Hi there, I have a Geforce RTX 2080 ti on an Ubuntu 18.04 machine.
The driver version is 510.54 and CUDA version is 11.6.
However when I run the command lspci | grep NVIDIA I get the following output.
86:00.0 VGA compatible controller: NVIDIA Corporation Device 1e04 (rev a1)
86:00.1 Audio device: NVIDIA Corporation Device 10f7 (rev a1)
86:00.2 USB controller: NVIDIA Corporation Device 1ad6 (rev a1)
86:00.3 Serial bus controller [0c80]: NVIDIA Corporation Device 1ad7 (rev a1)
The GPU is not getting detected with the above command.
But when I run nvidia-smi GPU is getting detected and I get the following output.
| NVIDIA-SMI 510.54 Driver Version: 510.54 CUDA Version: 11.6 |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:86:00.0 Off | N/A |
| 36% 34C P0 37W / 250W | 0MiB / 11264MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
Can anyone please help me with that?
