I’m having a problem getting Linux to correctly detect my 1060 6GB card.
I keep getting the “no CUDA-capable device detected”. Strange thing is I have another 1060 I borrowed which works fine, it’s just mine I’m having a problem with. Here are some details:
| NVIDIA-SMI 387.22 Driver Version: 387.22 |
| 0 ERR! Off | 00000000:01:00.0 Off | N/A |
| 0% 56C P0 25W / 120W | 0MiB / 6072MiB | 2% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
-rwxr-xr-x 1 root root 26804 Nov 13 00:28 nvidia-bug-report.sh
-rwxr-xr-x 1 root root 68952 Nov 13 00:28 nvidia-cuda-mps-control
-rwxr-xr-x 1 root root 47832 Nov 13 00:28 nvidia-cuda-mps-server
-rwxr-xr-x 1 root root 225776 Nov 13 00:28 nvidia-debugdump
-rwxr-xr-x 1 root root 335720 Nov 13 00:28 nvidia-installer
-rwsr-xr-x 1 root root 29488 Nov 13 00:28 nvidia-modprobe
-rwxr-xr-x 1 root root 46608 Nov 13 00:28 nvidia-persistenced
-rwxr-xr-x 1 root root 294472 Nov 13 00:28 nvidia-settings
-rwxr-xr-x 1 root root 520320 Nov 13 00:28 nvidia-smi
lrwxrwxrwx 1 root root 16 Nov 13 00:29 nvidia-uninstall -> nvidia-installer
-rwxr-xr-x 1 root root 188000 Nov 13 00:28 nvidia-xconfig
crw-rw-rw- 1 root root 195, 0 Jan 30 20:26 nvidia0
crw-rw-rw- 1 root root 195, 255 Jan 30 20:26 nvidiactl
crw-rw-rw- 1 root root 195, 254 Jan 30 20:27 nvidia-modeset
==============NVSMI LOG==============
Timestamp : Tue Jan 30 20:47:03 2018
Driver Version : 387.22
Attached GPUs : 1
GPU 00000000:01:00.0
Product Name : Unknown Error
Product Brand : GeForce
Display Mode : Disabled
Display Active : Disabled
Persistence Mode : Disabled
Accounting Mode : Disabled
Accounting Mode Buffer Size : 1920
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-99b4fa80-2c34-2037-aa10-9d8499fea01a
Minor Number : 0
VBIOS Version : 86.06.66.00.3F
MultiGPU Board : No
Board ID : 0x100
GPU Part Number : N/A
Inforom Version
Image Version : G001.0000.01.04
OEM Object : 1.1
ECC Object : N/A
Power Management Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GPU Virtualization Mode
Virtualization mode : None
PCI
Bus : 0x01
Device : 0x00
Domain : 0x0000
Device Id : 0x1C0610DE
Bus Id : 00000000:01:00.0
Sub System Id : 0x862C1043
GPU Link Info
PCIe Generation
Max : 2
Current : 2
Link Width
Max : 16x
Current : 1x
Bridge Chip
Type : N/A
Firmware : N/A
Replays since reset : 0
Tx Throughput : 2000 KB/s
Rx Throughput : 1000 KB/s
Fan Speed : 0 %
Performance State : P0
Clocks Throttle Reasons
Idle : Not Active
Applications Clocks Setting : Not Active
SW Power Cap : Active
HW Slowdown : Not Active
HW Thermal Slowdown : Not Active
HW Power Brake Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
FB Memory Usage
Total : 6072 MiB
Used : 0 MiB
Free : 6072 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 2 MiB
Free : 254 MiB
Compute Mode : Default
Utilization
Gpu : 2 %
Memory : 0 %
Encoder : 0 %
Decoder : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Texture Memory : N/A
Texture Shared : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending : N/A
Temperature
GPU Current Temp : 55 C
GPU Shutdown Temp : 102 C
GPU Slowdown Temp : 99 C
GPU Max Operating Temp : N/A
Memory Current Temp : N/A
Memory Max Operating Temp : N/A
Power Readings
Power Management : Supported
Power Draw : 25.53 W
Power Limit : 120.00 W
Default Power Limit : 120.00 W
Enforced Power Limit : 120.00 W
Min Power Limit : 60.00 W
Max Power Limit : 140.00 W
Clocks
Graphics : 367 MHz
SM : 367 MHz
Memory : 4006 MHz
Video : 708 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Default Applications Clocks
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 1974 MHz
SM : 1974 MHz
Memory : 4004 MHz
Video : 1708 MHz
Max Customer Boost Clocks
Graphics : N/A
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Processes : None
