00.0: BAR 0: assigned [io 0x200000-0x2000ff]
[ 9.631207] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[ 9.636575] pci 0008:00:00.0: bridge window [io 0x200000-0x200fff]
[ 9.642339] tegra-xusb 3610000.xhci: entering ELPG done
[ 9.643209] pci 0008:00:00.0: bridge window [mem 0x3528000000-0x35280fffff]
[ 9.643223] pci 0008:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 9.664682] pci 0008:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 9.673612] pcieport 0008:00:00.0: Adding to iommu group 10
[ 9.679539] pcieport 0008:00:00.0: PME: Signaling with IRQ 59
[ 9.686217] pcieport 0008:00:00.0: AER: enabled with IRQ 59
[ 9.693417] irq: IRQ304: trimming hierarchy from :pmc@c360000
[ 9.699397] irq: IRQ305: trimming hierarchy from :interrupt-controller@f400000-1
[ 9.707082] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 9.715012] tegra-se-nvhost 15810000.se: Adding to iommu group 50
[ 9.721642] tegra-se-nvhost 15810000.se: initialized
[ 9.737591] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 9.743990] tegra-se-nvhost 15820000.se: Adding to iommu group 51
[ 9.750601] tegra-se-nvhost 15820000.se: initialized
[ 9.758057] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 9.764433] tegra-se-nvhost 15840000.se: Adding to iommu group 52
[ 9.770993] tegra-se-nvhost 15840000.se: initialized
[ 9.780365] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 9.787284] tegra_actmon d230000.actmon: in actmon_register()...
[ 9.793665] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 9.799866] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 9.808287] hvc_sysfs: hypervisor is not present
��WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc1clk
��[ 9.852137] ALSA device list:
[ 9.855203] No soundcards found.
[ 9.859339] Freeing unused kernel memory: 3968K
[ 9.864076] Run /init as init process
[ 9.880452] Root device found: mmcblk0p1
[ 19.995240] ERROR: mmcblk0p1 not found
[ 121.582754] random: crng init done
Any help in resolving this is greatly appreciated. Thank you for your time.
