• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.1
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) 510
• Issue Type( questions, new requirements, bugs) issue
I am trying to use the new nvstreammux with sync-inputs=1 and max-latency=1*1e9. It is working as expected. It drops frames when nvinfer is not able to keep up with rtsp source rate of 25fps. It processes only latest frames. However, it is flooding the message bus with WARNING and ERROR
Here is my bus on_message callback
gboolean
cb_bus_call_handle_exit_on_eos(GstBus *bus, GstMessage *msg, gpointer data)
CallBkData *clbkdata = (CallBkData *)data;
GMainLoop *loop = (GMainLoop *)
clbkdata->loop;
switch (GST_MESSAGE_TYPE(msg))
case GST_MESSAGE_EOS:
logw("EOS from element {}",
GST_OBJECT_NAME(msg->src));
logd("Mode exit_on_eos : End of stream received; Exiting loop");
g_main_loop_quit(loop);
break;
case GST_MESSAGE_WARNING:
gchar *debug;
GError *error;
gst_message_parse_warning(msg, &error, &debug);
logw("WARNING from element {}: {}",
GST_OBJECT_NAME(msg->src), error->message);
g_free(debug);
loge("Warning: {}", error->message);
g_error_free(error);
break;
case GST_MESSAGE_ERROR:
gchar *debug;
GError *error;
gst_message_parse_error(msg, &error, &debug);
loge("ERROR from element {}: {}",
if (debug)
loge("Error details: {}", debug);
g_free(debug);
break;
case GST_MESSAGE_ELEMENT:
if (gst_nvmessage_is_stream_eos(msg))
guint stream_id;
if (gst_nvmessage_parse_stream_eos(msg, &stream_id))
logw("Got EOS from source (number)-{}",
stream_id);
break;
default:
break;
return TRUE;
When I run the application, this is the error message I see
17:05:36.952813 dsutils.hpp:772 ERR[483311] Warning: GStreamer error: clock problem.
17:05:36.952978 dsutils.hpp:769 WRN[483311] WARNING from element stream-muxer: GStreamer error: clock problem.
17:05:36.952979 dsutils.hpp:772 ERR[483311] Warning: GStreamer error: clock problem.
17:05:37.011514 dsutils.hpp:769 WRN[483311] WARNING from element stream-muxer: GStreamer error: clock problem.
17:05:37.011516 dsutils.hpp:772 ERR[483311] Warning: GStreamer error: clock problem.
17:05:37.011632 dsutils.hpp:769 WRN[483311] WARNING from element stream-muxer: GStreamer error: clock problem.
17:05:37.011632 dsutils.hpp:772 ERR[483311] Warning: GStreamer error: clock problem.
17:05:37.070121 dsutils.hpp:769 WRN[483311] WARNING from element stream-muxer: GStreamer error: clock problem.
17:05:37.070125 dsutils.hpp:772 ERR[483311] Warning: GStreamer error: clock problem.
17:05:37.070800 dsutils.hpp:769 WRN[483311] WARNING from element stream-muxer: GStreamer error: clock problem.
17:05:37.070801 dsutils.hpp:772 ERR[483311] Warning: GStreamer error: clock problem.
17:05:37.070910 dsutils.hpp:769 WRN[483311] WARNING from element stream-muxer: GStreamer error: clock problem.
17:05:37.070911 dsutils.hpp:772 ERR[483311] Warning: GStreamer error: clock problem.
17:05:37.090217 dsutils.hpp:769 WRN[483311] WARNING from element stream-muxer: GStreamer error: clock problem.
17:05:37.090219 dsutils.hpp:772 ERR[483311] Warning: GStreamer error: clock problem.
17:05:37.125362 dsutils.hpp:769 WRN[483311] WARNING from element stream-muxer: GStreamer error: clock problem.
17:05:37.125363 dsutils.hpp:772 ERR[483311] Warning: GStreamer error: clock problem.
17:05:37.125539 dsutils.hpp:769 WRN[483311] WARNING from element stream-muxer: GStreamer error: clock problem.
17:05:37.125540 dsutils.hpp:772 ERR[483311] Warning: GStreamer error: clock problem.
What can be done?
