No GPUs Available
Problem Summary:
I am facing an issue when trying to start a container in a remote environment using NVIDIA AI Workbench after building it. Used:
PyTorch
A Pytorch 2.1 Base with CUDA 12.2v1.0.2 | Ubuntu 22.04 | Python3
Upon launching the environment, I receive the following error message:
No GPUs Available
Not enough GPU resources are available. You can continue without GPUs. Additionally, you can cancel to manually stop projects to free up GPU resources.
This error occurs despite having GPUs available on the server. The output from the nvidia-smi command confirms that both GPUs (NVIDIA GeForce RTX 3060 and GeForce RTX 3060 Ti) are detected and show minimal memory usage:
| NVIDIA-SMI 550.107.02 Driver Version: 550.107.02 CUDA Version: 12.4 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 3060 Off | 00000000:01:00.0 Off | N/A |
| 0% 39C P8 18W / 170W | 2MiB / 12288MiB | 0% Default |
| | | N/A |
| 1 NVIDIA GeForce RTX 3060 Ti Off | 00000000:04:00.0 Off | N/A |
| 0% 59C P8 21W / 200W | 2MiB / 8192MiB | 0% Default |
| | | N/A |
Interestingly, when I run the container directly from the terminal, it successfully recognizes the GPUs. This indicates that there may be an issue with how the GPU resources are allocated or recognized specifically within NVIDIA AI Workbench.
I would appreciate any assistance in troubleshooting this issue to ensure the GPUs are available for the container in the AI Workbench environment.
Please tick the appropriate box to help us categorize your post
[0] Bug or Error
Feature Request
Documentation Issue
Other
logs.txt (7.9 KB)
Is this on a virtual desktop?
it is nvidia AI Workbench installed on Windows 11
The screenshot doesn’t let me see which system that Workbench window is for. Is it for local or for a remote?
Regardless, let me echo back what I think you are doing.
  • You have Workbench installed locally on a Windows 11 system.
  • You have installed Workbench remotely on an Ubuntu system that has the two GPUs in question.
  • When you try to build and open a CUDA enabled project on the remote, you are getting no GPUs found even though there are GPUs.
Is this assessment correct?
Thanks for your support!!!
yes. I installed workbench on remote, installed and connected.(Screenshot from remote location)
I can modify files, launch jupyter(CPU) etc. on remote and nvidia workbench program.
using nvidia-smi in remote location, you can see the output(screenshot from remote).
About app Nvidia Worbanch. I installed program and connected to remote(screenshot from nvidia workbench program on windows11)
Q & A:
  • You have Workbench installed locally on a Windows 11 system. Yes
  • You have installed Workbench remotely on an Ubuntu system that has the two GPUs in question. Yes
  • When you try to build and open a CUDA enabled project on the remote, you are getting no GPUs found even though there are GPUs. Yes
In general, my project that needs GPU won’t run in workbench
Error using remote location:
ok. so i’m guessing this is a problem at the dependency level, like something with Docker or the drivers.
Are you using Docker or podman as the runtime on the remote?
I am having the exact same problem. I have the GPU on a remote ubuntu environment and am accessing it from a workbench environment on my laptop with ubuntu.
I have installed the nvidia container toolkit so doesn’t seem like a docker issue. Some environment info below.
|   0  NVIDIA GeForce RTX 3080        Off |   00000000:17:00.0 Off |                  N/A |
|  0%   28C    P8              5W /  370W |      10MiB /  10240MiB |      0%      Default |
|                                         |                        |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                              GPU Memory |
|        ID   ID                                                               Usage      |
|    0   N/A  N/A      2988      G   /usr/lib/xorg/Xorg                              4MiB |
I am facing the same issue but with a different configuration. I have installed Nvidia AI Workbench on my local Macbook Pro M3. I am trying to run the example RAG repo and I am using docker. I am getting the error as attached in the screenshot.
Hi, it looks like you are working locally on an ARM-based Mac machine.
If you are working locally on the mac, then please note that you do need a dedicated GPU to run this project. Your currently system does not have a dedicated GPU.
Do you have a remote Ubuntu box you have access to with a GPU? If so you can connect to it from your Mac and use that location for compute for this project. You can read more about how to do so here.
(Also please note that ARM-based macs are generally unsupported by HF TGI (base container image for this project). But it seems like the project built fine for you, so maybe it is ok)
I used desktop docker’s mac socket and configured my workbench to point to this file which allowed me to build the project. I am using NGC to remotely access a GPU but I am not sure if my NGC is configured correctly.
Try this:
sudo nano /etc/nvidia-container-runtime/config.toml
change
‘no-groups = true’ to
‘no-cgroups = false’
sudo systemctl restart docker
That fixed it for me.
