I am facing high RAM usage on startup and after launching 1 or 2 application then left with some ~200 MB. I have 4 GB RAM Jetson nano and currently it is running slow as compared to 4 GB Raspberry pi 4 , My nano sbc used it crash regularly. I hate it.
My humble request to Nvidia jetpak development team, kindly produce the lightest version of jetpack with only image processing/AI package preinstalled. Please no other apps required. Because this SBC is popular for its GPU and AI.
Thanks and Regards
Suman
Hi.
How is the RAM usage by your 1 or 2 applications? Maybe you can move the desktop manager from gdm3 to lightdm.
To install and configure lightdm display manager, enter the commands:
sudo apt-get update
sudo apt-get install lightdm
sudo dpkg-reconfigure lightdm
NVIDIA recommends LightDM GTK+ Greeter as the default LightDM login greeter. To install this component, enter the commands:
sudo apt-get update
sudo apt-get install lightdm-gtk-greeter
And use a lightweight window manager like LXDE.
To install and enable LXDE and Compton, enter the commands:
sudo apt-get update
sudo apt-get install lxde compton
Create the configuration file /etc/xdg/autostart/lxde-compton.desktop, containing these commands:
[Desktop Entry]
Type=Application
Name=Compton (X Compositor)
GenericName=X compositor
Comment=A X compositor
TryExec=compton
Exec=compton --backend glx -b
OnlyShowIn=LXDE
Hi @WayneWWW Thanks for your response. But all these steps I have already taken before posting this request.
Can you please suggest any other light weight linux distro like dietpi which I can use and run my object detection alone. No other applications required.
If not then please assist me how I can create the jetson compatible image from source
Regards
Suman
We will check and see if further enhancement can be done. There is a solution for running DeepStream SDK:
DS app running on SD, not running on eMMC - Part II - #5 by DaneLLL
If you run DeepStream SDK, please give it a ry.
