Hello, I am trying to profile my julia code with Nsight Systems but no report or error is generated, the execution simply freezes. My guess is there is an issue close to this topic, but since it was closed and it was for windows I opened a new topic.
This problem happens whenever I try to profile a julia code. For example, the following code freezes:
using CUDA
a = CUDA.rand(1024,1024,1024)
sin.(a)
CUDA.@profile sin.(a)
I’m using the following command to profile the code:
nsys launch --trace=cuda,cublas julia --threads 32 test.jl
The output is the following:
application launched
[ Info: Running under Nsight Systems, CUDA.@profile will automatically start the profiler
WARNING: CUDA tracing is required for cudaProfilerStart/Stop API support. Turning it on by default.
waiting for capture range to start the collection
Capture range started in the application
Any idea on How to solve this issue? I don’t have sudo permissions on this system. I can ask the maintainers to implement your suggestions but it is not ideal.
System Information
Some important information about the system:
- I’m running my code in an HPC with the CentOS Linux release 7.7.1908
- CUDA version: 11.1.1-GCC-10.2.0
- GPU: Tesla V100 16GB
- GPU Drivers: 510.47.03
- Julia version: 1.7.2
- CUDA.jl version: 3.11.0
$ nvidia-smi
| NVIDIA-SMI 510.47.03 Driver Version: 510.47.03 CUDA Version: 11.6 |
| | | MIG M. |
| 0 Tesla V100-PCIE... On | 00000000:3B:00.0 Off | 0 |
| N/A 29C P0 25W / 250W | 0MiB / 16384MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
