I followed the guidelines on how to deploy Isaac Sim on AWS EC2. And everything worked just fine. But after I stopped EC2 instance and started it again the container fails to start:
$ sudo docker run --gpus all -e “ACCEPT_EULA=Y” --rm -p 47995-48012:47995-48012/udp -p 47995-48012:47995-48012/tcp -p 49000-49007:49000-49007/tcp -p 49000-49007:49000-49007/udp nvcr.io/nvidia/isaac-sim:2020.2.2_ea
docker: Error response from daemon: OCI runtime create failed: container_linux.go:349: starting container process caused “process_linux.go:449: container init caused "process_linux.go:432: running prestart hook 0 caused \"error running hook: exit status 1, stdout: , stderr: nvidia-container-cli: initialization error: nvml error: driver not loaded\\n\""”: unknown.
