I am trying to connect the Logitech-f710 control to the Jetson Orin nano. I am using the jetpack 6.0 but the control appears in the /dev/bus/usb/001/ not in the /dev/input/j* as many users comment. Also I read that can be something with this issue here but there is not aswer yet. Does anyone know what can I do in this case ? Thank you in advance
Normally when the kernel is built the compiler uses “gcc”. When you set cross compile environment variables, then the compiler will be prefixed with that content. As an example, let’s pretend you have: /usr/lib/aarch64/bin/
Now, let’s pretend all of those files begin with the name “aarch64-buildroot-linux-gnu-”, but otherwise that directory contains gcc, ld, objdump, and all of the usual programs that a compile might need. This means that when the rules want gcc, instead it will prepend and look for aarch64-buildroot-linux-gnu-gccbecause it asked for prepend plus gcc. All of those will end up as the cross tools via macro substitution of the prefix. You don’t specify a specific program in that directory, you specify only the prefix that makes names like “gcc” end up as “aarch64-buildroot-linux-gnu-gcc”. It will “do the right thing” automatically.
There are multiple macro substitutions going on, but eventually it will get to “CROSS_COMPILE=...some full path ending aarch64-buildroot-linux-gnu-”.
After that I copy the file kernel_out/kernel/kernel-jammy-src/drivers/input/joydev.ko to Jetson directory /lib/modules/$(uname -r)/kernel/drivers/input as the provided solution mentioned.
Then I run sudo depmod -a to update modules dependencies (trigger the module did not work without this)
Finally I trigger the moduel using sudo modprobe joydev
However, I am still do not getting the Joystick info I just can see it with lsusb and ls /dev/bus/usb/001/013 but is not working as js0 what can I do in this case ?
do i have to reflash the jetson for this i did’nt understand fron the documentation can any give a step by step guide for this
i am using jetson orin nano with jetpack 6.0
Yes, you have to re-flash the system. Please do
[1] Follow Quick Start section to download the system files for flashing Orin Nano developer kit. And follow the steps to Orin Nano developer kit.
[2] So now you have Linux_for_Tegra folder which is the default Jetpack release. And you can run initrd command to flash Orin Nano developer kit. Assume it is
~/jp61/Linux_for_Tegra
Please create a folder
~/jp61/src
Download source code to the folder and run
~/jp61/src$ sudo tar xpf public_sources.tbz2
And go to the directory for building kernel
~/jp61/src/Linux_for_Tegra/source
[3] You can follow the guidance to build kernel and NVIDIA oot modules
