I am encountering a persistent issue with high CPU usage caused by the nv_queue
process on my system when the GPU is idle. I want to resolve it and below are the details of my setup and what I’ve tried so far:
System Information:
- OS: Ubuntu 22.04.5 LTS
- Kernel: 5.15.0-126-generic
- GPU: NVIDIA TITAN V (connected via Thunderbolt in an eGPU box)
- Driver: nvidia-driver-565
Problem Description:
When the GPU is idle, the nv_queue
process consumes approximately 10% of my CPU time. Upon investigating /proc/interrupts
, I observed that there are a significant number of IRQs from the GPU during idle times. However, when a process actively uses the GPU (e.g., a CUDA workload), the IRQ behavior and CPU usage normalize.
What I’ve Tried:
- Modify Xorg Options:
I followed the solution in this post:
What is nv_queue and why is it the top process on my system?.
- I added the suggested options to
/usr/share/X11/xorg.conf.d/10-nvidia.conf
(found vialocate nvidia.conf
Option "metamodes" "nvidia-auto-select +0+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}"
Option "UseNvKmsCompositionPipeline" "Off"
Option "TripleBuffer" "On"
Unfortunately, this did not resolve the issue.
- Remove
xserver-xorg-video-nvidia-565
Since I only use the GPU for CUDA and do not require any display output. I tried to remove xserver nvidia driver. However, if I removed this package, I could no longer start the X server.
- Switch to intel with
prime-select
If I were to setprime-select intel
, CUDA would be unavailable (no nvidia-driver is loaded at all). I currently use the “on-demand” mode.
Additional Notes:
- The issue seems to stem from IRQ handling when the GPU is idle.
- It seems it is related to xserver
- There is no graphic process for xserver when I run
nvidia-smi
Any idea?
Thank you for your help.
