Hi Rama,
could you please tell me the device type (ConnectX3 or ConnectX4) and the Link type( Ethernet or Infiniband )
I guess that you use Ethernet and you want to capture RoCE packets.
you can see HowTo Enable, Verify and Troubleshoot RDMA https://community.mellanox.com/s/article/howto-enable--verify-and-troubleshoot-rdma
To be able to use ibdump, you need to enable flow steering.
a. To enable flow-steering:
- add/create /etc/modprobe.d/mlx4.conf file and add this line:
options mlx4_core log_num_mgm_entry_size=-1
#/etc/init.d/openibd restart
(Make sure the you still have IP configured on the interface)
b. Run some RDMA traffic (e.g. ib_send_bw or similar above)
c. run ibdump to create *.pcap file.
# ibdump
Initiating resources …
searching for IB devices in host
Port active_mtu=1024
MR was registered with addr=0x61b8f0, lkey=0x10010d00, rkey=0x10010d00, flags=0x1
Device : “mlx4_0”
Physical port : 1
Link layer : Ethernet
Dump file : sniffer.pcap
Sniffer WQEs (max burst size) : 4096
Ready to capture (Press ^c to stop):
Captured: 82133 packets, 88626986 bytes
Interrupted (signal 2) - exiting …
# ls
sniffer.pcap
d. Open the pcap file using wireshark (or similar program)
In this case RoCE V1 was used (ethertype 0x8915)
Thanks,
Talat
