I made a custom driver and tried to use in Xavier(NX) I made changes to the cam_i2c_mux device tree and used ov5693 camera driver but when i try to use
" gst-launch-1.0 nvarguscamerasrc ! nvvidconv ! xvimagesink
", I get this error
"Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:645 No cameras available
(gst-launch-1.0:22233): GStreamer-CRITICAL **: 15:33:46.543: gst_mini_object_set_qdata: assertion ‘object != NULL’ failed
Got EOS from element “pipeline0”."
I tried using “v4l2-ctl --device /dev/video0 --stream-mmap --stream-to=frame.raw --stream-count=1 --set-ctrl bypass_mode=0” and got this in dmesg
[ 2875.744147] ov5693 9-0036: ov5693_power_on: power on
[ 2875.757604] OV5693 Writing Table
[ 2875.770547] Setting the Mood 0
[ 2875.770554] Setting the mode Success
[ 2875.770563] OV5693 Writing Table
[ 2875.770772] ov5693 number Start Streaming
[ 2875.796451] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
[ 2878.268417] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 2878.268605] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 2878.268751] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 2878.271324] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 2880.828392] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 2880.828555] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 2880.828740] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 2880.831542] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 2883.388376] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 2883.388574] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
The camera driver was working properly in Xavier(AGX)
Is there any way to fix this issue ?
hello varun.p,
these messages shows it cannot communicate with the camera devices.
could you please probe the i2c signaling to ensure you’re having correct regulator supply.
thanks
Hi @JerryChang ,
I tried to probe the i2c lanes and found i2c signals are sent to the camera, I also verified that the camera is also sending MIPI signal.
hello varun.p,
could you please follow below steps to enable VI tracing logs.
for example,
echo 1 > /sys/kernel/debug/tracing/tracing_on
echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
echo 2 > /sys/kernel/debug/camrtc/log-level
echo > /sys/kernel/debug/tracing/trace
cat /sys/kernel/debug/tracing/trace
Hi @JerryChang ,
I have attached the results of trace log here.
vi_tracing_logs.txt (4.5 KB)
hello varun.p,
I don’t see any sensor signaling coming to VI engine.
there should be FS (frame-start), FE (frame-end), SOF (start-of-frame), EOF (end-of-frame)…etc from the tracing logs.
may I know what’s THS settle time of the MIPI lane you’ve configured?
please check Sensor Software Driver Programming and refer to cil_settletime. it’s by default using zero for auto-calibrated.
Hi @JerryChang ,
The cil_settletime is zero.
Kindly check my configurations please let me know if I am missing anything
I have edited this in sources/kernel/hardware/nvidia/platform/t19x/jakku/kernel-dts/common/tegra194-camera-rbpcv2-imx219.dtsi
#include <dt-bindings/media/camera.h>
host1x {
vi@15c10000 {
num-channels = <2>;
ports {
#address-cells = <1>;
#size-cells = <0>;
vi_port0: port@0 {
reg = <0>;
rbpcv2_imx219_vi_in0: endpoint {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&rbpcv2_imx219_csi_out0>;
vi_port1: port@1 {
reg = <1>;
rbpcv2_imx219_vi_in1: endpoint {
port-index = <2>;
bus-width = <2>;
remote-endpoint = <&rbpcv2_imx219_csi_out1>;
nvcsi@15a00000 {
num-channels = <2>;
#size-cells = <0>;
csi_chan0: channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
csi_chan0_port0: port@0 {
reg = <0>;
rbpcv2_imx219_csi_in0: endpoint@0 {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&rbpcv2_imx219_out0>;
csi_chan0_port1: port@1 {
reg = <1>;
rbpcv2_imx219_csi_out0: endpoint@1 {
remote-endpoint = <&rbpcv2_imx219_vi_in0>;
csi_chan1: channel@1 {
reg = <1>;
ports {
#size-cells = <0>;
csi_chan1_port0: port@0 {
reg = <0>;
rbpcv2_imx219_csi_in1: endpoint@2 {
port-index = <2>;
bus-width = <2>;
remote-endpoint = <&rbpcv2_imx219_out1>;
csi_chan1_port1: port@1 {
reg = <1>;
rbpcv2_imx219_csi_out1: endpoint@3 {
remote-endpoint = <&rbpcv2_imx219_vi_in1>;
cam_i2cmux {
i2c_0:i2c@0 {
imx219_cam0: ov5693_c@36{
compatible = "nvidia,ov5693";
/* I2C device address */
reg = <0x36>;
/* V4L2 device node location */
devnode = "video0";
/* Physical dimensions of sensor */
physical_w = "3.674";
physical_h = "2.738";
/* Define any required hw resources needed by driver */
/* ie. clocks, io pins, power sources */
avdd-reg = "vana";
iovdd-reg = "vif";
/* Sensor output flip settings */
vertical-flip = "true";
mode0 { // OV5693_MODE_2592X1944
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
active_w = "1920";
active_h = "1080";
mode_type = "bayer";
pixel_phase = "bggr";
csi_pixel_bit_depth = "10";
readout_orientation = "0";
line_length = "1936";
inherent_gain = "1";
mclk_multiplier = "10";
pix_clk_hz = "123000000";
gain_factor = "10";
min_gain_val = "10";/* 1DB*/
max_gain_val = "160";/* 16DB*/
step_gain_val = "1";
default_gain = "10";
min_hdr_ratio = "1";
max_hdr_ratio = "1";
framerate_factor = "1000000";
min_framerate = "1000000";/*1 */
max_framerate = "60000000";/*60*/
step_framerate = "1";
default_framerate = "60000000";
exposure_factor = "1000000";
min_exp_time = "16667";/* us */
max_exp_time = "1000000";/* us */
step_exp_time = "1";
default_exp_time = "16667";/* us */
embedded_metadata_height = "0";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
rbpcv2_imx219_out0: endpoint {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&rbpcv2_imx219_csi_in0>;
i2c_1: i2c@1 {
imx219_cam1: rbpcv2_imx219_c@10 {
compatible = "nvidia,imx219";
reg = <0x10>;
devnode = "video1";
physical_w = "3.680";
physical_h = "2.760";
sensor_model = "imx219";
use_sensor_mode_id = "true";
* ==== Modes ====
* A modeX node is required to support v4l2 driver
* implementation with NVIDIA camera software stack
* == Signal properties ==
* phy_mode = "";
* PHY mode used by the MIPI lanes for this device
* tegra_sinterface = "";
* CSI Serial interface connected to tegra
* Incase of virtual HW devices, use virtual
* For SW emulated devices, use host
* pix_clk_hz = "";
* Sensor pixel clock used for calculations like exposure and framerate
* readout_orientation = "0";
* Based on camera module orientation.
* Only change readout_orientation if you specifically
* Program a different readout order for this mode
* == Image format Properties ==
* active_w = "";
* Pixel active region width
* active_h = "";
* Pixel active region height
* pixel_t = "";
* The sensor readout pixel pattern
* line_length = "";
* Pixel line length (width) for sensor mode.
* == Source Control Settings ==
* Gain factor used to convert fixed point integer to float
* Gain range [min_gain/gain_factor, max_gain/gain_factor]
* Gain step [step_gain/gain_factor is the smallest step that can be configured]
* Default gain [Default gain to be initialized for the control.
* use min_gain_val as default for optimal results]
* Framerate factor used to convert fixed point integer to float
* Framerate range [min_framerate/framerate_factor, max_framerate/framerate_factor]
* Framerate step [step_framerate/framerate_factor is the smallest step that can be configured]
* Default Framerate [Default framerate to be initialized for the control.
* use max_framerate to get required performance]
* Exposure factor used to convert fixed point integer to float
* For convenience use 1 sec = 1000000us as conversion factor
* Exposure range [min_exp_time/exposure_factor, max_exp_time/exposure_factor]
* Exposure step [step_exp_time/exposure_factor is the smallest step that can be configured]
* Default Exposure Time [Default exposure to be initialized for the control.
* Set default exposure based on the default_framerate for optimal exposure settings]
* gain_factor = ""; (integer factor used for floating to fixed point conversion)
* min_gain_val = ""; (ceil to integer)
* max_gain_val = ""; (ceil to integer)
* step_gain_val = ""; (ceil to integer)
* default_gain = ""; (ceil to integer)
* Gain limits for mode
* exposure_factor = ""; (integer factor used for floating to fixed point conversion)
* min_exp_time = ""; (ceil to integer)
* max_exp_time = ""; (ceil to integer)
* step_exp_time = ""; (ceil to integer)
* default_exp_time = ""; (ceil to integer)
* Exposure Time limits for mode (sec)
* framerate_factor = ""; (integer factor used for floating to fixed point conversion)
* min_framerate = ""; (ceil to integer)
* max_framerate = ""; (ceil to integer)
* step_framerate = ""; (ceil to integer)
* default_framerate = ""; (ceil to integer)
* Framerate limits for mode (fps)
* embedded_metadata_height = "";
* Sensor embedded metadata height in units of rows.
* If sensor does not support embedded metadata value should be 0.
mode0 { /* IMX219_MODE_3264x2464_21FPS */
mclk_khz = "24000";
num_lanes = "2";
tegra_sinterface = "serial_c";
phy_mode = "DPHY";
discontinuous_clk = "yes";
active_w = "3264";
active_h = "2464";
pixel_t = "bayer_rggb";
readout_orientation = "90";
line_length = "3448";
mclk_multiplier = "9.33";
pix_clk_hz = "182400000";
gain_factor = "16";
min_gain_val = "16"; /* 1.00x */
max_gain_val = "170"; /* 10.66x */
default_gain = "16"; /* 1.00x */
min_framerate = "2000000"; /* 2.0 fps */
max_framerate = "21000000"; /* 21.0 fps */
default_framerate = "21000000"; /* 21.0 fps */
min_exp_time = "13"; /* us */
max_exp_time = "683709"; /* us */
default_exp_time = "2495"; /* us */
embedded_metadata_height = "2";
mode1 { /* IMX219_MODE_3264x1848_28FPS */
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "3264";
active_h = "1848";
gain_factor = "16";
max_framerate = "28000000"; /* 28.0 fps */
default_framerate = "28000000"; /* 28.0 fps */
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
rbpcv2_imx219_out1: endpoint {
status = "okay";
port-index = <2>;
bus-width = <2>;
remote-endpoint = <&rbpcv2_imx219_csi_in1>;
lens_imx219@RBPCV2 {
min_focus_distance = "0.0";
hyper_focal = "0.0";
focal_length = "3.04";
f_number = "2.0";
aperture = "0.0";
tcp: tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
* Physical settings to calculate max ISO BW
* num_csi_lanes = <>;
* Total number of CSI lanes when all cameras are active
* max_lane_speed = <>;
* Max lane speed in Kbit/s
* min_bits_per_pixel = <>;
* Min bits per pixel
* vi_peak_byte_per_pixel = <>;
* Max byte per pixel for the VI ISO case
* vi_bw_margin_pct = <>;
* Vi bandwidth margin in percentage
* max_pixel_rate = <>;
* Max pixel rate in Kpixel/s for the ISP ISO case
* isp_peak_byte_per_pixel = <>;
* Max byte per pixel for the ISP ISO case
* isp_bw_margin_pct = <>;
* Isp bandwidth margin in percentage
num_csi_lanes = <2>;
max_lane_speed = <984000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <3>;//2
vi_bw_margin_pct = <100>;
max_pixel_rate = <123000>;
isp_peak_byte_per_pixel = <6>;//5
isp_bw_margin_pct = <100>;
* The general guideline for naming badge_info contains 3 parts, and is as follows,
* The first part is the camera_board_id for the module; if the module is in a FFD
* platform, then use the platform name for this part.
* The second part contains the position of the module, ex. "rear" or "front".
* The third part contains the last 6 characters of a part number which is found
* in the module's specsheet from the vendor.
modules {
cam_module0: module0 {
badge = "e3326_front_P5V27C";
position = "rear";
orientation = "1";
cam_module0_drivernode0: drivernode0 {
/* Declare PCL support driver (classically known as guid) */
pcl_id = "v4l2_sensor";
/* Driver v4l2 device name */
devname = "ov5693 1-0036";
/* Declare the device-tree hierarchy to driver instance */
proc-device-tree = "/proc/device-tree/i2c@c240000/ov5693_c@36";
cam_module0_drivernode1: drivernode1 {
pcl_id = "v4l2_lens";
proc-device-tree = "/proc/device-tree/e3326_lens_ov5693@P5V27C/";
cam_module1: module1 {
badge = "jakku_rear_RBP194";
position = "rear";
orientation = "1";
cam_module1_drivernode0: drivernode0 {
devname = "imx219 10-0010";
proc-device-tree = "/proc/device-tree/cam_i2cmux/i2c@1/rbpcv2_imx219_c@10";
cam_module1_drivernode1: drivernode1 {
proc-device-tree = "/proc/device-tree/lens_imx219@RBPCV2/";
Hi @JerryChang ,
The camera is streaming when using " gst-launch-1.0 nvv4l2camerasrc ! nvvidconv ! xvimagesink"
but still i am getting no cameras available when trying “gst-launch-1.0 nvarguscamerasrc ! nvvidconv ! xvimagesink”
How to fix no cameras available when using nvarguscamerasrc ?
hello varun.p,
it’s nvarguscamerasrc to parse the content and register camera nodes to system.
please update above to adapt to your sensor driver. especially, the devname, and proc-device-tree property.
you’ll also need to update the badge, otherwise it’ll load the ov5693’s ISP configuration.
thanks
Hi @JerryChang ,
What changes should I make ?
I used the same device-tree properties in Xavier AGX and it worked for my camera but not working in Xavier NX.
hello varun.p,
I’ve point-out three things in comment #10,
please have a try to update them and share the test results.
