Does NGC cli have a proxy option?
My customer is using an https proxy (which also takes care of dns resolution) and NGC is not working on my RHL9 VM.
I need it to install an NVDIA A40 virtualized on the server.
Error is:
[Errno -2] Name or service not known
Adding debug information
ngc config set --debug
Guest mode in use. No API Key or Starfleet Auth detected.
Requesting URL (GET):
https://api.ngc.nvidia.com/v2/resources/nvidia/ngc-apps/ngc_cli
payload: None
params: None
Headers:
{‘Content-Type’: ‘application/json’, ‘User-Agent’: ‘ngccli/3.47.0 linux-x86_64’}
Error getting latest version for location
https://api.ngc.nvidia.com/v2/products
payload: None
params: None
Headers:
File “ngccli/ngc.py”, line 154, in main
File “ngccli/ngc.py”, line 95, in _check_warning_messages
File “ngcbpc/api/configuration.py”, line 1069, in get_unified_catalog_product_names
File “ngcbpc/api/configuration.py”, line 1059, in _get_unified_catalog_product_names
File “ngcbpc/api/connection.py”, line 144, in make_api_request
File “ngcbpc/api/connection.py”, line 270, in _request_with_retries
File “ngcbpc/tracing.py”, line 266, in send
File “ngcbpc/singleton.py”, line 18, in call
File “ngcbpc/tracing.py”, line 82, in init
File “ngcbpc/tracing.py”, line 72, in is_enabled
File “ngcbpc/util/ssh_utils.py”, line 143, in is_port_open
socket.gaierror: [Errno -2] Name or service not known
Command: ngc config set --debug
os: Linux-5.14.0-427.28.1.el9_4.x86_64
ngc-cli version: NGC CLI 3.47.0
Run “ngc diag all” to view more detailed information.
could I download the guest driver from another vm that has connectivity and the registered API key?
