it’s super weird that my nvidia GPU couldn’t be detected at all, neither by lspci or lshw -c display:
lshw -c Display
WARNING: you should run this program as super-user.
*-display
description: VGA compatible controller
product: TigerLake-H GT1 [UHD Graphics]
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 01
width: 64 bits
clock: 33MHz
capabilities: vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: iomemory:600-5ff iomemory:400-3ff irq:164 memory:6000000000-6000ffffff memory:4000000000-400fffffff ioport:4000(size=64) memory:c0000-dffff memory:4010000000-4016ffffff memory:4020000000-40ffffffff
WARNING: output may be incomplete or inaccurate, you should run this program as super-user.
and
00:00.0 Host bridge: Intel Corporation 11th Gen Core Processor Host Bridge/DRAM Registers (rev 05)
00:02.0 VGA compatible controller: Intel Corporation TigerLake-H GT1 [UHD Graphics] (rev 01)
00:04.0 Signal processing controller: Intel Corporation TigerLake-LP Dynamic Tuning Processor Participant (rev 05)
00:08.0 System peripheral: Intel Corporation GNA Scoring Accelerator module (rev 05)
00:0a.0 Signal processing controller: Intel Corporation Tigerlake Telemetry Aggregator Driver (rev 01)
00:0d.0 USB controller: Intel Corporation Tiger Lake-H Thunderbolt 4 USB Controller (rev 05)
00:14.0 USB controller: Intel Corporation Tiger Lake-H USB 3.2 Gen 2x1 xHCI Host Controller (rev 11)
00:14.2 RAM memory: Intel Corporation Tiger Lake-H Shared SRAM (rev 11)
00:14.3 Network controller: Intel Corporation Tiger Lake PCH CNVi WiFi (rev 11)
00:15.0 Serial bus controller: Intel Corporation Tiger Lake-H Serial IO I2C Controller #0 (rev 11)
00:16.0 Communication controller: Intel Corporation Tiger Lake-H Management Engine Interface (rev 11)
00:17.0 SATA controller: Intel Corporation Device 43d3 (rev 11)
00:1d.0 PCI bridge: Intel Corporation Tiger Lake-H PCI Express Root Port #9 (rev 11)
00:1d.4 PCI bridge: Intel Corporation Device 43b4 (rev 11)
00:1f.0 ISA bridge: Intel Corporation Tiger Lake-H LPC/eSPI Controller (rev 11)
00:1f.3 Multimedia audio controller: Intel Corporation Tiger Lake-H HD Audio Controller (rev 11)
00:1f.4 SMBus: Intel Corporation Tiger Lake-H SMBus Controller (rev 11)
00:1f.5 Serial bus controller: Intel Corporation Tiger Lake-H SPI Controller (rev 11)
01:00.0 Non-Volatile memory controller: Sandisk Corp Device 5014
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
Before it was working flawless. After I tried to re-install the driver version and play with bumblebee and prime-select, it suddently couldn’t be detected at all. I was thinking it’s the problem of configuration setting. However, it turned out to be deeper than that cause the nvidia GPU is NOT detected on Windows on the same laptop as well, which leads me to think about whether this is the problem of BIOS setting. After searching for suggestions on BIOS setting for a while, I still couldn’t manage to fix it.
This is the bug report attached.
nvidia-bug-report.log.gz (131.5 KB)
I am highly appreciating any help on this.
