Hello!
I’m facing an issue with CUDA-API Debugging on Nsight Eclipse.
I can step through my c++ code or run it, but the debugger halts when I call an operation from the runtime API such as cudaMalloc(…) or something. It doesn’t respond to any terminating or suspending call.
The code runs perfectly in a fully compiled application… but the debugger halts on API and kernel calls.
Does somebody have a solution for this? Or faces the same issue?
Thanks for any response.
Best Regards
Archoran
