NSight Systems CLI DeepStream 6.0/6.1 container compatibility
RTX 5000, x86-64 RHEL
• DeepStream Version
6.0 (nvidia_deepstream:6.0-devel) & 6.1 (nvidia_deepstream:6.1-devel)
470.57.02 & 510.47.03
Possible bug
Hi, I am attempting to use the Nsight Systems CLI (nsys) inside the stock DeepStream 6.0 or 6.1 development containers released by Nvidia. I started testing nsys with the very latest release and stepped back each release until I found a version that worked inside the DeepStream containers. Here are the results:
nsight-systems-2021.2.4_2021.2.4.12-1_amd64.deb - works great
nsight-systems-2021.3.2_2021.3.2.4-1_amd64.deb - nsys: /opt/vulkan/build/Vulkan-Loader/loader/loader.c:5517: loader_layer_create_device: Assertion pCreateInfo->queueCreateInfoCount >= 1' failed. [nsight-systems-2021.3.3_2021.3.3.2-1_amd64.deb](https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2004/x86_64/nsight-systems-2021.3.3_2021.3.3.2-1_amd64.deb) - nsys: /opt/vulkan/build/Vulkan-Loader/loader/loader.c:5517: loader_layer_create_device: Assertion pCreateInfo->queueCreateInfoCount >= 1’ failed.
nsight-systems-2021.5.2_2021.5.2.53-1_amd64.deb – will not terminate application after specified delay
nsight-systems-2022.1.3_2022.1.3.3-1_amd64.deb – will not terminate the application after specified delay
NsightSystems-linux-cli-public-2022.1.1.61-1d07dc0.deb (latest from downloads) - will not terminate the application
To test this compile the Nvidia sample deepstream-app in the container and run:
nsys profile --wait all --gpu-metrics-set --trace=cuda,cudnn,nvtx,osrt,opengl --delay=10 --duration=2 ./deepstream-app path to config
Why is it necessary to revert back to nsys CLI version 2021.2.4 in order to successfully collect a profile in the DeepStream container? This appears consistent with both 6.0 and 6.1 development containers
Can you tell where you download the package?
Hi, the post above has hyperlinks you can click. They are all from:
or
https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64/
or you can try the latest NSight CLI download
This looks like NSight related. We are moving this post to the NSight forum to get better help.
Any updates on this?
