Hi. I was previously running cuda and cublas successfully on my laptop and within the last two weeks but then something went wrong. I am running 64-bit windows 8.1 with an NVIDIA Geforce GT 640M LE GPU. Everything was previously working using Visual Studio 2010 (unsure of the GPU driver installed when working, but I could find out if explained how). Then, yesterday I tried to run a program again for the first time in about 2 weeks and it ultimately boiled down to the no CUDA-capable device detected in deviceQuery.
Here’s what I’ve tried, without any changing behavior(in order):
Uninstall/Reinstall Cuda
Clean Reinstall GPU driver (both newest and second newest drivers)
Tried running Cuda-z but no cuda-capable device detected
Tried all of the above again in varying orders (getting desperate)
Windows System Reset to a week ago (that’s the oldest reset available)
Installed MS VS 2013
Clean Reinstall of GPU driver
I have almost the exact same problems and behaviors as described here: https://devtalk.nvidia.com/default/topic/791925/windows-7-quot-no-cuda-capable-device-is-detected-quot-with-cuda-capable-gpu-installed/
but I really don’t know if I could afford to do a whole reinstall of my OS because it would take at least a few days getting all my software reinstalled and things back to normal…
I haven’t tried to physically remove the graphics card, nor do I even know how to/if I should do that because I’m not that tech savvy with GPUs and I’m 4 weeks new to CUDA.
Please let me know if you have any other suggestions.
Also, here’s an output from running nvidia-smi
C:\Program Files\NVIDIA Corporation\NVSMI>nvidia-smi
Thu Jul 09 09:00:19 2015
| NVIDIA-SMI 353.30 Driver Version: 353.30 |
| GPU Name TCC/WDDM | Bus-Id Disp.A | Volatile Uncorr. ECC |
| 0 GeForce GT 640M LE WDDM | 0000:01:00.0 N/A | N/A |
| N/A 43C P0 N/A / N/A | 61MiB / 2048MiB | N/A Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 Not Supported |
C:\Program Files\NVIDIA Corporation\NVSMI>nvidia-smi -a
==============NVSMI LOG==============
Timestamp : Thu Jul 09 09:03:31 2015
Driver Version : 353.30
Attached GPUs : 1
GPU 0000:01:00.0
Product Name : GeForce GT 640M LE
Product Brand : GeForce
Display Mode : N/A
Display Active : N/A
Persistence Mode : N/A
Accounting Mode : N/A
Accounting Mode Buffer Size : N/A
Driver Model
Current : WDDM
Pending : WDDM
Serial Number : N/A
GPU UUID : GPU-66ca17fa-c833-92d0-445f-e2d97bdfd548
Minor Number : N/A
VBIOS Version : 80.07.4A.00.06
MultiGPU Board : N/A
Board ID : N/A
Inforom Version
Image Version : N/A
OEM Object : N/A
ECC Object : N/A
Power Management Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
PCI
Bus : 0x01
Device : 0x00
Domain : 0x0000
Device Id : 0x0FD310DE
Bus Id : 0000:01:00.0
Sub System Id : 0x909C104D
GPU Link Info
PCIe Generation
Max : N/A
Current : N/A
Link Width
Max : N/A
Current : N/A
Bridge Chip
Type : N/A
Firmware : N/A
Replays since reset : 0
Tx Throughput : N/A
Rx Throughput : N/A
Fan Speed : N/A
Performance State : P0
Clocks Throttle Reasons : N/A
FB Memory Usage
Total : 2048 MiB
Used : 61 MiB
Free : 1987 MiB
BAR1 Memory Usage
Total : N/A
Used : N/A
Free : N/A
Compute Mode : Default
Utilization
Gpu : N/A
Memory : N/A
Encoder : N/A
Decoder : N/A
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Texture Memory : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending : N/A
Temperature
GPU Current Temp : 42 C
GPU Shutdown Temp : N/A
GPU Slowdown Temp : N/A
Power Readings
Power Management : N/A
Power Draw : N/A
Power Limit : N/A
Default Power Limit : N/A
Enforced Power Limit : N/A
Min Power Limit : N/A
Max Power Limit : N/A
Clocks
Graphics : N/A
SM : N/A
Memory : N/A
Applications Clocks
Graphics : N/A
Memory : N/A
Default Applications Clocks
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : N/A
SM : N/A
Memory : N/A
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Processes : N/A
