尊敬的支持团队:
我正在使用 NVIDIA NIM API 进行个人开发/测试。由于进行多智能体(Agentic Workflow)开发,单次任务会产生20-50次API调用环节,导致频繁遇到 429 Too Many Requests 错误,严重影响了开发进度。特此申请将速率限制从当前的 40 RPM 提升至 200 RPM。
尊敬的支持团队:
| 申请提高 NIM API 速率限制(40 → 200 RPM) | 0 | 167 | May 22, 2026 | |
| 申请提高 NIM API 速率限制(40 → 200 RPM) | 0 | 214 | May 8, 2026 | |
| 尊敬的支持团队: 我正在使用 NVIDIA NIM API 进行个人开发/测试。由于进行多智能体(Agentic Workflow)开发,单次任务会产生20-50次API调用环节,导致频繁遇到 429 Too Many Requests 错误,严重影响了开发进度。特此申请将速率限制从当前的 40 | 0 | 105 | August 28, 2026 | |
| Request for NIM API Rate Limit Increase (40 → 200 RPM) | 0 | 144 | May 7, 2026 | |
| 申请提高NVIDIA NIM API 速率限制(40 → 200 RPM) | 0 | 105 | June 4, 2026 | |
| Rate limit increase request — 40 RPM to 200 RPM for Testing | 0 | 136 | May 24, 2026 | |
| Request to Increase NIM API Rate Limit (40 → 200 RPM) – Personal Development Use | 0 | 91 | May 20, 2026 | |
| 申请提升 NVIDIA NIM API 速率限制(40 RPM 至 200 RPM) | 1 | 238 | July 6, 2026 | |
| Request for NIM API Rate Limit Increase (40 RPM → 200 RPM) | 0 | 91 | May 2, 2026 | |
| 申请提升 NVIDIA NIM API 速率限制(40 RPM 至 200 RPM) | 1 | 492 | July 5, 2026 |
