Need help on H264 encoded 4K@30fps video framerate
Dear experts,
I’m currently porting a HDMI-to-4-lane-CSI bridge driver from Xavier AGX to Xavier NX and trying to do the H264 encoding on the video providing from a 4K camera. But I cannot achieve the maximum frame-rate of the camera (30fps).
The camera node in the dtsi is as following :
	host1x {
		vi@15c10000  {
			num-channels = <2>;
			ports {
				#address-cells = <1>;
				#size-cells = <0>;
				vi_port0: port@0 {
					reg = <0>;
					toto_vi_in0: endpoint {
						port-index = <0>;
						bus-width = <4>;
						remote-endpoint = <&toto_csi_out0>;
				vi_port1: port@1 {
					reg = <1>;
					toto_vi_in1: endpoint {
						port-index = <2>;
						bus-width = <4>;
						remote-endpoint = <&toto_csi_out1>;
		nvcsi@15a00000 {
			num-channels = <2>;
			#size-cells = <0>;
			csi_chan0: channel@0 {
				reg = <0>;
				ports {
					#size-cells = <0>;
					csi_chan0_port0: port@0 {
						reg = <0>;
						toto_csi_in0: endpoint@0 {
							port-index = <0>;
							bus-width = <4>;
							remote-endpoint = <&toto_out0>;
					csi_chan0_port1: port@1 {
						reg = <1>;
						toto_csi_out0: endpoint@1 {
							remote-endpoint = <&toto_vi_in0>;
			csi_chan1: channel@1 {
				reg = <1>;
				ports {
					#size-cells = <0>;
					csi_chan1_port0: port@0 {
						reg = <0>;
						toto_csi_in1: endpoint@2 {
							port-index = <2>;
							bus-width = <4>;
							remote-endpoint = <&toto_out1>;
					csi_chan1_port1: port@1 {
						reg = <1>;
						toto_csi_out1: endpoint@3 {
							remote-endpoint = <&toto_vi_in1>;
	cam_i2cmux {
		i2c_0:i2c@0 {
			toto_a@2b {
				compatible = "nvidia,toto";
				/* I2C device address */
				reg = <0x2b>;
				/* V4L2 device node location */
				devnode = "video0";
				/* Physical dimensions of sensor */
				physical_w = "3.674";
				physical_h = "2.738";
				/* Define any required hw resources needed by driver */
				/* ie. clocks, io pins, power sources */
				avdd-reg = "vana";
				iovdd-reg = "vif";
				dvdd-reg = "vdig";
				/* Sensor output flip settings */
				vertical-flip = "true";
				/* if true, delay gain setting by one frame to be in sync with exposure */
				delayed_gain = "true";
				clocks = <&bpmp_clks TEGRA194_CLK_EXTPERIPH1>,
				 <&bpmp_clks TEGRA194_CLK_PLLP_OUT0>;
				clock-names = "extperiph1", "pllp_grtba";
				/* clock-frequency = <24000000>; */
				status = "okay";
				mclk = "extperiph1";
				/*vana-supply = <&p2822_avdd_cam_2v8>;
				vif-supply = <&p2822_vdd_1v8_cvb>;
				vdig-supply = <&p2822_vdd_1v8_cvb>;*/
				mode0 { // TOTO_MODE_3840X2160
					mclk_khz = "24000";
					num_lanes = "4";
					phy_mode = "DPHY";
					discontinuous_clk = "yes";
					dpcm_enable = "false";
					cil_settletime = "0";
					active_w = "3840";
					active_h = "2160";
					mode_type = "yuv";
					pixel_phase = "uyvy";
					csi_pixel_bit_depth = "16";
					readout_orientation = "0";
					line_length = "3840";
					inherent_gain = "1";
					mclk_multiplier = "24";
					pix_clk_hz = "312500000";
					gain_factor = "1000000";
					min_gain_val = "1000000";
					max_gain_val = "44400000";
					step_gain_val = "1";
					default_gain = "1000000";
					min_hdr_ratio = "1";
					max_hdr_ratio = "1";
					framerate_factor = "1000000";
					min_framerate = "1500000";
					max_framerate = "30000000";
					step_framerate = "1";
					default_framerate= "30000000";
					exposure_factor = "1000000";
					min_exp_time = "44";
					max_exp_time = "478696";
					step_exp_time = "1";
					default_exp_time = "16667";/* us */
					embedded_metadata_height = "0";
				ports {
					#size-cells = <0>;
					port@0 {
						reg = <0>;
						toto_out0: endpoint {
							port-index = <0>;
							bus-width = <4>;
							remote-endpoint = <&toto_csi_in0>;
		i2c_1:i2c@1 {
			toto_c@2b {
				reg = <0x2b>;
				devnode = "video1";
				avdd-reg = "vana";
				iovdd-reg = "vif";
				dvdd-reg = "vdig";
				status = "okay";
					mclk_khz = "24000";
					num_lanes = "4";
					tegra_sinterface = "serial_c";
					phy_mode = "DPHY";
					active_w = "3840";
					active_h = "2160";
					mode_type = "yuv";
				ports {
					#size-cells = <0>;
					port@0 {
						reg = <0>;
						toto_out1: endpoint {
							port-index = <2>;
							bus-width = <4>;
							remote-endpoint = <&toto_csi_in1>;
	tcp: tegra-camera-platform {
		compatible = "nvidia, tegra-camera-platform";
		* Physical settings to calculate max ISO BW
		* num_csi_lanes = <>;
		* Total number of CSI lanes when all cameras are active
		* max_lane_speed = <>;
		* Max lane speed in Kbit/s
		* min_bits_per_pixel = <>;
		* Min bits per pixel
		* vi_peak_byte_per_pixel = <>;
		* Max byte per pixel for the VI ISO case
		* vi_bw_margin_pct = <>;
		* Vi bandwidth margin in percentage
		* max_pixel_rate = <>;
		* Max pixel rate in Kpixel/s for the ISP ISO case
		* isp_peak_byte_per_pixel = <>;
		* Max byte per pixel for the ISP ISO case
		* isp_bw_margin_pct = <>;
		* Isp bandwidth margin in percentage
		num_csi_lanes = <8>;
		max_lane_speed = <2500000>;
		min_bits_per_pixel = <10>;
		vi_peak_byte_per_pixel = <2>;
		vi_bw_margin_pct = <25>;
		max_pixel_rate = <750000>;
		isp_peak_byte_per_pixel = <5>;
		isp_bw_margin_pct = <25>;
		 * The general guideline for naming badge_info contains 3 parts, and is as follows,
		 * The first part is the camera_board_id for the module; if the module is in a FFD
		 * platform, then use the platform name for this part.
		 * The second part contains the position of the module, ex. "rear" or "front".
		 * The third part contains the last 6 characters of a part number which is found
		 * in the module's specsheet from the vendor.
		modules {
			cam_module0: module0 {
				badge = "camera_front_123";
				position = "front";
				orientation = "1";
				cam_module0_drivernode0: drivernode0 {
					pcl_id = "v4l2_sensor";
					devname = "toto 9-002b";
					proc-device-tree = "/proc/device-tree/cam_i2cmux/i2c@0/toto_a@2b";
			cam_module1: module1 {
				badge = "camera_rear_123";
				position = "rear";
				orientation = "1";
				cam_module1_drivernode0: drivernode0 {
					devname = "toto 10-002b";
					proc-device-tree = "/proc/device-tree/cam_i2cmux/i2c@1/toto_c@2b";
I calculated the pix_clk_hz different ways :
Based on sensor CSI lane output rate :
pixel_clk_hz = 2500 Mbps * 4 / 8 = 1250000000 (8-bit-per-pixel)
pixel_clk_hz = 2500 Mbps * 4 / 16 = 625000000 (16-bit-per-pixel)
Based on frame size and frame rate :
pixel_clk_hz = 3840 x 2160 x 30 x 1 = 248832000 (8-bit-per-pixel)
pixel_clk_hz = 3840 x 2160 x 30 x 2 = 497664000 (16-bit-per-pixel)
The command for saving the H264 encoded video :
$ gst-launch-1.0 v4l2src device=/dev/video0 ! videoconvert ! omxh264enc ! h264parse ! qtmux ! filesink location=toto.h264 -e
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
Framerate set to : 30 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
H264: Profile = 66, Level = 40
(NVENC runs @499MHz during the encoding)
The command for decoding the H264 info :
$ gst-discoverer-1.0 toto.h264 -v
Analyzing file:///home/nvidia/toto.h264
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
Done discovering file:///home/nvidia/toto.h264
Topology:
  container: video/quicktime
    video: video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)5.1, profile=(string)constrained-baseline, width=(int)3840, height=(int)2160, framerate=(fraction)100000/13307, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)2:6:0:7, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
      Tags:
        video codec: H.264 / AVC
        maximum bitrate: 34258320
        bitrate: 15566333
        datetime: 2020-11-09T08:32:01Z
        container format: Quicktime
      Codec:
      Additional info:
        None
      Stream ID: 8fdbb59d0bae59b8c625e0f21ceac4b42887b4efa066081575d45c6969026e25/001
      Width: 3840
      Height: 2160
      Depth: 24
      Frame rate: 100000/13307
      Pixel aspect ratio: 1/1
      Interlaced: false
      Bitrate: 15566333
      Max bitrate: 34258320
Properties:
  Duration: 0:01:00.740333333
  Seekable: yes
  Live: no
  Tags:
      bitrate: 15566333
In every case, I got the framerate around 100000/13307 ~ 7.5fps as above
Camera spec :
QFHD: 2160p/29.97, 2160p/25, 2160p/23.98
FHD: 1080p/59.94, 1080p/50, 1080p/29.97 (2-2), 1080p/25 (2-2), 1080i/59.94, 1080i/50,
HD: 720p/59.94, 720p/50, 720p/23.98
SD:480p/59.94, 576p/50
Can anyone help to point out any missing configuration or stuff in order to achieve the maximum fps of the video provided by the camera (30 fps), please ?
Thanks in advance,
K.
Have confirm the output is 30fps by v4l2-ctl first.
Dear @ShaneCCC,
Using v4l2-ctl command gives :
$ v4l2-ctl -d /dev/video0 --set-fmt-video=width=3840,height=2160,pixelformat=UYVY --set-ctrl bypass_mode=0 --stream-mmap --stream-count=500 --stream-to=toto.raw
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 30.00 fps
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 29.97 fps
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 29.98 fps
Then I followed the instruction to break-down the pipeline to check the frame-rate as in this discussion : TX2 h264 encoding, 60 FPS camera, 30 FPS Video Stream. It gives :
~$ gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,width=3840,height=2160,format=UYVY,framerate=30/1 ! fpsdisplaysink video-sink=fakesink -v
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0: sync = true
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = video/x-raw, width=(int)3840, height=(int)2160, format=(string)UYVY, framerate=(fraction)30/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw, width=(int)3840, height=(int)2160, format=(string)UYVY, framerate=(fraction)30/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink.GstProxyPad:proxypad0: caps = video/x-raw, width=(int)3840, height=(int)2160, format=(string)UYVY, framerate=(fraction)30/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay.GstPad:src: caps = video/x-raw(memory:SystemMemory, meta:GstVideoOverlayComposition), width=(int)3840, height=(int)2160, format=(string)UYVY, framerate=(fraction)30/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0.GstPad:sink: caps = video/x-raw(memory:SystemMemory, meta:GstVideoOverlayComposition), width=(int)3840, height=(int)2160, format=(string)UYVY, framerate=(fraction)30/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay.GstPad:src: caps = video/x-raw, width=(int)3840, height=(int)2160, format=(string)UYVY, framerate=(fraction)30/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0.GstPad:sink: caps = video/x-raw, width=(int)3840, height=(int)2160, format=(string)UYVY, framerate=(fraction)30/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay.GstPad:video_sink: caps = video/x-raw, width=(int)3840, height=(int)2160, format=(string)UYVY, framerate=(fraction)30/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink: caps = video/x-raw, width=(int)3840, height=(int)2160, format=(string)UYVY, framerate=(fraction)30/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw, width=(int)3840, height=(int)2160, format=(string)UYVY, framerate=(fraction)30/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 16, dropped: 0, current: 31.99, average: 31.99
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 16, dropped: 0, current: 31.99, average: 31.99
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 29, dropped: 0, current: 25.07, average: 28.47
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 29, dropped: 0, current: 25.07, average: 28.47
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 44, dropped: 0, current: 29.92, average: 28.95
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 44, dropped: 0, current: 29.92, average: 28.95
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 59, dropped: 0, current: 29.99, average: 29.21
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 59, dropped: 0, current: 29.99, average: 29.21
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 74, dropped: 0, current: 29.99, average: 29.36
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 74, dropped: 0, current: 29.99, average: 29.36
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 89, dropped: 0, current: 29.95, average: 29.46
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 89, dropped: 0, current: 29.95, average: 29.46
$ gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,width=3840,height=2160,format=UYVY,framerate=30/1 ! nvvidconv ! ‘video/x-raw(memory:NVMM),format=NV12’ ! fpsdisplaysink video-sink=fakesink -v
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)3840, height=(int)2160, framerate=(fraction)30/1, interlace-mode=(string)progressive, format=(string)NV12
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)3840, height=(int)2160, framerate=(fraction)30/1, interlace-mode=(string)progressive, format=(string)NV12
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink.GstProxyPad:proxypad0: caps = video/x-raw(memory:NVMM), width=(int)3840, height=(int)2160, framerate=(fraction)30/1, interlace-mode=(string)progressive, format=(string)NV12
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay.GstPad:src: caps = video/x-raw(memory:NVMM, meta:GstVideoOverlayComposition), width=(int)3840, height=(int)2160, framerate=(fraction)30/1, interlace-mode=(string)progressive, format=(string)NV12
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0.GstPad:sink: caps = video/x-raw(memory:NVMM, meta:GstVideoOverlayComposition), width=(int)3840, height=(int)2160, framerate=(fraction)30/1, interlace-mode=(string)progressive, format=(string)NV12
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay.GstPad:video_sink: caps = video/x-raw(memory:NVMM), width=(int)3840, height=(int)2160, framerate=(fraction)30/1, interlace-mode=(string)progressive, format=(string)NV12
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink: caps = video/x-raw(memory:NVMM), width=(int)3840, height=(int)2160, framerate=(fraction)30/1, interlace-mode=(string)progressive, format=(string)NV12
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)3840, height=(int)2160, framerate=(fraction)30/1, interlace-mode=(string)progressive, format=(string)NV12
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw, width=(int)3840, height=(int)2160, format=(string)UYVY, framerate=(fraction)30/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 5, dropped: 0, current: 8.75, average: 8.75
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 5, dropped: 0, current: 8.75, average: 8.75
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 9, dropped: 0, current: 6.36, average: 7.50
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 9, dropped: 0, current: 6.36, average: 7.50
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 13, dropped: 0, current: 6.67, average: 7.22
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 13, dropped: 0, current: 6.67, average: 7.22
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 17, dropped: 0, current: 6.72, average: 7.10
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 17, dropped: 0, current: 6.72, average: 7.10
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 21, dropped: 0, current: 6.75, average: 7.03
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 21, dropped: 0, current: 6.75, average: 7.03
$ gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,width=3840,height=2160,format=UYVY,framerate=30/1 ! nvvidconv ! ‘video/x-raw(memory:NVMM),format=NV12’ ! omxh264enc ! fpsdisplaysink video-sink=fakesink -v
/GstPipeline:pipeline0/GstOMXH264Enc-omxh264enc:omxh264enc-omxh264enc0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)3840, height=(int)2160, framerate=(fraction)30/1, interlace-mode=(string)progressive, format=(string)NV12
/GstPipeline:pipeline0/GstOMXH264Enc-omxh264enc:omxh264enc-omxh264enc0.GstPad:src: caps = video/x-h264, alignment=(string)au, profile=(string)baseline, level=(string)4, stream-format=(string)avc, width=(int)3840, height=(int)2160, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, interlace-mode=(string)progressive, colorimetry=(string)bt2020, chroma-site=(string)mpeg2
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink.GstProxyPad:proxypad0: caps = video/x-h264, alignment=(string)au, profile=(string)baseline, level=(string)4, stream-format=(string)avc, width=(int)3840, height=(int)2160, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, interlace-mode=(string)progressive, colorimetry=(string)bt2020, chroma-site=(string)mpeg2
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay.GstPad:src: caps = video/x-h264(memory:SystemMemory, meta:GstVideoOverlayComposition), alignment=(string)au, profile=(string)baseline, level=(string)4, stream-format=(string)avc, width=(int)3840, height=(int)2160, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, interlace-mode=(string)progressive, colorimetry=(string)bt2020, chroma-site=(string)mpeg2
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0.GstPad:sink: caps = video/x-h264(memory:SystemMemory, meta:GstVideoOverlayComposition), alignment=(string)au, profile=(string)baseline, level=(string)4, stream-format=(string)avc, width=(int)3840, height=(int)2160, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, interlace-mode=(string)progressive, colorimetry=(string)bt2020, chroma-site=(string)mpeg2
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay.GstPad:video_sink: caps = video/x-h264, alignment=(string)au, profile=(string)baseline, level=(string)4, stream-format=(string)avc, width=(int)3840, height=(int)2160, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, interlace-mode=(string)progressive, colorimetry=(string)bt2020, chroma-site=(string)mpeg2
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink: caps = video/x-h264, alignment=(string)au, profile=(string)baseline, level=(string)4, stream-format=(string)avc, width=(int)3840, height=(int)2160, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, interlace-mode=(string)progressive, colorimetry=(string)bt2020, chroma-site=(string)mpeg2
/GstPipeline:pipeline0/GstOMXH264Enc-omxh264enc:omxh264enc-omxh264enc0.GstPad:src: caps = video/x-h264, alignment=(string)au, profile=(string)baseline, level=(string)4, stream-format=(string)avc, width=(int)3840, height=(int)2160, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, codec_data=(buffer)014240150301000a6742403395a00f0010f901000468ce3c80, interlace-mode=(string)progressive, colorimetry=(string)bt2020, chroma-site=(string)mpeg2
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink.GstProxyPad:proxypad0: caps = video/x-h264, alignment=(string)au, profile=(string)baseline, level=(string)4, stream-format=(string)avc, width=(int)3840, height=(int)2160, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, codec_data=(buffer)014240150301000a6742403395a00f0010f901000468ce3c80, interlace-mode=(string)progressive, colorimetry=(string)bt2020, chroma-site=(string)mpeg2
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay.GstPad:src: caps = video/x-h264(memory:SystemMemory, meta:GstVideoOverlayComposition), alignment=(string)au, profile=(string)baseline, level=(string)4, stream-format=(string)avc, width=(int)3840, height=(int)2160, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, codec_data=(buffer)014240150301000a6742403395a00f0010f901000468ce3c80, interlace-mode=(string)progressive, colorimetry=(string)bt2020, chroma-site=(string)mpeg2
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0.GstPad:sink: caps = video/x-h264(memory:SystemMemory, meta:GstVideoOverlayComposition), alignment=(string)au, profile=(string)baseline, level=(string)4, stream-format=(string)avc, width=(int)3840, height=(int)2160, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, codec_data=(buffer)014240150301000a6742403395a00f0010f901000468ce3c80, interlace-mode=(string)progressive, colorimetry=(string)bt2020, chroma-site=(string)mpeg2
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay.GstPad:video_sink: caps = video/x-h264, alignment=(string)au, profile=(string)baseline, level=(string)4, stream-format=(string)avc, width=(int)3840, height=(int)2160, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, codec_data=(buffer)014240150301000a6742403395a00f0010f901000468ce3c80, interlace-mode=(string)progressive, colorimetry=(string)bt2020, chroma-site=(string)mpeg2
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink: caps = video/x-h264, alignment=(string)au, profile=(string)baseline, level=(string)4, stream-format=(string)avc, width=(int)3840, height=(int)2160, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, codec_data=(buffer)014240150301000a6742403395a00f0010f901000468ce3c80, interlace-mode=(string)progressive, colorimetry=(string)bt2020, chroma-site=(string)mpeg2
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 9, dropped: 0, current: 7.05, average: 7.90
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 9, dropped: 0, current: 7.05, average: 7.90
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 13, dropped: 0, current: 7.01, average: 7.61
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 13, dropped: 0, current: 7.01, average: 7.61
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 17, dropped: 0, current: 6.95, average: 7.44
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 17, dropped: 0, current: 6.95, average: 7.44
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 21, dropped: 0, current: 7.00, average: 7.35
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 21, dropped: 0, current: 7.00, average: 7.35
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 25, dropped: 0, current: 7.06, average: 7.31
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 25, dropped: 0, current: 7.06, average: 7.31
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 29, dropped: 0, current: 7.04, average: 7.27
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 29, dropped: 0, current: 7.04, average: 7.27
Could you help to have a look at the above result, pelase ?
Thanks in advance,
K.
For update, I also activated the max. perf ( sudo nvpmodel -m 2 and sudo jetson_clocks) and used io-mode=2 as in GStreamer pipeline is slow but nothing changes.
Best regards,
K.
From JP4.4(r32.4.3), we have nvv4l2camerasrc plugin. It eliminates additional memory copy in using v4l2src. Please try the pipeline:
$ gst-launch-1.0 nvv4l2camerasrc device=/dev/video0 ! 'video/x-raw(memory:NVMM),width=3840,height=2160,format=UYVY,framerate=30/1' ! nvvidconv ! ‘video/x-raw(memory:NVMM),format=NV12’ ! fpsdisplaysink text-overlay=0 video-sink=nvoverlaysink -v
If you can achieve 4Kp30 withabove pipeline, please link with nvv4l2h264enc maxperf-enable=1 for video encoding.
Dear @DaneLLL,
Thanks for your pipeline. I could run it at 30 fps as below :
$ gst-launch-1.0 nvv4l2camerasrc device=/dev/video0 ! ‘video/x-raw(memory:NVMM),width=3840,height=2160,format=UYVY,framerate=30/1’ ! nvvidconv ! ‘video/x-raw(memory:NVMM),format=NV12’ ! fpsdisplaysink text-overlay=0 video-sink=nvoverlaysink -v
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstNvOverlaySink-nvoverlaysink:nvoverlaysink-nvoverlaysink0: sync = true
/GstPipeline:pipeline0/GstNvV4l2CameraSrc:nvv4l2camerasrc0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)3840, height=(int)2160, format=(string)UYVY, interlace-mode=(string)progressive, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)3840, height=(int)2160, format=(string)UYVY, interlace-mode=(string)progressive, framerate=(fraction)30/1
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)3840, height=(int)2160, interlace-mode=(string)progressive, framerate=(fraction)30/1, format=(string)NV12
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)3840, height=(int)2160, interlace-mode=(string)progressive, framerate=(fraction)30/1, format=(string)NV12
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink.GstProxyPad:proxypad0: caps = video/x-raw(memory:NVMM), width=(int)3840, height=(int)2160, interlace-mode=(string)progressive, framerate=(fraction)30/1, format=(string)NV12
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstNvOverlaySink-nvoverlaysink:nvoverlaysink-nvoverlaysink0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)3840, height=(int)2160, interlace-mode=(string)progressive, framerate=(fraction)30/1, format=(string)NV12
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink: caps = video/x-raw(memory:NVMM), width=(int)3840, height=(int)2160, interlace-mode=(string)progressive, framerate=(fraction)30/1, format=(string)NV12
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)3840, height=(int)2160, interlace-mode=(string)progressive, framerate=(fraction)30/1, format=(string)NV12
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)3840, height=(int)2160, format=(string)UYVY, interlace-mode=(string)progressive, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)3840, height=(int)2160, format=(string)UYVY, interlace-mode=(string)progressive, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 17, dropped: 0, current: 32.89, average: 32.89
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 33, dropped: 0, current: 30.08, average: 31.46
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 49, dropped: 0, current: 30.08, average: 31.00
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 65, dropped: 0, current: 30.07, average: 30.76
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 81, dropped: 0, current: 30.07, average: 30.62
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 97, dropped: 0, current: 30.06, average: 30.53
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 113, dropped: 0, current: 30.05, average: 30.46
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 129, dropped: 0, current: 30.04, average: 30.41
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 145, dropped: 0, current: 30.05, average: 30.37
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 161, dropped: 0, current: 30.03, average: 30.33
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 177, dropped: 0, current: 30.04, average: 30.31
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 193, dropped: 0, current: 30.03, average: 30.28
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 209, dropped: 0, current: 30.01, average: 30.26
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 225, dropped: 0, current: 30.04, average: 30.25
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 240, dropped: 0, current: 29.99, average: 30.23
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 256, dropped: 0, current: 30.03, average: 30.22
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 272, dropped: 0, current: 30.00, average: 30.20
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 288, dropped: 0, current: 30.00, average: 30.19
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 304, dropped: 0, current: 30.01, average: 30.18
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 320, dropped: 0, current: 30.00, average: 30.17
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 336, dropped: 0, current: 30.00, average: 30.17
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 351, dropped: 0, current: 29.99, average: 30.16
I’m also using JP4.4(r32.4.3). Could you clarify how to " link with nvv4l2h264enc maxperf-enable=1 for video encoding" a little bit more, please ?
Thanks and best regards,
K.
You can run
$ gst-launch-1.0 nvv4l2camerasrc device=/dev/video0 ! ‘video/x-raw(memory:NVMM),width=3840,height=2160,format=UYVY,framerate=30/1’ ! nvvidconv ! ‘video/x-raw(memory:NVMM),format=NV12’ ! nvv4l2h264enc maxperf-enable=1 ! h264parse ! matroskamux ! filesink location=a.mkv
Hi @DaneLLL,
Thank you very much. It works like a charm :
$ gst-launch-1.0 nvv4l2camerasrc device=/dev/video0 ! ‘video/x-raw(memory:NVMM),width=3840,height=2160,format=UYVY,framerate=30/1’ ! nvvidconv ! ‘video/x-raw(memory:NVMM),format=NV12’ ! nvv4l2h264enc maxperf-enable=1 ! h264parse ! matroskamux ! filesink location=toto.mkv
$ gst-discoverer-1.0 toto.mkv -v
Analyzing file:///home/nvidia/toto.mkv
Done discovering file:///home/nvidia/toto.mkv
Topology:
container: video/x-matroska
video: video/x-h264, level=(string)5.1, profile=(string)constrained-baseline, stream-format=(string)byte-stream, alignment=(string)au, width=(int)3840, height=(int)2160, framerate=(fraction)30/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
Tags:
container format: Matroska
video codec: H264
  Codec:
  Additional info:
    None
  Stream ID: 0986329c7517ec4ab9efa684e6fdb0d4448ab3aa6db06dd4a8a1c95c2af6bae8/001:13989757530665874744
  Width: 3840
  Height: 2160
  Depth: 24
  Frame rate: 30/1
  Interlaced: false
  Bitrate: 0
  Max bitrate: 0
Properties:
Duration: 0:00:14.084000001
Seekable: yes
Live: no
Tags:
video codec: H264
Dear @DaneLLL,
Btw, aside from the difference in the encoder ( omxh264enc vs nvv4l2h264enc), I observed a little difference in the container format: I used Quicktime (qtmux) in my command, but you used Matroska (matroskamux). I also tried to replace matroskamux by qtmux in your command but the encoded video seems not playable.
Since I have less experience with gstreamer, I’d like to have your confirmation about the fact that I cannot use Quicktime anymore since the quality of encoded video @7.5fps is much better than one @30fps?
Thanks in advance,
K.
For using qtmux, you have to send end of stream(EoS) to get a valid mp4. Please try the pipeline:
$ gst-launch-1.0 nvv4l2camerasrc device=/dev/video0 num-buffers=300 ! ‘video/x-raw(memory:NVMM),width=3840,height=2160,format=UYVY,framerate=30/1’ ! nvvidconv ! ‘video/x-raw(memory:NVMM),format=NV12’ ! nvv4l2h264enc maxperf-enable=1 ! h264parse ! qtmux ! filesink location=a.mp4
With num-buffers=300, it sends EoS after source sending 300 frames to downstream element. If your usecase is to exit through Ctrl + C, suggest use matroskamux or mpegtsmux.
