Isaac Sim advanced installation: failed pulling container image from NGC
I am experiencing issues in the very first step of the advanced (container) installation of Isaac SIM (section 3.2, step 6).
After creating the NGC API key I am able to successfully login to nvcr:
:~$ sudo docker login nvcr.io
Authenticating with existing credentials...
WARNING! Your password will be stored unencrypted in /root/snap/docker/1779/.docker/config.json.
Configure a credential helper to remove this warning. See
https://docs.docker.com/engine/reference/commandline/login/#credentials-store
Login Succeeded
However, the docker pull fails:
~$ sudo docker pull nvcr.io/nvidia/isaac-sim:2022.1.1
Error response from daemon: manifest for nvcr.io/nvidia/isaac-sim:2022.1.1 not found: manifest unknown: manifest unknown
They updated the tutorial to the latest verison of Isaac Sim, which came out this week, but that version of the container has not been published yet. You can change the 2022.1.1 to 2022.1.0 to download the previous version, or wait for them to update the container.
Thanks, this resolved the issue.
For future setups, any way to list the available tags of nvcr.io/nvidia/isaac-sim?
They’re listed here Isaac Sim | NVIDIA NGC
