No output from sgie in msgbroker on image inference
Hi, i think i posted in the wrong category but could not edit the existing post.
Continuing the discussion from No output from sgie in msgbroker on image inference:
• DeepStream Version
• TensorRT Version
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.0
• TensorRT Version 8.0.1
• NVIDIA GPU Driver Version (valid for GPU only) 495.29
• Issue Type( questions, new requirements, bugs) bugs
I am trying to infer an image(1frame) using deepstream-app with pgie + sgie and output to msgbroker . The pipeline is able to run successfully and the msgbroker is able to output the meta data infer from the pgie but the msgbroker did not have the output infer from the sgie . When i check the process flow, i noticed the msgconv start to process the message after the frame has done processing and did not wait for the object processing to be done in sgie . Therefore, receiving output without the meta data from sgie in the msgbroker.
Can you share your pipeline? Do you mean SGIE work in async mode?
The SGIE is neither a detector nor a classifier. It is use to generate some tensor output. For the async mode, do you mean classifier-async-mode? I have tried setting this parameter and it has to enable the tracker but when i enable the tracker, there is no detection on the image. I have attached the pipeline graph for your reference.
Can you ensure the model of the SGIE has right output?
When i ran with a video source or multiple image source (at least 4 source), i was able to get the expected output from SGIE in the msgbroker.
Can you change SGIE setting to have a check? such as infer for all class id.
Hi, tried change to infer all class id but still cannot get the expected result from SGIE.
Can you get the SGIE output when display the output in local instead of msgbroker?
