• x86 Machine with dGPU
• DeepStream Version : deepstream-6.3
• TensorRT Version: 8.6.1.
• NVIDIA GPU Driver Version (valid for GPU only) : Driver Version: 535.86.10 CUDA Version: 12.2
• Issue Type: questions
I have a deepstream pipeline as followiing.
export USE_NEW_NVSTREAMMUX=yes
gst-launch-1.0 filesrc location=/opt/nvidia/deepstream/deepstream-6.3/samples/streams/sample_1080p_h264.mp4 ! decodebin ! nvvideoconvert ! videorate ! "video/x-raw,framerate=25/1" ! nvvideoconvert ! "video/x-raw(memory:NVMM), width=640, height=480" ! m.sink_0 nvstreammux name=m ! nvstreamdemux name=d d.src_0 ! nvvideoconvert ! tee name=t ! queue max-size-buffers=60 max-size-time=2000000000 max-size-bytes= 440401920 min-threshold-time=2000000000 min-threshold-buffers=50 name=delay_queue ! fpsdisplaysink sync=false t. ! queue ! autovideosink
I want manual delaying of 50 frames for some experiment. But the pipeline is blocked if I am trying to play the video. If there is no delay queue it is working as normal. Please help me to put a delay queue of 50 frames.
PS: I need new streammux because of a shortcoming of the current streammux and old streammux works well with the delay.
Interestingly it works for smaller number of buffers(2/3) like the below one
gst-launch-1.0 filesrc location=/opt/nvidia/deepstream/deepstream-6.3/samples/streams/sample_1080p_h264.mp4 ! decodebin ! nvvideoconvert ! videorate ! "video/x-raw,framerate=25/1" ! nvvideoconvert ! "video/x-raw(memory:NVMM), width=640, height=480" ! m.sink_0 nvstreammux name=m config-file-path=streammux.txt ! nvstreamdemux name=d d.src_0 ! nvvideoconvert ! tee name=t ! queue max-size-buffers=3 max-size-time=2000000000 max-size-bytes= 440401920 min-threshold-time=2000000000 min-threshold-buffers=2 name=delay_queue ! autovideosink sync=true async=true t. ! queue ! autovideosink sync=true async=true
Please advice on how to solve it.
@fanzh any idea?
new streammux
new streammux not working
gst-launch-1.0 --gst-debug-level=3 filesrc location=/opt/nvidia/deepstream/deepstream-6.3/samples/streams/sample_1080p_h264.mp4 ! decodebin ! nvvideoconvert ! videorate ! "video/x-raw,framerate=25/1" ! nvvideoconvert ! "video/x-raw(memory:NVMM), width=640, height=480" ! m.sink_0 nvstreammux name=m config-file-path=streammux.txt ! nvstreamdemux name=d d.src_0 ! nvvideoconvert ! tee name=t ! queue max-size-buffers=30 max-size-time=2000000000 max-size-bytes= 440401920 min-threshold-time=2000000000 min-threshold-buffers=20 name=delay_queue ! fpsdisplaysink sync=false t. ! queue ! autovideosink sync=true async=false
new streammux working with smaller buffer size
gst-launch-1.0 --gst-debug-level=3 filesrc location=/opt/nvidia/deepstream/deepstream-6.3/samples/streams/sample_1080p_h264.mp4 ! decodebin ! nvvideoconvert ! videorate ! "video/x-raw,framerate=25/1" ! nvvideoconvert ! "video/x-raw(memory:NVMM), width=640, height=480" ! m.sink_0 nvstreammux name=m config-file-path=streammux.txt ! nvstreamdemux name=d d.src_0 ! nvvideoconvert ! tee name=t ! queue max-size-buffers=4 max-size-time=2000000000 max-size-bytes= 440401920 min-threshold-time=2000000000 min-threshold-buffers=3 name=delay_queue ! fpsdisplaysink sync=false t. ! queue ! autovideosink sync=true async=false
old streammux
export USE_NEW_NVSTREAMMUX=no
gst-launch-1.0 --gst-debug-level=3 filesrc location=/opt/nvidia/deepstream/deepstream-6.3/samples/streams/sample_1080p_h264.mp4 ! decodebin ! nvvideoconvert ! videorate ! "video/x-raw,framerate=25/1" ! nvvideoconvert ! "video/x-raw(memory:NVMM), width=640, height=480" ! m.sink_0 nvstreammux name=m batch-size=1 width=1280 height=720 ! nvstreamdemux name=d d.src_0 ! nvvideoconvert ! tee name=t ! queue max-size-buffers=30 max-size-time=2000000000 max-size-bytes= 440401920 min-threshold-time=2000000000 min-threshold-buffers=20 name=delay_queue ! fpsdisplaysink sync=false t. ! queue ! autovideosink sync=true async=false
Please find the pipelines with different outcomes. It will be help full for debugging the issue.
Hi @fanzh
any update on this?
I used DS 7 as well with the follwing pipeline
gst-launch-1.0 --gst-debug-level=3 filesrc location=/opt/nvidia/deepstream/deepstream-7.0/samples/streams/sample_1080p_h264.mp4 ! decodebin ! nvvideoconvert ! videorate ! "video/x-raw,framerate=25/1" ! nvvideoconvert ! "video/x-raw(memory:NVMM), width=640, height=480" ! m.sink_0 nvstreammux name=m config-file-path=streammux.txt batch-size=1 ! nvstreamdemux name=d d.src_0 ! nvvideoconvert ! tee name=t ! queue max-size-buffers=30 max-size-time=2000000000 max-size-bytes= 440401920 min-threshold-time=2000000000 min-threshold-buffers=20 name=delay_queue ! fpsdisplaysink sync=false t. ! queue ! autovideosink sync=true
and with following mux property
[property]
algorithm-type=1
batch-size=2
max-fps-control=1
overall-max-fps-n=30
overall-max-fps-d=1
overall-min-fps-n=25
overall-min-fps-d=1
max-same-source-frames=1
Not working as well, Please let me know if there is any update on this.
fanzh
June 26, 2024, 2:49pm
6
sorry for the late reply!
what do you mean about “the pipeline is blocked if I am trying to play the video”? did the output video hung?
some plugins have buffer pool, the plugins will wait if the pool is empty. I suggest simplify the pipeline to narrow down this issue. for example, please check if
gst-launch-1.0 filesrc location=/opt/nvidia/deepstream/deepstream-6.3/samples/streams/sample_1080p_h264.mp4 ! decodebin + queue+… is fine, then add other plugins step by step.
Please help me.
PS: It doesnt work on the DS 7 as well
fanzh
June 28, 2024, 9:26am
8
you can put the queue before nvvideoconvert. then it should not be affected by streammux.
But we need the queue after the streammux, because we are essentially trying to add overlays after a specific delay to the exact frame, using a queue and and pipe to send instantaneous overlays to the frame which is happening after delay.
Ajithkumar A K
fanzh
July 1, 2024, 3:04am
10
I increased some bufferpool size. this command-line in the log works well on DS7.0. Here is the log log.txt (1.2 KB).
Thank you @fanzh ,
Let me check and get back the delay, with a thread and overlay.
Hi @fanzh
Does this solution works, for ds 6.3? Since we are heavily dependent on jetpack 5.1, which in my knowledge doesnt have DS7 supoort.
fanzh
July 4, 2024, 5:25am
13
ajithkumar.ak95:
noticing you are using dGPU, why you are heavily dependent on jetpack 5.1. you can try the solution on DS63.
Hi @fanzh
we are parallel y developing an orin based solution too. I will get back on DS63 after checking the solution
fanzh
July 8, 2024, 8:40am
15
Sorry for the late reply, Is this still an DeepStream issue to support? Thanks!
Hi @fanzh
it is working in DS63, new streammux
max_fps_dur 8.33333e+06 min_fps_dur 2e+08
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
Missing element: MPEG-4 AAC decoder
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
^Chandling interrupt.
Interrupt: Stopping pipeline ...
Execution ended after 0:00:08.198833339
Setting pipeline to NULL ...
[ERROR push 353] push failed [-2]
Freeing pipeline
Al though while pasuing the pipeline, We are getting [ERROR push 353] push failed [-2],
Also, it is working even without nvvideoconvert output-buffers=30 property. FYI
fanzh
July 9, 2024, 6:18am
17
can this issue be reproduced on dGPU/Jetson with DS7.0? if yes, could you share the detailed reproducing steps and command-line? Thanks!
It is not replicable in DS7
fanzh
July 16, 2024, 6:05am
19
It is not happening in DS7, Yes we can close this
system
Closed
July 30, 2024, 5:17pm
21
