Hardware - GPU (A100/A30/T4/V100) : A10G
Hardware - CPU : AMD EPYC 7R32
Operating System : Ubuntu 22.04
Riva Version : 2.19.0
TLT Version (if relevant)
How to reproduce the issue ? (This is for errors. Please share the command and the detailed log here)
I’m using a g5.4xlarge based ec2 instance. My goal is to convert pretrained tts nemo models into rmir. I used Nemo 24..01.framework container. I mounted it with adrectory having riva_quickstart_2.19.0 and installed the nemo2riva 2.19.0.whl . I downloaded the fastpitch and Hifigan pretrained models in nemo format and converted them into .riva using the nem2riva command.
After that I mounted the same directory with riva-speech-2.19.0 and ran the following command to convert then .riva models into .rmir model using the following command :
riva-build speech_synthesis \
custom_tts.rmir:tlt_encode \
fastpitch_tts.riva:tlt_encode \
hifi_gan.riva:tlt_encode
once the rmir model is created I placed it inside local_models/rmir inside riva_quickstart.2.19.0. I set other services flags inside config.sh to false and tts to true. and the flag to read local rmirs true. i mounted the correct folder.
when I ran riva_init.sh it converted the rmir model into multiple directories inside models folder. one of them was onnx . but when I ran riva_start.sh it keeps on saying waiting for riva server to load the models. and then give health ready check failed.
on the other hand if I set the using_existing_rmir models to false it downloads the rmir model from ngc and converted them into directory. and this model get’s loaded at riva_start.sh correctly.
