Running in Ubuntu 22.04 LTS on x86 processor with A1000 GPU.
I am trying to run a TAO is a self-hosted mode, but can never get past NGC commands. I have setup NGC in several forms – python virtual environment (so effectively native) and docker.
In each case, calls to NGC result in output like (added --debug):
os: Linux-6.8.0-40-generic
ngc-cli version: NGC CLI 3.53.0
[Errno -2] Name or service not known
File "ngccli/ngc.py", line 163, in main
File "ngcbpc/tracing.py", line 146, in wrapper_span
File "ngcbpc/singleton.py", line 18, in __call__
File "ngcbpc/tracing.py", line 83, in __init__
File "ngcbpc/tracing.py", line 73, in is_enabled
File "ngcbpc/util/ssh_utils.py", line 143, in is_port_open
socket.gaierror: [Errno -2] Name or service not known
Command: ngc registry model list nvidia/tao/gazenet:* --
I believe this is due to some network / DNS / proxy error. I am behind company proxy, and usually HTTPS_PROXY and similar environment variables are sufficient. That doesn’t seem to be the case here, and I’m otherwise not sure how to remedy this.
Is there any recommendation here? I haven’t found anything on the forums that directly suggests how to work around this. I’m trying to avoid any externally hosted cloud instances for the time being.
