Hello- I’m trying to use Nsight Systems 2022.2.1 with the Julia programming language. When I try to launch the Julia REPL, the stdin/stdout/stderr streams are not available, and it just hangs until I hit Ctrl+C to exit. I’m running the following as Administrator from a PowerShell Core terminal on Windows 11:
nsys launch --show-output=true --trace=cuda C:\Users\<username>\AppData\Local\Programs\Julia-1.7.2\bin\julia.exe
If I add --help to the end of the above command, then it will still hang for a moment without output, but will exit after a short pause without an error code. So it seems in that case that the help output is lost, and nsys exits normally when the underlying Julia process exits normally.
This is using Nsight Systems 2022.2.1\target-windows-x64\nsys.exe. If I instead try to use Nsight Systems 2022.2.1\host-windows-x64\nsys-ui.exe, I’m able to connect to my Windows localhost. When I try to profile Julia, a blank terminal window will launch, nothing will be displayed, and the profiler will hang until the terminal window is manually closed. The result will be no CUDA trace data collected.
I’m running as Administrator, on Windows 11, using Nsight Systems 2022.2.1, display driver 512.15, and Julia 1.7.2 installed from Download Julia. I’m not using WSL, just vanilla Windows.
Are you able to reproduce this issue on Windows? Is there any other information I could provide to help troubleshoot? Thanks.
