Hi! I am trying to run Isaac sim remotely with an azure or aws container, however whenever I try to generate the NGC key as it says in the documentation ([3. Deploy to Cloud β Omniverse Robotics documentation]). It tells me to select my nvdia account, and every time it tells me to set my profile as in this picture:
Thank you for your reply. Unfortunately I tried in different browsers but I canβt successfully obtain the NGC key. I also tried to refresh the page and access by going to setup in the NGC main page after loggin (Generate API key):
