No output display in nano SDK4.0.2!
Hello I just installed latest DeepStream in latest Jetpack in Nano.
Problem: I couldn’t get output display in sample run.
nano@nano:~$ deepstream-app -c /opt/nvidia/deepstream/deepstream-4.0/samples/configs/deepstream-app/source8_1080p_dec_infer-resnet_tracker_tiled_display_fp16_nano.txt
Creating LL OSD context new
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_klt.so
gstnvtracker: Optional NvMOT_RemoveStreams not implemented
gstnvtracker: Batch processing is OFF
Runtime commands:
	h: Print this help
	q: Quit
	p: Pause
	r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
      To go back to the tiled display, right-click anywhere on the window.
** INFO: <bus_callback:189>: Pipeline ready
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
**PERF: FPS 0 (Avg)	FPS 1 (Avg)	FPS 2 (Avg)	FPS 3 (Avg)	FPS 4 (Avg)	FPS 5 (Avg)	FPS 6 (Avg)	FPS 7 (Avg)
**PERF: 0.00 (0.00)	0.00 (0.00)	0.00 (0.00)	0.00 (0.00)	0.00 (0.00)	0.00 (0.00)	0.00 (0.00)	0.00 (0.00)
** INFO: <bus_callback:175>: Pipeline running
KLT Tracker Init
KLT Tracker Init
KLT Tracker Init
KLT Tracker Init
KLT Tracker Init
KLT Tracker Init
KLT Tracker Init
KLT Tracker Init
**PERF: 27.60 (27.60)	28.14 (28.14)	28.14 (28.14)	27.18 (27.18)	26.55 (26.55)	27.10 (27.10)	27.10 (27.10)	28.14 (28.14)
**PERF: 26.92 (27.25)	26.72 (27.41)	26.72 (27.41)	26.52 (26.84)	25.92 (26.23)	26.32 (26.70)	26.52 (26.81)	26.32 (27.20)
**PERF: 27.60 (27.37)	27.80 (27.54)	27.39 (27.40)	28.00 (27.23)	27.80 (26.76)	28.00 (27.14)	27.80 (27.14)	28.20 (27.54)
**PERF: 27.30 (27.35)	27.30 (27.48)	27.70 (27.48)	27.30 (27.25)	27.10 (26.85)	27.30 (27.18)	27.30 (27.18)	27.10 (27.43)
**PERF: 27.63 (27.41)	27.83 (27.55)	27.03 (27.39)	27.23 (27.25)	27.43 (26.96)	27.23 (27.19)	27.43 (27.23)	27.43 (27.43)
**PERF: 28.17 (27.53)	27.56 (27.55)	27.76 (27.45)	27.97 (27.37)	27.56 (27.06)	27.76 (27.28)	27.56 (27.28)	27.76 (27.48)
**PERF: 27.31 (27.50)	27.31 (27.52)	27.11 (27.40)	26.91 (27.30)	27.11 (27.07)	26.91 (27.23)	27.11 (27.26)	27.31 (27.46)
**PERF: 26.67 (27.40)	27.47 (27.51)	27.07 (27.36)	27.27 (27.30)	27.27 (27.10)	27.07 (27.21)	26.87 (27.21)	26.67 (27.36)
**PERF: 28.03 (27.47)	27.82 (27.54)	27.82 (27.41)	27.62 (27.33)	27.82 (27.18)	28.03 (27.30)	28.03 (27.30)	27.62 (27.39)
**PERF: 27.71 (27.49)	27.90 (27.58)	27.90 (27.46)	27.90 (27.39)	27.90 (27.25)	27.71 (27.34)	27.71 (27.34)	28.10 (27.46)
** INFO: <bus_callback:212>: Received EOS. Exiting ...
Quitting
App run successful
nano@nano:~$
Only program running, no image/video output display.
I see CPU & GPU is getting occupied during the run.
Hi
Where did you run? you need to run on desktop in order to get output renderred to display.
I ran this on Jetson nano.
FYI: Below gstreamer pipeline is working.
gst-launch-1.0 filesrc location=/opt/nvidia/deepstream/deepstream-4.0/samples/streams/sample_720p.mp4 ! qtdemux ! h264parse ! nvv4l2decoder ! m.sink_0 nvstreammux name=m batch-size=1 width=1920 height=1080 ! nvinfer config-file-path=/opt/nvidia/deepstream/deepstream-4.0/samples/configs/deepstream-app/config_infer_primary_nano.txt batch-size=1 unique-id=1 ! nvtracker ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_klt.so ! nvinfer config-file-path= /opt/nvidia/deepstream/deepstream-4.0/samples/configs/deepstream-app/config_infer_secondary_vehicletypes.txt batch-size=16 unique-id=2 infer-on-gie-id=1 infer-on-class-ids=0 ! nvmultistreamtiler rows=1 columns=1 width=1280 height=720 ! nvvideoconvert ! nvdsosd ! nvegltransform ! nveglglessink
Can you change sink0 group type to 2 EglSink and try again?
Sorry, but I don’t understand your suggestion.
To make myself clear.
deepstream-app → command line is not working
gstreamer → command line is working.
yes, i mean you can change the file /opt/nvidia/deepstream/deepstream-4.0/samples/configs/deepstream-app/source8_1080p_dec_infer-resnet_tracker_tiled_display_fp16_nano.txt
Perfect. Problem solved :)
Sometimes guys like me, need to be spoon-fed.
Thank you very much for your patience.
Glad to know, you are welcome.
