Hello to everyone.
I’m trying to configure KDE 6 on top of Wayland on FreeBSD 14.1. My hardware is composed by an intel I9 cpu and two nvidia cards. Actually I’m using the GTX 1060 as primary and I have reserved the RTX 2080 ti for the various virtual machines that I want to use (with FreeBSD,Linux or Windows 10/11 : everything works like a charme). To achieve the goal I’ve passed through my nVidia RTX 2080 ti inside a virtual machine based on FreeBSD 14.1,configured to use the latest packages available. This is the script that I’m using to launch Plasma 6 on Wayland :
export XDG_CONFIG_HOME="$HOME/.config"
export XDG_CACHE_HOME="$HOME/.cache"
export XDG_DATA_HOME="$HOME/.local/share"
export XDG_RUNTIME_DIR="/var/run/user/1001"
export LIBSEAT_BACKEND=consolekit2
ck-launch-session dbus-run-session startplasma-wayland 2> startplasma.log
Inside the vm,this is what is reported by nvidia-smi :
marietto@marietto:~ $ nvidia-smi
Wed Jul 31 16:01:47 2024
| NVIDIA-SMI 550.54.14 Driver Version: 550.54.14 CUDA Version: N/A |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 2080 Ti Off | 00000000:00:08.0 On | N/A |
| 30% 42C P8 21W / 250W | 160MiB / 11264MiB | 2% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
On the log file I see this interesting error :
No provider of glEGLImageTargetTexture2DOES found. Requires one of GL_OES_EGL_image
and I suspect that it is correlated to some nvidia component that’s broken inside the virtual machine.
Someone wants to give some help to fix that error ?
