Multidimensional grids, shared memory assessment. My code runs fine in the jupyter notebook and am getting the correct results. However, checking the code through the assessment button produces “Error-we encountered an error, please try again.” There is no feedback on the code itself so it appears to not be related to my code specifically but the api for assessment. Any help appreciated
Hi there I am having the same problem. Did you figure out the issue?
Hi, I have also encountered this error today, it turns out that your code has to be saved under the path assessment/xxx.py, the path is right on the construction upon the cell, check it closely.
