Hi, I installed Nvidia Tool Kit 9.1, without OpenGL. Ubuntu 16.04 OS
Copyright (c) 2005-2017 NVIDIA Corporation
Built on Fri_Nov__3_21:07:56_CDT_2017
Cuda compilation tools, release 9.1, V9.1.85
Now, I am trying to run the sample code provided in the SDK. ./deviceQuery
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 35
-> CUDA driver version is insufficient for CUDA runtime version
Result = FAIL
Other Info:
lspci | grep -i nvidia
01:00.0 VGA compatible controller: NVIDIA Corporation Device 1b02 (rev a1)
01:00.1 Audio device: NVIDIA Corporation Device 10ef (rev a1)
06:00.0 VGA compatible controller: NVIDIA Corporation GF108 [GeForce GT 620] (rev a1)
06:00.1 Audio device: NVIDIA Corporation GF108 High Definition Audio Controller (rev a1)
// cuda CUDA capable device like
@ubox:~$ lspci | grep -i nvidia
@ubox:~$ cat /proc/driver/nvidia/version
NVRM version: NVIDIA UNIX x86_64 Kernel Module 384.111 Tue Dec 19 23:51:45 PST 2017
GCC version: gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.4)
Now, I ran below command
@ubox:~$ nvidia-smi -a
==============NVSMI LOG==============
Timestamp : Thu Feb 15 12:59:54 2018
Driver Version : 384.111
Attached GPUs : 1
GPU 00000000:01:00.0
Product Name : TITAN Xp
Product Brand : GeForce
Display Mode : Enabled
Display Active : Enabled
Persistence Mode : Disabled
Accounting Mode : Disabled
Accounting Mode Buffer Size : 1920
Driver Model
Current : N/A
Pending : N/A
Serial Number : 0323917059049
GPU UUID : GPU-de0d3962-b234-a6e3-38f5-2d874f9f178a
Minor Number : 0
VBIOS Version : 86.02.3D.00.01
MultiGPU Board : No
Board ID : 0x100
GPU Part Number : 900-1G611-2530-000
Inforom Version
Image Version : G001.0000.01.04
OEM Object : 1.1
ECC Object : N/A
Power Management Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GPU Virtualization Mode
Virtualization mode : None
PCI
Bus : 0x01
Device : 0x00
Domain : 0x0000
Device Id : 0x1B0210DE
Bus Id : 00000000:01:00.0
Sub System Id : 0x11DF10DE
GPU Link Info
PCIe Generation
Max : 3
Current : 1
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Replays since reset : 0
Tx Throughput : 0 KB/s
Rx Throughput : 5000 KB/s
Fan Speed : 24 %
Performance State : P8
Clocks Throttle Reasons
Idle : Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
FB Memory Usage
Total : 12188 MiB
Used : 202 MiB
Free : 11986 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 5 MiB
Free : 251 MiB
Compute Mode : Default
Utilization
Gpu : 0 %
Memory : 1 %
Encoder : 0 %
Decoder : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Texture Memory : N/A
Texture Shared : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending : N/A
Temperature
GPU Current Temp : 38 C
GPU Shutdown Temp : 99 C
GPU Slowdown Temp : 96 C
GPU Max Operating Temp : N/A
Memory Current Temp : N/A
Memory Max Operating Temp : N/A
Power Readings
Power Management : Supported
Power Draw : 15.08 W
Power Limit : 250.00 W
Default Power Limit : 250.00 W
Enforced Power Limit : 250.00 W
Min Power Limit : 125.00 W
Max Power Limit : 300.00 W
Clocks
Graphics : 139 MHz
SM : 139 MHz
Memory : 405 MHz
Video : 544 MHz
Applications Clocks
Graphics : 1404 MHz
Memory : 5705 MHz
Default Applications Clocks
Graphics : 1404 MHz
Memory : 5705 MHz
Max Clocks
Graphics : 1911 MHz
SM : 1911 MHz
Memory : 5705 MHz
Video : 1708 MHz
Max Customer Boost Clocks
Graphics : N/A
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Processes
Process ID : 1317
Type : G
Used GPU Memory : 104 MiB
Process ID : 2274
Type : G
Used GPU Memory : 95 MiB
what could be wrong ?
